- Twister xtg Pro problems.
- Weird interference
- tornado s30
- BS904-013R
- shocks on tornado s30
- Clear side on 8e backdraft
- Making a track need ideas ?
- Thermal glue
- THE REDCATS A FLAMER!!!!!!!!
- aftershock 8e shocks
- servos humming?????
- motor fan
- Redcat Ground Pounder will not run
- Caldera SC 10E
- Twister Drifter
- Pics of my Local Track....Redcat did well
- Spur Gear (wheels spinning tight and running hot)
- SH .18 ABC or ABN?
- need Volcano help
- ...and damage was done!
- What does everone think of there earthquake 8e's?
- esc fan?
- Has anyone switched SH.18 to OS .18 in any Redcat? Or any other .18 for that matter?
- I thought I was going to make the jump!
- Hurricane XP Brushless conversion
- Want to drop in OS engine, will it fit?
- What to look for when upgrading servos????
- redcat websites?
- Motor seized :(
- Pull start issue
- nitro fuel compression prob
- earthquake into a backdraft
- 2.4ghz remote no servo signal
- How do you get in touch with rufaster
- help with twister reverse?
- switching Engine
- aftershock 8e differential oil?
- RedCat Earthquake 3.5 41 MPH
- RedCat Vortex SS 48MPH
- OS .18 in Caldera
- Redcat needs a PRO driver to race their trucks...
- question about the twister?
- Modified Lightning EP Pro 112 MPH
- Having trouble with my tornado Tune
- Difference in "upgraded" Shockwave/Tornado diff housing
- 8E questions
- twister upgrade
- HELP chewing up pinion gears.
- shockwave glow plugs?
- Lightning STR....wow!
- Tornado s30 video not changing gears HELP
- street tires
- Redcat Quality ...........
- 1/5 scale- anybody?
- Twister 2pc chassis not so good!
- shockwave's 27Mhz
- Backdraft 8E W/TP 45c batterys
- So is the Hurricane XTR a good buggy for racing???
- dimensions of twister battery compartment?
- backdraft 8E issues
- earthquake 3.5 throttle servo stickin
- need carring case
- whta's model is best for jumping off ramp?
- is redcat teasing me?
- which is best for backyard bashing?
- Redcat changing names
- Steel spur Gear for tornado s30
- twister xtg pro bodies?
- bent dogbone trornado s30
- Help! I broke a part and don't even know it's part number.
- harding the diff gears
- Backdraft 3.5 | Custom painted body
- Please Redcat????........give us a steel spur for the Aftershock 8e.
- Does anyone else get excited when it rains?
- Braking moter in. Need you help
- Shocks for Tornado EPX Pro
- Can anyone recommend tires for Aftershock?? Stockers have no traction.
- is it possible?
- Sumo Rock Crawler???
- twister xtg pro battery case?
- redcat volcano
- Checking axle grease info needed
- Tornado S30 tires
- Painting Tornado S30 wheels?
- Whats the best batt hump pack?
- Trouble deciding what truck to get
- battery info wanted
- wnt different tires for EQ 3.5
- First airbrush job!
- shipping?
- tornado s30 and volcano s30
- lighting epx pro+lipo=bye bye tires!
- Tornado EPX Pro is cogging
- two choices...
- redcat sucks? thats a lie.
- why is Redcat so inexpensive?
- New Carb Coming?
- quad shocks on 8E
- Check out this setup! Need Tire Help!!!!!
- differential silicon weight for the Tornado EPX Pro
- wider tire selection
- monsoon xtr
- volcano s30 rollcage
- Converting Earthquake 3.5 to a Backdraft 3.5???
- nitro fuel?
- Linkage Problem?? I think.
- EQ 3.5 glowplug info needed
- GoPro HD | Backdraft 8E 1st run
- glow plugs?
- Boiling plastic parts....Do people still do this???
- Please read please help / Tornado EPX Pro parts!
- redcat Monsoon XTR need opinion
- tornado s30 steering knuckle questions
- Top speed of a Tornado EPX Pro
- Tornado EPX Pro Lipo questions
- Where to buy an electric starter for the S30?
- Volcanio stub axles
- Good old Tornado S30
- Hurricane xtr losing steering
- Is the Aftershock also branded and sold as another truck???
- any better diffs. available?
- Tornado S30 Manual Error
- engine swap program?
- servo saver problem
- im being ignored by redcat support team why?
- Easrthquake 3.5 dogbone
- URCHOBBY bash fest
- Caldera 10E
- So who races their Aftershock 8e???
- A few questions
- twister xtg pro
- 8E C carier
- Tornado S30 14MM hex w/ one way bearing
- Twister XTG-PRO
- anyone with a 8E had steering issues?
- Fun with my Volcano SV30
- Is there a Steel Spur option for the Aftershock 8e???
- aftershock front diff gear ratios for 3.5 vs 8e?
- hard cased lipos?
- What good Lipos fit the Aftershock 8e?
- bang for your buck
- Tekin R8 and T8 motor esc combo
- Track Locator
- 3.0 sh wont idle
- Are Avalanche XP parts interchangeable with Earthquake 3.5 parts
- Replacement throttle/steering servos for Earthquake 3.5?????
- 8E upgrades
- Sell it or Upgrade it? Giving UP .........
- little help
- what do you own?
- t-bone racing upgrades for redcats.
- MGT shocks/springs work on the aftershock.
- i have a 8E question!
- redcat dealers help
- ** Undestructable RC Body** in 0-20 deg weather
- Need your opinion
- new to the hobby
- Earthquake 8E
- NEED ENGINE HELP PLEASE!
- Tornado S30 Stoped Responding
- reciever?
- motor mounts ?
- New engine for Tornado S30?
- Volcano S30 where to buy new brake disc?
- twister xtg pro?
- Earthquake 3.5
- Caldera 10e alum Upgrades install
- Redcat is crap uh?
- Volcano s30 vs Caldera 3.0
- banana/bullet plugs?
- Air leak?
- How will it run?
- Sumo
- volcano sv
- cold weather nitro
- Just sharing the carnage... Oh My....!
- Fitting Aftershock 3.5 body to Hurricane XTR
- interested in mixing their own fuel? you need this!
- Redact Twister XTG Pro vid..! I want one bad now....!
- a warning for electric RC owners!
- video of the NEW Redcat Twister on youtube here is the link
- 15% Nitro 18% oil PowerMaster Fuel.....!
- Shocks/Suspension Dropping
- Can you bump start a hurricane with the OFNA t-start
- volcano s30
- fried baby fried....
- What would Redcat fans like to see come out next?
- WOW....Lot's of Hate for Redcat online
- steering link
- Tornado S30 receiver
- 12 to 17
- Two speed for avalanche?
- What Truck boddies will fit Earthquake 3.5....and other upgrade parts?
- Avalanche XP wheel options?
- Which is tougher....Avalanch XP or Earthquake 3.5
- 2s lipos?
- Anyone have one of the New Recat Trucks or Buggies yet?
- earthquake steering again
- Caldera 10e on 3s lipo?
- Backdraft 8E
- replacement parts
- Part #'s help please
- Tsunami
- upgraded shocks
- Vid on replacement body for my Backdraft 8E
- Vid on Backdraft 8e battery box mod
- rs 10 xt
- help? bad something
- Step 1 of relooking my Backdraft 8E
- redcat racing shockwave
- BD8E wheel nuts
- new redcat racing monsoon
- back in the redcat family - aftershock 8e
- tornado bb 2 speed
- Remote Transmitter Help Plz
- Backdraft / Earthquake 8e battery box mods.
- Other bodies that fit backdraft 8e
- WARRANTY
- steel gear stripping! HELP!
- do you think i should give nitro a try?
- AC Adapter
- Battery question on 8E
- how do i get the upper deck off???
- strengthening body?
- Earthquake 3.5 clutch question
- Be strong my fellow winter RCers...Sring is around the corner!
- earthquake 3.5 steering
- My redcat buggy froze!
- Looking for best Backdraft 8e deal
- Caldera 10E radio question
- question about waterproofing and battery hold down
- my first body work: hemicuda earthquake 8e (pics)
- servo?
- questions about redcat 1/8 scale
- HPI to Redcat tire issue
- RedCat starter box
- Volcano S30
- redcat racing monsoon
- traxxas 4wd slash vxl VS. caldera 10E
- Never cared much for the Backdraft Body colors so.......
- Tornado S30 Glow Plug
- PLace to order parts
- I dont mean to rub it in or nothing....
- going to get a caldera...upgrade question
- EarthQuake Nitro Engines What fits What Doesn't
- motor turns?
- Great Option for Earthquake 8E Body Upgrade
- tornado s30 shock oil weight
- Bump starter for Hurricane XTR
- Redcat Aftershock 8E motor inop.
