View Full Version : E-Flite Helicopters
- Next upgrade???
- Blade CP Rotors will not trun
- Blade Cx Spinning
- just a thought
- MCX flight time
- Blade CP Pro. I Killed It.
- Hitec 5065(digital 65MG)
- anyone know how to adj. tracking on mcx
- Help
- Blade 400 Realflight
- Going Separates on the Blade cp Pro
- Hopping Up Two Blade CX2s
- SeaHawk Body
- CX 4 in 1 question
- Milliamp usage meters
- cx2 no lights on 3-n-1
- CX2 w/cam
- Xtreme Blade balancing
- cx2 power loss.. help!!!!
- CX2 Hop Ups
- CX2 - Aftermarket Balance Bar Holder
- Blade 400 motor adjustment
- Photos and video of Old bird with a Totally NEW trick (body and frame!)
- Fishing!
- Getting back to it...
- Too Fly or not To Fly?
- Batteries
- Blades - Boiling and More
- New Problem
- Blade MCX battery help
- New Eflite Lipo gets charge error.
- Blade mCX first impressions
- Is this Broken?
- Blade 400 Li-Po Battery
- What can you do with old Helli parts?
- QUESTION ABOUT MCX CAPABILITIES
- Cp pro or 400
- Bind-N-Play Blade mCX?
- Blade CX2 Canopy
- Which CX2 mods can help Twister Skylift?
- Australia Company Produces Commercial Co-Axial Heli
- CX out of control
- cx2 tail boom prob
- RCFEIND's RC Flying Music Videos - Flying - Music - How-To
- Futaba t9cap
- CX2 Aluminum Parts?
- MYSTERY LIPO Battery
- SUBJECT CLOSED
- new battery problems with bmcx
- blade cp 4 in 1
- CX2 power loss no lift...
- 2nd Generation Xtreme Motors for CX2
- Removing bearing from main gear Blade 400
- Blade 400
- Help on Lift-Off
- Best Online Vendor for CP Pro Parts?
- Blade 400 Main Gear Tips Ground Off
- mcx any problems with wire connection to battery
- Blade MCX Micro and Battery charger options
- Blade CP CNC Main Gear/Help needed
- CX2 Tunning
- Improoving flight time on the Blade 400
- Blade 400 replacement servo gears
- Blade cp+
- CX2 on a 9303
- mCX blown servos?
- Blade MCX Challenge - Lexington, KY
- Blade MCX issues, help needed.
- CX2 Chronic Limitations
- CX2 Main gear misalignment problems
- Cx2 Vs. B400
- Blade 400 Optional Battery
- Best folding blades for CX/2
- B400 and HS65 HB servos
- Blade 400 blinking light on the receiver ?
- outer shaft bearing holder
- Xtreme motors and best LiPo for CX2
- Cx2 blade problems
- Difficulty trimming for yaw with a CX2.
- Blade 400 Servo Failure!!
- CP Pro Glitching?
- Blade MCX For RealFlight G3.5
- What's that long life lipo bat for CP Pro?
- Blade CX 4in1 wiring information
- cx 1 tx
- Boom replacement on Blade CP
- Blade 400/ cp cpp FMS SIM
- Blade 3D VS. Belt CP
- Upgrade Servos on B400? HELP!!
- Blade CP Pro 2
- Cheap factory made blades?
- Swashplate woes blade 400
- need help swasplate blade 400
- swasplate set up on blade 400
- Can you actually learn something from the MCX?
- What's the difference?
- need help setting up a cp pro to a dx6i
- lama v4 blade cx2 compatibility
- new to helis
- BLADE 400
- Looking for a Gram Scale
- CX-2 BATTERY REPLACEMENT
- Blade MCX Charger Question
- Saga Continues...Must be overlooking something???
- gws dragonfly
- Blade CP radio glitch?
- Got My MCX!
- Blade 400 Expo
- Problems after replacing lower blades on CX2
- blade cx2 swashplate leveling tool
- Cancer hitting hard selling 2 450SAs and DX7
- Need advice on Blade 400 sale.
- B-400 Stabilizer fin on boom angle?
- B400: power loss mid flight
- Blade 400 battery connector leads?
- Faster, yet safe, charger for CX2 batteries?
- struggling and losing faith!
- Battery problems on Blade CX-2, please help.
- CP Pro carbon fiber blades?
- Just got a blade 400..How do you check belt tension..
- Blade CX-2 Easy to fly???
- JR servos for B400
- blade cx2, used with broken rotor blade, what problems to look out for?
- Alternate motor for a Blade 400
- Is my 4 in 1 fried????
- Problems with upgraded CX2
- balance of washers n bits on feathering shaft
- blade pitch question
- STILL DRFIFTING LEFT!!!
- Anyone use these batts on the 400 yet?
- Blade 400 RTF Questions
- Not enough positive pitch
- Blade cp pro charger?
- Blade 400/3D Gyro Question?
- Blade 400 on the way, Need battery advice!
- WOOT! got a Blade 400!!!
- main gear bearing removal/replace
- New CX2 Bell Jet Ranger Videos
- Blade 400 blade tracking
- Starter heli?
- CX2 - Top Blade Doesn't Turn
- Replacement parts for ESPH1000 Tail Boom Kit
- Par 370 Motor Problem
- Copterx Tail break down
- Eflite Blade CX2 Help
- Blade 400 3d
- easy way to center the tail without fumbling.
- Blade 400 with a7000
- Best RTF Heli after HBFP and Walk 36
- Blade Cp Pro Crash-Broken Parts
- Learning to fly the B400
- CP Pro Help
- Landing the B400
- Buying a Blade 400 3D
- cx-2 clockwise issue
- Esky lama vs E-flite Cx2
- My new CX glitches very bad
- Brushless ESC options
- Light hook ups for the body
- $20 blade cx2
- Flylites causing servo interference
- MY RUDDER INPUTS FAR TOO TWITCHY??
- Blade 400 Stupid Questions*
- Replacement motor for 430 stock on the Blade 400
- Newbie Cx question
- Installing Spektrum DX6i in Blade CP+
- Frozen Tailrotor servo Blade 400
- cx2 leans to the left and i cant stop it.
- Best place to get parts online? In Canada?
- CP Pro Newbie questions
- HELLO
- Need help with blade CP aileron controls
- 20 am brushless esc eflite question.
- Blade CP Pro BLades
- Blade out of control, CCW Spinning...FAST!
- Blade 400 wents nuts
- Replacing tail boom on Blade CP Pro
- CX2 / Xtreme upgrades parts WEIGHTS
- flybar questions ?????
- Blade CP Pro
- blade 400 mainshaft
- CX2 Heat Sink Mod Installation Pictures
- Lower part of my swash plate keeps popping off....
- Blade 400 bible
- gy110 gyro
- let's see those B400 pics.
- CP+ Hoping Violently
- gear mesh to tight?
- Has anyone tried this with a b400 gyro
- Symmetrical vs. Flat Bottom Blades
- Beginner Heli - I'm thinking about the Blade 400
- Can you buy just a CX2 without TX,etc?
- Carbon vs wood blades
- Strange Crash, What happened?
- Violent circles upon lift off??
- im going violently in circles.
- Moving up?
- CX2 on Multiplex Evo9 ?
- charging lipo batterys
- Question regarding my Gyro on my Blade CP Pro!
- B400 Pitch Help
- good way to balance CX/CX2 blades???
- Blade 400?
- Blade CX2 Hovering...
- Confused what should I do.
- Flight Simulator
- Proublem with a Flycamone2 on a Blade 400
- looking at the CP pro RTF? or the CX2 with SPEKTRUM DSM???
- A STORE IN THE LOS ANGELES AREA THAT SELLS BLADE CX2 PARTS?
- STRONGER BLADES FOR BLADE CX2?
- See picture, is this broke??
- noob with a blade CX....
- TP610c Charger Question?
- PROOF THAT THE BLADE CX2 CAN BE FLOWN IN EXTREME CIRCUMSTANCES!
- Uh-oh Battery Help Plz.
- How to prevent broken motor bushing??
- blade 400 why has my esc caught fire ?????????
- cx2 rx channel problem
- Blade 400 pitch is reversed
- a123 powered b400
- CX2 weird hovering situation?
- Need some upgraded skids for my CX2
- Cx2 Mods And Pics
- Blade 400 with Hughes 500 Fuzz
- Help Blade CP Pro Problems
- DOH!! dont use T-REX 450 tail blades!!
- CX2 has developed a squeal......
- CX2 4 in 1 turns from green to Red on full throttle
- Please Help, CX2 wont fly. Seems Simple! only Half Power?
- Good Flight Simulator????
- Cx2 / cx Easy canopy extra ventilation...
- Blade Cx2 Problem
- Begginer Thread
- Just getting it off the ground
- BLADE 400 replacement parts list?
- Blade 400 PNP Help Pls
- GWS DIRECT DRIVE IN CANADA??
- Blade 400 Pitch Servo Issues
- Blade CP Pro and a 9303
- Dual Flybar Linkage
- CX2 stock battery charge time
- Binding Question Blade 400
- Flybar removal question....
- delete
- Charging the Stock Battery with TP610c
- Gws Mod
- Tail bobs
- B-400: GYRO- re-re-revisited :P
- first flight with a blade 400
- dx6i can any one help with basic set up for cp pro
