View Full Version : E-Flite Helicopters
- Blade 400 - unplugging the motor
- shorten all the wires on my CX2
- Blade cp + case
- CX 2 spins countere clockwise
- 11.1 1250 mAhr 15 c in a cx2 ?
- My Video Review of the Blade 400
- Need help adding a GY401 Gyro to the Blade 400
- My Blade 400 Experience [New to CP]
- deleted
- Latest BCPP tail mod
- What altitude are you flying at????
- Blade 400 losing lift?
- B400: Swashplate Leveling-Which Linkage?
- BLADE 400 FINALLY COMING
- Remove the body fins on the CX2
- Dead on Arrival Xtreme Motor
- tailrotor input vs. headspeed?
- blade 400 3d and Hitec hs 65mg servo
- cx2 flight time?
- new member
- CX 2 Twitchy
- Best LiPo Quick Charger and Balancer for about $100 or less
- Blade CX No lift
- Dynam Vortex Flybar on CX2 (pic)
- Wood Dowel Tail Mod for Blade CP
- Does anybody have a Blade 400 model for the ClearView Simulator?
- CX2 Falls when rotating
- Tail Motor on CX & CX2 Xtreme Boom
- blade cx2 chargeing problem
- Blade 400 In Canada????
- B400 Batteries
- Xtreame blade question?
- Brushless Motors?
- b400 servo change gone bad
- cp+ setup
- My CX2, In the toilet?
- e-flight batteries cx2 - the manual says....
- alternate power supply for blade cp
- CX2 Piro rate?
- Parts question...2 to be exact
- CP+ servo or interference?
- Here Is My Heli
- Suggestions for next heli after CX2?
- Replacement blades for 400
- How far can a CX go outside?
- CP Blade gearbox
- 3S on a CX2 - AWESOME!
- Blade 400 Main Shaft and Blade Strikes
- Next step up for CX2 pilots
- Hey goldslinger..., about your CF flybar???
- CP Pro question (for brother in law)
- Why add all the CX2 aluminum parts???
- Weird CX2 crashing!!!!!! help!!!!!!!!!
- CAN'T ELIMINATE NOSE DRIFT!!
- CX2 rotors won't spin initially, need advice.
- Rebuilt Blade CP tonite
- Any pilots in Pennsylvania?
- eflite 3in1
- C.F. OUTER SHAFT; Extended to kill 2 problems
- Where to buy??
- CP Pro on the way...any tips or info?
- bad control problem help please!
- need help with my gyro
- Blade CX vs CX2 - What is the difference?
- blade cp pro upgrades
- Blade 400 3D - Advice please
- adjusting gear meash
- banking problem-Blade CP
- $1 led lights on CX2
- Blade CX2 Flybar warp question
- BRUSHLESS CP INSTALL
- Aftermarket Rotor Blades for Cx2
- Gyro mounted upfront
- New Blade 400 issue....
- CX2 Messed Up Badly. Have No Idea What's Wrong. Help!
- BoomTown Hobbies Carbon Boom Kit Questions
- Need Xtreme inner shaft cap
- Xtreme upper grips seem WAAAYY too heavy
- Eflite or Coco Lama
- Blade CX2 Outer Shaft
- Plastic is fantastic but is metal better? Our reporter on the street finds out what YOU think.
- Will CX2 Servos work with CX 4in1
- Blade CX2 Servos..Which To Buy?
- B400/DX6i: Adding Second Model & Binding?
- CX Motor Maintenance
- Blade CP +
- To drill or not to drill???? New 4in1 + drill = recipe for disaster
- Bad flybars
- Aluminum swashplate, good or evil? Story at eleven.
- Anyone tried CF flybar with plastic hub?
- warped blades are ridiculous
- Figures (an outdoor comedy)
- Unbreakable skids, good or bad?
- RF G2 controller with RF3.5 or Higher?
- crashing into wifes stuff...oops...LOL
- blade 400 r44 scale
- Spinner
- NO PUNCH LEFT
- My Blade CX will rotate a lot faster to the right than to the left. Toilet Bowl Effect?
- home made C.F. boom?
- Free to good home receiver and 3in1
- blade 400 crashed & rebuilt
- Big trouble
- Shaft question
- Blade 400 - Tips, tricks, and mods
- Rudder Trim Issues
- Battery Charger
- blade cx, cp, 400 scale helis
- Ack help! CX2 issues
- New CX2 Owner....A couple questions....
- Want to buy a DX6i
- CPPro Power Loss
- Would you purchase a full upgrade kit including a innershaft,outershaft, and flybar?
- cp vs cp pro
- CX2 and FSOne connection
- Setting control arms at 90 degrees
- Silver VS Carbon Brushes on Xtreme Motors
- Cx2 body work
- My heli pcs CX-2
- blade cx2 problem.....help
- blade 400 first impressions.....
- CX2 antenna
- Question about motors
- 3in 1 vs 4in1
- Better servos for the CX2
- Carbon Fiber Outer Shaft - CX CX2
- dsp75 in blade 400
- Bad Shakes - CX2
- Where's my photo?
- How do I remove the tail canopy on the Blade CX2?
- Lower Blade Problem- Cx2
- Roll Adjustment
- FP goes left - AARGHHHH!!!!!!!
- Thrust "Pops"
- Is this a good deal for leaving a CX
- Blade cx2 custom bodies.
- Lot of sparks
- Differences between coaxial or tail rotor
- Help with DX7 CPP
- my first movie
- Blade CX2 Transmitter ->PC simulator cable question
- Charger for Blade 400
- blade 400 speed control won't arm!
- HAPPY NEW YEARS to ALL
- Blade 400 Seesaw Holder?
- sooo... my girlfriend wanted to try.
- Tx as a SIM controller
- Loss of altitude in backward flight
- Links-Tips/Repairs/Mods CX-CX2
- Antenna wire wrap
- Blade CX2 spining left -
- Battery Charger
- Blade cx2 Best upgrades????
- High Altitude CX2 questions
- how to program a jr 9303 for the blade cx2
- NExt Step from CX2
- Moving a servo hole
- Extremely Simple Blade CX2 Questions
- Brand new cx2
- And she still flies...Blade CP
- BLADE 400 questions
- Blade CX Newbie Questions
- Blade cx madness
- Customized Blades CP or CX (lets see pictures)
- CX-2 Shaft dimensions
- replacing xtreme motor brushes
- Help, I want an LED spot light for my bird
- CX-2-How do you add reciever for futaba?
- carbonfiber flybar- no
- NEWBIE
- Blade CX2 - unstable flight after repair
- Can I get the original Blade CX transmitter to work with a simulator?
- charging a 400 battery
- naked CX2
- Xtreme Boom Tail Motor on CX2
- Blade CP PRO replacement blade grips?
- BLADE CX2 MOD ??????????
- G90 vs G110 gyro
- Blade CX2
- Struggling with Single Rotor basics
- Bad Clacking during hard manuevering...best fixes?
- Blade 400 VS Axe CP.
- Blade CX2 Lower rotor head replacement help
- Blade CX
- Converting!!!
- TX Won't Bind
- another round. . . U know You are Addicted when. . .
- Radio problem
- Anyone use FS One simulator?
- extreme blade grips
- Spektrum Neck Strap ???
- ef sabre help
- Hide your balance plug
- blade CP LED blinking green/red???
- 4-1 Unit
- What does charging in series mean? HELP with Align RCC-4CX
- CX No More Bent Outer Shafts. UPDATE !
- Online Calculators / for mm to inches and grams to oz.
- LiMN Packs?
- m e e e e e r y c h r i s t m a s ! ! !
- Need Battery Tray
- Setup for Blade CPP & Futaba 6EXH
- Blade CX Battery Problems
- Merry Christmas / Sign quest book
- CX-2 Spinning -- Help
- Flybar mod question
- DS75H servo replacement and setup?
- thanks for all of the help - 16 1/2min flight w/o crash
- Bearing kit for the CX-2
- 3S Paxk On CX2 ROCKS!
- G90 gyro adjustment
- Extreme grip / flybar link interfere
- Pitch curve on Blade 400?
- Servo Wires Braided = Less Interference
- CX2 CF/Aluminum Air Frame
- CX2 spinning to right
- xtreme motors don't fit please help!!!!!!!
- Shaft Straightening technique works
- Ewwww Grinding sound with up and down movement of shaft!!!???
- Adjusting Gear Mesh and Belt Tension
- blade 400
- blade cx extreme motors
- Got a wobble - replaced everything 1by1 - video avail ***PLEASE HELP***
- Carbon Fiber Tail boom....
- Going from a 7.4 lipo to an 11.1 ?????!!!!!!
- Grease or Oil Bearings / Choppersrule
- another factory sealed outer shaft bent BCX
- XHeli sales no responce to complate
- Lower blades still warped!
- CP Pro ready for inverted flight?
- I got ripped off!
- Blade cx2 shakes
- Connecting Cam to LiPo
- need help flying a circuit / tail wag..
- Belt-CP vs Trex / Choppersrule
- Diameter of main shaft on CP
- Intermittant servo on BCX2
- Quick E-flite on-line store within EU?
- Weak turn/spin
- Blade CX2 won't go above 6 inches...
- CX2 battery question(s)
- FPV - Anyone try yet? What R U using?
- CX2 4Min flight time ????
- AirHogs Reflex stability problem
- servo replacement
- Want to buy a new heli....which is better?
- cx2 swashplate
- Blade cp pro Video's
- Did i mess up the battery?
- CNC Aircraft Aluminum Parts for BCX2
