PDA
View Full Version : Merlin Turbine Clinic
  1. The new M166TS review
  2. 140 ECU settings
  3. Jets Munt USA
  4. Propaine start turbine will not start with electric gas valve
  5. Jets Munt USA is up
  6. Merlin 160. What should I do?
  7. Merlin 140XBL A couple of running anomalies
  8. Merlin 140XBL starting issue
  9. 160
  10. Jet munts 140 starting [roblems
  11. 100x wont start.
  12. Back from holidays?
  13. VT80 Idle
  14. Fill in the Gap
  15. Merlin 140 Issue
  16. Jets Munt Service Question
  17. Gaspar Can you look at this log
  18. withe smoke
  19. fadec 10
  20. M70xbl
  21. Vt80 starter rpm failure message
  22. M100XBL temperature calibration
  23. Merlin 100xbl Not reaching full RPM
  24. Merlin 140XBL
  25. MERLIN 160 Question
  26. Merlin 200 throttle graphs
  27. Pipe Specs for 100XBL
  28. Pipe distance
  29. Inflight restart
  30. VT80 Starter motor
  31. Gaspar
  32. Which oil do you use?
  33. Xicoy HoTT Telemetry adapter
  34. No reply to emails from Gaspar/Jets-munt/Xicoy
  35. M-160 is this kero start or not.
  36. Vt 80 slow spool in air
  37. Intermittent problem with Merlin 160
  38. I can't get the Failsafe to work on my 140 XBL
  39. Vt 80
  40. Jet munts 140 Xbl problem starting
  41. Jet Munt VT80 question
  42. Jets Munt service
  43. Merlin 90 fire ball
  44. 100x start problems
  45. Merlin 140XBL startup issues.
  46. Merlin 140 ECU data terminal no longer work
  47. Vt 80 no start
  48. Merlin 140 problems
  49. Vt80
  50. My new project skyemaster mig 29 with twin vt80
  51. What a great service!
  52. VT 80 programming TX
  53. Merlin 140
  54. Diesel vs Paraffin
  55. Diesel ??
  56. Merlin 140 does not idle at 35K.
  57. VT 80
  58. VT80 question regards starting
  59. VT 80
  60. Merlin 140 mounting options
  61. 90mk2 pump limit reached !
  62. M40 turbine
  63. Merlin VT 80
  64. merlin 160 weak gas message
  65. FADEC DATA PARAMETER ECU MERLIN 160
  66. More VT turbines?
  67. VT80 Manual
  68. Any RPM/power wire issues on later Ver 10 ECU
  69. Older M90 upgrade to kero start ?
  70. 160..
  71. New Merlin 140 Slow spool 6 sec?
  72. Merlin M90
  73. FADAC speed low indication
  74. FADEC and A123's
  75. Ceramic Plug settings for Merlin90 & 160
  76. Merlin 90K - Start Bad error
  77. Fadec and windows 7
  78. Merline 90 problem
  79. Merlin Kero Start...
  80. Merlin 90 2.5% turbine oil OK ?
  81. Merlin 90 tail pipe to tail cone gap??
  82. Merlin 90
  83. Distance from engine to tailpipe?
  84. Builder for a Iron Bay- Byron corsair
  85. New Merlin 160 owner and I have some questions
  86. SPOOL UP TIME : 7 sec
  87. Merlin support
  88. Merlin 160 PROBLEM
  89. Power max hand trigger
  90. Downloading Info.
  91. Setting ECU to 'learn'...
  92. pump
  93. SMOKE SYSTEM SET-UP ??
  94. Merlin MK2
  95. Merlin MK2
  96. flight time
  97. TC4
  98. FADEC PC Connection question
  99. Fuel pump connection to ECU - Newbie Question
  100. available
  101. Merlin 160 - High idle?
  102. Merlin Kero Start
  103. Merlin Turbine support forum now open
