View Full Version : T-Rex heli
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13]
14
15
16
17
18
- budget gyro question
- Trimming flight with T-rex 600...
- TREx 450- ar6100 or ar7000
- help I have an offset between the autorotation and tail drive gears
- T-Rex 450SA Adjustment Advice Needed
- 600 mm blades epoxy
- CCPM to HDE conversion
- Where can I buy Trex parts in South Florida?
- Best belt for a t-rex 450 tail
- control linkages
- alan szabo ringing out the trex 600N
- ground effect?
- 6xas and ccpm
- Pitch Guage How To
- Wiring question for Sonix 30A ESC
- Help/ DX6 settings for 450XL / Choppersrule
- SOLDERING 101
- My SE V2 vs SE
- successful first flights with new Rex
- TREX SA with 9C setup
- Understanding Battery "C" and ESC etc
- Throttle 'clicks'
- good lipo cell balancer?
- need help with futaba 6xas and trex
- Align Servos? - opinions please
- Different T-Rex versions
- HELP TAIL SERVO CHOICES
- Tail outta control!
- 25A esc with a 3550kv motor?
- Got my new 450 xl
- Chinese T-Rex Knock off??? PHOENIX 450SE
- TREX 600 SCALE BELL 222
- TREX 600 MECHANICS in Bell 222 with retracts (SCALE)
- Battery balancing?
- T-Rex 450 SE Tail Shakes
- radio for t-rex
- autorotation videos
- Blade tracking problems!
- Quick Newb Question On Models
- Need info on 450xl or 450sa
- Long Flight Duration is all I want
- DX7 Air versus Heli Version Thoughts...
- battery question
- trex600 maiden disaster!
- T-Rex SE VS T-Rex SE V@
- tp1010/210 balancer setup for fp 6s1p
- LiPo Battery Poll - Another one -Which Brand
- Another newb question, what IS idle up?
- n00b TREX 450 XL build
- carbon fiber v. fiberglass canopy
- Brushed T-Rex?
- Trex 450 setup problem
- I develpoed a new trick..The tick-tock alarm clock
- am i heading for a disaster
- tail pulsation
- How to save $18 and waste a weekend...
- Problems with pitch adjustments.
- Binding rear servo on Trex 450 SE
- Main belt pulley ?
- Loops, just do them
- Budget TREX
- Which frame, aluminum or CF
- Best place to buy a T-Rex450 SE
- Up and down
- battery charger for trex 450
- Hitec hs65 or JR 285 servos for Trex 450
- Futaba 401 or Logitec 2100 for a gyro for the Trex 450
- T-Rex 450SE "new" V2
- Tail boom - Carbon vs Aluminum
- mounting the 9650
- Good Deal??
- TREX 600 Problem!
- bare bones se?
- 450 user manual
- My new 450SE
- THINKING OF GOING ALL OUT ELECTRIC
- instructions?
- hacker C50 13l on a trex 600 ??
- trex600 setup help
- Belt stretching?
- Which TX?
- blade grip tightness
- Best esc placement opinions?
- tp1010 charger question
- Govenor
- Battery alarm
- Battery Mounting
- align esc help
- local IL help fine tuning?
- New Heli, trex600, raptor E620 or raptor 50?
- Wow! Carbon blades for $36.95
- Charger for 450Se
- 2 newb question on DX6 settings
- Dx7 setup for the T-Rex Se V2
- post your set-ups!
- Replacing Tail Boom
- Hot esc and motor
- Hey, 3D guys, need your help
- DX6 throttle stick sensitivity in the low stick position
- A couple of questions
- Lessons learned: Painting the Canopy
- make sure everything is tight
- X or XL?
- Flight times?
- t-rex600/dx-7 switch harness
- What does ESC mean?
- Futaba G190 gyro? Can it handle a T-REX 450?
- t-rex600/dx-7 more help needed please
- Help with ccpm vs. hde trex450xl helis
- When to replace Lipo's??
- Futaba GY611 Problem
- tracking throttle curve question
- Video... T-Rex 600
- Two firsts for me this weekend
- DX6,401,9650 question
- Trex 450S CF Manual Missing from Box
- 450 vs 600
- sims?
- I blame you guys!!! GT,KING,DON...all you all..
- Video: How low will you go?
- T-Rex standard servos
- Canopy sizes
- blade size question?
- BL35g esc Question
- triton jr. charger
- how do t-rex flybar paddles hook on?
- faster cyclic on 450XL ?
- The easy way to learn 3D
- Battery Mounting?
- 450xl gear grinding
- Which blade grips should I buy?
- anybody paint their own canopy?
- Very Very New To Heli
- frustrated with t-rex600/dx-7 setup HELP!
- Copter x purchase (Trex 450se clone)
- PVC coated blades?
- So how much wind is too much wind?
- What are safe ESC and motor temps?
- My first "SUCCESSFUL" loop...
- Test hop completed! Couple of questions
- servos for T-Rex 600
- need pics of ar7000rx placement on trex 600
- Your first inverted flight...
- brushless motor tight spots?
- Futaba S3154 & GY401
- t-rex 600 and dx-7 setups
- AR7000 help
- Bad esc or something else?
- Newbie confusion with simple gyro setup
- Head wobble at low RPM - is this a problem?
- will Futaba 6EXHP fly a T-TEX?????
- T-Rex 450 SE V2...what's the absolute best servo setup?
- Wires, wires and more wires!
- Vote, which servo is best hitec 65mg ot 65hb??
- T-rex 450 HDE and DX6 tx
- AR7000 and Futaba GY401
- T-Rex 600 electric video
- Motor questions for you EE's
- Align T-Rex Aluminum Case, Worth it?
- T-REX 450 SE Throttle Hold Pitch Curve
- help with trex 450s setup
- Major problems on my 450SE
- T-Rex 450 Guru Question (Frame Change).
- 450XL CDE rebuild is done!
- motor question
- Massive drain, can't even fly 5 minutes?
- servo noise
- s285 mini servos any good?
- T-Rex buying advice
- HS 65MG servo attachment
- good battery for the 450xl??
- T-Rex 450SE (CDE) Questions...
- Phoenix 45 ESC Question
- 450XL CDE Linkage Problem
- gyro Help!
- Horizontal vs vertical gyro mounting
- Changing all bearings
- Hitec HPD-07RH Receiver Range Problem
- Head Speed Question
- Align Charger won't charge TP Lipo?
- 401 gyro
- Apex MK3 balance connector
- Yes or No?
- Which Tail Drive gear??
- 4 cell lipos on the Trex
- Sale of SE
- post pics of your canomod airbrush canopy please.
- Trex head speed/motor/esc question
- Futaba GY401/S9650 on JR Equipment?
- Customised Trex 450Sish
- HELP with 450se carbon fiber boom , tail blade ,flybar paddle part numbers. Please!
- 450XL CCPM rotor head strength
- T-REX 600 CF build help.
- Hitec hs65 vs JR ds285 micro servos
- Flight trimming
- Which dx7 for 450se????please advise
- CopterX Main Rotor Head Set
- indoor 600 Trex
- DX6 Servos with T-rex
- recommendations for throttle and/or pitch curve numbers for the T-Rex 450 CCPM
- Comparison Trex 450XL, 450S, 450SE.
- how much for a trex
- TRex Models
- Assembling 450SA haed question?
- How are you guys setting up your tail control on the SE
- ABEC-3 Bearings on Trex 600
- Help buying first trex
- f
- Help ?
- Indoor Flying Areas (So. Cal.)
- Freaky 600 flight
- T-Rex 450XL CDE
- Channels, Futaba
- Any body have pics of this motor? Align Outrunner 400LF
- Crash, why? what to check?REDUX
- Good servos for T-Rex 450
- TREX tail help!
- Gyro/Servo combinations
- How bout posting your pitch settings
- 13T pinion noisy??
- What tips can you give me prior to building a Trex 450SA?
- ESC amp rating and battery C-rating?
- Great video! What type of camera?
- Trex 600 Swashplate binding
- Main shaft tensile tests
- Charge/Store Lipo's safely
- This is a good deal on Trex 600
- T-rex 450 SE what battery should i buy
- blade length?
- CNC 400 heli from xm seller.com
- Which gyro for Trex 450sa?
- Heli Movement
- Radio installation
- 450se Motor Question!
- What does the "C" rating on a lipo mean?
- TREX flips
- T REX Question
- First build problems, please help!
- set it up and flew it the "Finless" way
- Main Gear replacement
- Which Cell Balancer
- motor resistance
- align's website
- T-Rex 450X What is the first Upgrade.
- rpm question
- help finding rotor RPM
- new bee ques.
- Stiff swashplate
- Training Gear - Intermediate beginners, very Simple
