PDA
View Full Version : E-Flite Helicopters
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Blade CX2- Alum inner shaft replacment
  2. Boomtown rocks!
  3. Blade 400 Ball Link threads?
  4. Great deal on 12v/3a B400 charger power supply
  5. Blade cx2 batterys
  6. Blade 400 Gyro rate mode
  7. Blade Pro with Futaba GY401 Gyro
  8. What are the sticky weight pads for?
  9. Blade cx problem
  10. Here's what happens when a CX2 falls out of the sky from 200 feet.
  11. Is this TBE?
  12. Blade CP+ upgrades. advice
  13. Now my CX is unstable, why?
  14. (Yet another) Blade CX2 grip question---->
  15. Trying to set Blade 400 to +/- 12 pitch
  16. BLADE CP+ QUESTIONS!!!!!!
  17. blade cx2 jet ranger fuselage?
  18. Crash Videos
  19. B400: Flybar & Spindle Replacement??
  20. blade cx no control
  21. Caught On Video: CP Pro Electrical Glitches, Problem Solved me thinks.
  22. How do I know if the gyro needs adjusting
  23. Odd Electrical Problem
  24. Gyro for a cp-pro
  25. Is Blade 400 Heli right for you? Are you ready for 3D?
  26. Whats a good battery charger?
  27. Blade 400 & GY401 Gyro
  28. Balance charger...
  29. If you dislike E-flite blades then please just go away
  30. I Never Should Have Changed A Thing on my CX2...Please Help.
  31. 140 degree Xtreme motors
  32. How do you hold your sticks?
  33. Blade CP Pro lose altitude during hover
  34. Did sitting for a couple of months kill my cx batteries ?
  35. Which motor is bad?
  36. CX2 problem
  37. Odd balance problem on BCP+
  38. b400 canopy
  39. CP PRO tail motor too powerfull?
  40. VOTE! Winner of the CX Hands-Off Hover Challenge
  41. Blade 400 3D Radio power system setup
  42. Online Canadian Stores?
  43. Blade 400 and A123 Batteries?
  44. Using a Futaba TX w/ the cp pro
  45. Why is Fixed Pitch easier than Collective Pitch?
  46. Dualsky SL 1300mAh lipo packs, anyone have expierence with these?
  47. Blade 400 and cp pro questions!!!
  48. forward left, huh?
  49. !!UPDATE!!(and question) Cool free CX2 flybar mod: So I get a pair of dykes...
  50. HELP: ripped the antenna cable of my CX2 TX - where does it go ?
  51. blade cx2 spin to left
  52. Eflight Blade CP+ learning questions
  53. Blade CP Pro (newbie)
  54. 2.4G Spectrum Radio System
  55. any left handed rc heli pilots here?
  56. 1st and 2nd CP Pro flights
  57. Pics of my helis
  58. Blade CX2 too much play in shafts
  59. Question about my CP Pro
  60. Servo problems on the b400
  61. More B400 questions, "skipping at startup"
  62. Blade CX Upgrades??
  63. Trim and set up guide for the B400
  64. Turns with a CP+
  65. Turns with a CP+
  66. Question RE: antenna on CX with upgraded boom?
  67. Blade CX2 help
  68. How the ?
  69. Kicking up problems...
  70. BLADE 400 VIDEO
  71. blade 400 & Dx7 settings
  72. CX2 Flybar & Weight Options (pic)
  73. Blade CX2 Extreme Core Set
  74. Blade CX trouble.. Any Advice Appreciated.
  75. Blade Cx2 turning problem
  76. WHICH IS BETTER / DO U PREFER ????
  77. Blade 400 Radio issue?
  78. Stateline Hobbies...?
  79. Desktop picture?
  80. Blade CX2 "yo yo"
  81. Blade 400 Purchase
  82. I HAVE A FEELING...-
  83. MY HELI JUST DOES NOT STOP LEANING RIGHT? SOMEONE PLZ PLZ HELP.........?
  84. CP Pro complete set up (help)
  85. Cp Pro Front Servo
  86. Finally flying my Blade CP (instead of the other way around)
  87. CP Pro mechanical problems continue, 1 week old
  88. CX2 Crash
  89. Blade 400 rebuild
  90. going for a CP
  91. Blade CP and disk orentation
  92. Blade CP main shaft / rotor head slop?
  93. TIP: CX2/V4 lessons for "next step" single rotor heli
  94. DX6i Spektrum on blade cp pro
  95. Xtreme
  96. I may be way off here but, cell phone lith. batts. for RC? No?
  97. Inadvertent Blade CX Aquatic Mod
  98. Moving servo linkage out one hole
  99. Debonder
  100. A different kind of scale CX
  101. Excuses from pilots for laughs
  102. Keep anything that rotates LIGHT on the CX2
  103. uughh..B400 lots of trouble :(
  104. First post, help with blades hitting each other..
  105. Canopies for the Blade 400
  106. Loop and Crash...
  107. blade pro
  108. scale ccw rotation
  109. Blade CX2 Battery/Charger issue
  110. Just got some bling for cx2
  111. cx2 servo problems on 3 different helis
  112. DX6i Spektrum on CX2
  113. Cx2 will only lift a couple of inches
  114. I need new LIPOs. What kind to get
  115. CX2 motor upgrade
  116. blade 400 tail servo question?
  117. CX2 yaw problem after minor crash
  118. CX vs CX2?
  119. Bring on the Blade 400 bling!!
  120. CP Pro - Warning! - Ball Joints!!
  121. What is this?
  122. Blade 400 + JR DS3400G gyro servo = tail flexing?
  123. Blade CP, No Lift, Installed Super Skids???
  124. Upper Blade Tracking - Suggestions?
  125. Nose spinning to the right ???
  126. Blade cx hop ups
  127. Brand new Blade 400 smokes and stops working
  128. BATTERY FIX ! How To Rebalance Lipo's
  129. gain and proportional pots troubles...
  130. Blade CX / CX2 Gallery
  131. Need some advise on my CX
  132. I'm moving on already!
  133. Can someone measure their CX/CX2 for me?
  134. Blade CX 2 Extreme
  135. Blade CX 2 Extreme
  136. Lubricating Servo Gears??
  137. Vent holes in CX2 3-in-1 unit needed?
  138. Blade cp pro servos keep striping gears
  139. Blade CX 2 Extreme
  140. Installing aluminum swash plate on CX2
  141. Warning on Carbon Fiber Shaft for CX CX2
  142. CP PRO wont lift off???
  143. Who's put HiTec HS65MG servos on their Blade 400?
  144. carbon fiber blades
  145. Carbon Fiber Outer Shaft for sale on Ebay
  146. blade 400
  147. Blade CP+ flybar weight installation Q?
  148. !!UPDATE!!!:Horizon woes: Was; RE: Uggh, yes another battery thread ;) Read on:
  149. is my cx2 a lemon?
  150. CP Pro info. 3 in one QUESTION? Help!
  151. Blade 400 Spare parts. What I need?
  152. lubricating gears/cogs & bearings ??
  153. Thanks Horizon... No really..THANKS!!
  154. CX2 & Now a B400 Q about Real Flight G2
  155. HELP WITH CX2 AFTER CRASH RX OR 3-IN-1??
  156. Drewed's bird
  157. CP Pro DX7 PITCH CURVE NEEDED HELP!
  158. New 3in1
  159. CP Pro info. Needed! Help!
  160. Whats Wrong? Test
  161. Uggh, yes another battery thread ;) Read on:
  162. Blade Cp Pro ready to take off
  163. b400 vibration
  164. Batteries and Chargers! HELP
  165. B400 Head Speed?
  166. Blade 400
  167. Blade 400 new owner, looking for advice
  168. Spektrum DSP75 for tail--major tail spin
  169. DX6i copy programming problem
  170. Adding extended inner shaft and aluminum lower blade mount –sluggish results?
  171. will a 2 cell lipo work in the blade cp?
  172. Blade CP Smells Like Somethings Burning
  173. CX2 Transmitter Trainer Output
  174. cx2 no lift after crash
  175. Weight of Xtreme & CX canopies???
  176. Blade CP Pro suddenly needs lots of aileron trim
  177. Need Help With Blade CX2
  178. BCX2 which hole on the servo arms do you have your link arm set on?
  179. CX2 Blade grips
  180. CX2 spins slowly in 3 FT circle when hovering
  181. CX2 pics and video
  182. CX2 battery tray
  183. blade cx2 charger problem
  184. Please Help Me and My Blade CP!!!
  185. Third Partly Aluminum Upgrades for Blade 400
  186. $56.00 in damage to my blade cx2
  187. blade 400 yes or no ?
  188. Blade 400: Power Cuts Out to Motor
  189. Blade 400 rudder servo DS3400G
  190. "Blade 400" DX6i timer function not working
  191. Blade 400 2 minute fly time
  192. CX2 Best batteries and motors?
  193. HELP!!!! Ive fallen in the toilet and can't get out!
  194. Direct Fit Metal Geared Servos Option For Blade 400??
  195. CX2 4in1 and 3in1 differences
  196. Biggest coax heli available?
  197. Custom battery tray?
  198. Busted
  199. CX2 - Up'ing the POWER !
  200. Blade 400- "Clicking" servo
  201. EXPO on throttle?
  202. Creating a new look
  203. BLADE 400 CHARGER PROBLEMS CAUTION?
  204. Blade 400 servos HELP HELP HELP
  205. Big problem
  206. g4 updated helis?
  207. CYRODRIVE DISCUSSION THREAD
  208. blade 400 batteries
  209. help! blade cx2 control problems
  210. Blade 400 Tips Needed Before Takeoff
  211. servo arm hole
  212. CP PRO TO A CP+
  213. I like my Belt Cp more then my Blade 400 look at my Belt cp hover rite of the box!!!!
  214. Spektrum DX6i lost Idle up -Blade 400
  215. Cryodrive shaft length flight testing
  216. 3 cell lipo on cx2 3-in-1?
  217. Blade CX2 outdoor flight?
  218. Front CPP servo.
  219. CX2 carbon fiber flybar enhancement
  220. Short ramble and servo question....
  221. B400 battery flight times
  222. any flyers from Western Wisconsin?
  223. Cryodrive shaft length?
  224. just called boomtown hobbies
  225. Instructions on how to Upgrade CX2?
  226. Blade mods
  227. Xtreme aluminum flybar center issues on CX2
  228. b400 tail kick out.
  229. cx swashplate quality
  230. CX2 propo-pot range of adjustment???
  231. home made dual tail motors CP+
  232. My First RC Helicopter - Advice
  233. Blade CX
  234. Yes/No DX6 vs Blade CX2 DSM
  235. Good Bye Blade 400, I'll miss ya
  236. Did it just mess up on me?
  237. Possible Battery Upgrade?
  238. transmitter charging?
  239. Idea? How to Measure Lift?
  240. Cheapest batteries?
  241. Blade 400 - unplugging the motor
  242. shorten all the wires on my CX2
  243. Blade cp + case
  244. CX 2 spins countere clockwise
  245. 11.1 1250 mAhr 15 c in a cx2 ?
  246. My Video Review of the Blade 400
  247. Need help adding a GY401 Gyro to the Blade 400
  248. My Blade 400 Experience [New to CP]
  249. deleted
  250. Latest BCPP tail mod
