PDA
View Full Version : T-Rex heli
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
  1. microbeast plus setup for Trex 500XT issue
  2. DX6 IKON 2 TrexE 550 DFC Help
  3. Help with T-rex 500
  4. Trex 150 DFC & EU spec Spektrum TX problems
  5. Help - TREX 700L Dom Top / Castle Creations ESC / DX9 / AR7200BX
  6. Align Trex 550E v2 Flybar !! NEED !!settings for Futaba T7C TX
  7. Need some help with buying parts for my 700e
  8. Got my new baby today !!
  9. Trex 450L gyro operation
  10. T Rex 450 & 600 Gyro questions
  11. DX6I Setup for T Rex 600
  12. Robbe Roxxy ESC BL-Control 9100-6 Short Circuit
  13. Trex 450 plus dfc rtf-how to set up collective pitch limits
  14. Set-up Question
  15. Need help with trex 550 electronics setup!!
  16. TREX 450 pro help on repair
  17. Thicker Main Shaft on the 450.
  18. T-Rex 450 X
  19. Trex 150 tail hunt (wag) remedy options.
  20. Binding Trex 150 to Spektrum puzzle solved!
  21. Clone
  22. 3 S or 6S dominator
  23. ESC Help Needed...Please!
  24. Is Align still in bussiness?
  25. APS Lite and 450l problem to link
  26. Trex 450 Hotrod
  27. HK450: Is it the cheapest 450 heli
  28. trex 450 tail dont go right
  29. Dx6i radio set up help
  30. Which battery for Trex 550E Pro DFC... beginner pilot.
  31. Trex 250 MRS issues
  32. any advice is appreciated!!!
  33. T-Rex 600 pro
  34. Trex 450 XL sliding right!
  35. Trex 450 Sport throttle/pitch curve help
  36. 3GX setup problem
  37. Tail rotor suddenly not working after 6 month storage
  38. Blade grip bearings 450 Pro
  39. Trex 450Plus DFC RTF
  40. ZYX-S2 set up
  41. Align BL35P Setup Problem
  42. T-REX 250 Plus DFC T Type Arm
  43. T-Rex 250 Plus DFC RTF Helicopter drifts left or right
  44. Trex 450 Clone Question and tips
  45. T-Rex 450 SE question
  46. CopterX 450 DFC/ZXY-S Setup Nightmare
  47. Esc and motor getting too hot
  48. FE423Z one way bearingavailable
  49. Tail Wag, GY401 Please help
  50. 450 pro battery and canopy questions
  51. Value of used TREX 450 Pro
  52. FS-TH9X Aileron/Elevator stick not responding
  53. trex 450 se v2 fbl conversion......help
  54. Best 4CH for Intermediate
  55. HK-450GT CCPM Alloy T-Rex compatible - Part IV
  56. Did you fly today?
  57. whats the difference?
  58. Urgent please help!!
  59. Flybar or Flybarless what is better??
  60. I think i'm going to get the HK-600gt help needed!
  61. T Rex 450 Plus RTF
  62. I have stopped using Align Gyros & FBL 3G
  63. gopro on a 250?
  64. t-rex 450 motor surge
  65. I pulled the trigger on TREX 450 PRO
  66. T-Rex 450 rotor head/main shaft locking screw keep on breaking
  67. 450 PRO DFC vs PRO V2
  68. Video - T-Rex 450 Pro DFC Align
  69. ALIGN VS TAROT?
  70. Which heli?
  71. Which Kit is best ??
  72. Kit unboxing video: T-Rex 450 Pro DFC Supercombo Flybarless
  73. 3GX FBL rudder problem
  74. Need Help with TRex500 GP780 Gyro
  75. FPV with Trex 550e DFC
  76. Custom Safe Landing Kit
  77. LAST WEEK choice
  78. ESC problem.
  79. Noob to electric helis
  80. Dynam 450 erazor CF or B version
  81. 550 tail twitch issue, not a wag or bob
  82. Trex 450se converted to fit the Pro DFC torque tube tail drive ?
  83. Show me your flight Box :
  84. Trex 250 and 450 frame spacing
  85. Rudder servo for T-rex 450 //3-blade tail
  86. HK 450 Pro TT
  87. 450 tail wag
  88. Which HK model?
  89. T-Rex 450 pro DFC Receiver Choices
  90. TREX 450 Sport Blade grip separation
  91. Coolrunning HS-25 ESC Manual
  92. T-REX 100-What is It
  93. next heli ???
  94. spektrum Beastx DX6I
  95. 3GX flybarless system
  96. video camera for Trex 100?
  97. Time to go FBL on my 'ol 450 SE V2
  98. Trex 450 handling Characteristics
  99. TREX 450 need controller help
  100. HK-450GT CCPM Alloy T-Rex compatible - Part III
  101. Flybarless system or not?
  102. 2.4 Ghz Transmitter question
  103. TREX 600EFL Pro - Part Question
  104. My 450 tail jerks violently all of a sudden!?
  105. Looking at the Align APS Gyro
  106. What Gyro for T-Rex 450XL???
  107. Hk600 tail not holding
  108. What is this v2.0, with pictures this time
  109. Trex 450 bolts
  110. What 450 is this?
  111. Do i have to shorten the tail boom on the Hk500cmt
  112. HK250-GT Alloy+CF Trex 250 Compatible Clone
  113. First flight of the year and tail way out of trim... ***?
  114. hk 450 clone
  115. new trex 100x wont fly strait
  116. CopterX 500 / HK 500 CMT tail rotor grip failing in flight
  117. Trex250 GP750 severe Hunting Tail Wag issue
  118. very weird question
  119. is the E Razor pro carbon edition rtf really rtf
  120. 440mm blades on a 500ESP with 3GX?
  121. Gyro Programing
  122. charger and battery?
  123. 1 vs 2 batteries?
  124. Rear rotor weirdness
  125. question
  126. Which motor for a trex 600?
  127. Trex 600, which motor to use and should I oil them
  128. HK 450 pro question/help
  129. Building my first Heli
  130. Building my first Heli
  131. HK-450GT CCPM Alloy T-Rex compatible - Part II
  132. My 500 will not hold a hover.
  133. Align Trex 600 helicopter - softstart
  134. ALERT :exi aluminum tail upgrade
  135. Ball link reamer size?
  136. Trex-500 and Torque Tubes. ARGHHHHH!? Whats the point?
  137. Best Spektrum RX for a TREX 450?
  138. trex 450se v2 upgrade
  139. TREX 450 Pro V2 ESC question
  140. 450 Clone setup, HELP!
  141. Back and Forth
  142. HK 600 questions
  143. HK 600 question
  144. the Shakes
  145. McPX help thread
  146. What gyros is out there?
  147. HK450 GT Pro Tail Drive
  148. Trex 450 pro v2 flybar or 3gx - beginner?
  149. T-Rex 700E & Futaba R149DP Receiver
  150. 450 Clone Belt Drive
  151. T Rex 700E F3C
  152. Blind buying Trex 550E 3GX
  153. Blind buying 550E 3GX as first heli
  154. Gyros
  155. Esc Choices
  156. Trex 450 on 4s, more power, cooler running.
  157. T-REX 250 Vs. Velocity 90 CRASH
  158. Stripped Gears HK600GT - Help Please
  159. Adjustable 250 linkage
  160. Trimming an EXI 250
  161. Mast Shim TREX 550E V2 FLYBAR
  162. Best affordable motor for trex/hk 450
  163. Im back!!!!
  164. Profession Quality Aerial Video Using A TREX 500
  165. Need info on older T Rex 600
  166. Rotor wont turn
  167. Beginner question regarding T-Rex
  168. How to make proportional rudder movement?
  169. 600E Pro gyro
  170. Trex 450 Sport - Maiden and first time flip!
  171. FUTABA RAIDO
  172. HELP PLEASE T-rex 450 Pro 3GX
  173. Savox SB-2272MG vs Futaba BL251
  174. Jr gyro's
  175. Something wrong with tail control arm?
  176. trex 450 pro
  177. Align T-REX 550 E with Quark Spartan Gyro - You got to love that Sound
  178. Align T-Rex 550E V2 3GX
  179. 250 Clone interchangeable!?
  180. 600 flying video
  181. Hardcore 600 Smackdown
  182. Full CNC TREX 500 PRO 3GX BUILD
  183. 250 clone wanted
  184. will this canopy fit?
  185. flying my trex 450 pro
  186. Trex 600E destroys itself
  187. HK 250 GT clone
  188. trex 600 e esc issue
  189. trex 450 se v2 current price?
  190. Trex 250 on 3s ??
  191. Good price for T-Rex 450 Pro Super Combo?
  192. EXI 450 build??
  193. Align 600 ESP head on a Rap 50 ? ?
  194. Anyone done this mod to the 450 SA
  195. 75 amp Align ESC failed or not?
  196. trex 450 se v2 vs sport v3
  197. trex 450 SA
  198. Trex 600 maximum main and tail blade size
  199. Unwanted drift on exi 450 pro with belt
  200. Lipotech esc
  201. Tail hunting on trex 600e, but seems to be power train
  202. Trex 250 Clone War hang out
  203. eflite 60 amp esc
  204. SPEKTRUM DX8 Radio with 2 8-ch Receivers
  205. CopterX 250 motor question
  206. Where to buy a Trex 500 clone?
  207. will this fit?
  208. ESC temp.
  209. HK450 90% T-Rex compatible?
  210. How do you work a Thunder Power 1010 charger?
  211. 72 mhz and metal gear servos???
  212. size 700 or 550 which one is better
  213. need help with trex600e and viper 1300kv
  214. Chinese TREX500E Clones Safe or not? In flight Explosion
  215. HK 500 GT cyclic oscillation issue
  216. HELP...Trex 500
  217. Trex 500 ESP question
  218. Can you use three cell lypo on a 500 size heli
  219. Trex 550e Conversion (Electric to Nitro)
  220. trex 500 flight times
  221. 450 clones
  222. Tarot 450 pro
  223. Proud new Trex 450 Pro owner!
  224. T rex 450 Setup
  225. Red or Blue Loctite for Trex 600?
  226. t-rex 250
  227. T-Rex 450 Pro (Shaft Driven)
  228. EXI Clone questions
  229. Helichair conversion
  230. Align electronic problems
  231. taking it a bit too far in this hobby
  232. No liftoff when throttled up????
  233. Trex 450 Head speed with Dx7
  234. Heliup 450
  235. Trex-550 & DX6i Specktrum PROBLEM
  236. Align 3G Programmable Flybarless System on 450 Sport?
  237. help
  238. Trex 600 cyclic fine tuning problem? Or not advice
  239. Trex 550 question
  240. tex 450 help
  241. Electric Rotowing
  242. 450 trex set up
  243. Connectors
  244. my t-rex 500 getting a make over
  245. Trex 100s
  246. HK450 GT Pro Turning Right
  247. Trex 550 Flybarless Question
  248. Setup issue
  249. General Question about
  250. First build. 500
