PDA
View Full Version : Helimax
Pages : 1 2 [3] 4 5 6 7
  1. Glitches on startup?
  2. Mimicking the Belt CP throttle curve for DX6 radio gear.
  3. Axe Cp servo problems Bell Hilller to
  4. No Lift!!!
  5. E-sky 0704A HH Gyro for Axe-CP
  6. The Axe CP-L as a 2nd Helicopter?
  7. other canopies for heli pro 450
  8. more on sustituting a radio
  9. New to helis
  10. Battery question
  11. DIRECT DRIVE TAIL ROTOR
  12. sustituting a radio
  13. Brushless AXE CP HELP!!!
  14. Axe CP v3!?! HAWTNESS...... nawt
  15. Looks like I'm in it.........
  16. Vertical Stablizer Alternative?
  17. IDLE 430
  18. helimax ez problem with upper blades
  19. Balde pitch?
  20. Direct Drive Tail Setup
  21. flybar balancing
  22. more on swash plate
  23. Stock E-board Axe CP (pics Please)
  24. New Lipo Problem
  25. aligning the swash plate
  26. Queston on ball joints?
  27. Digital Damper
  28. Helimax blade balancer
  29. What do you guys think about installing the lipos here?
  30. TAIL MOTOR
  31. Fitting a non-standard battery updatge
  32. Not Much Activity in this Thread
  33. Possible alternative gyro for the Axe CP?
  34. Help AXE CP Servos
  35. Where do you guys buy your lipo batt. from?
  36. Axe CP fix
  37. Love the Axe CP, but need a little help =(
  38. Axe Batt. recall reply
  39. kenetic 50
  40. Screws for CNC bell hiller mod for Axe cp
  41. MX450 XL comming up!?!
  42. Fitting a non-standard battery
  43. AXE CP DRIFTS LEFT
  44. *** Helimax Battery Recall ***
  45. Axe Belt Upgrade
  46. Axe CP tail motor Replacement !
  47. Battery recall
  48. Rotofly - no control over cyclic
  49. Bizarre tail heat sink mod
  50. Axe figure eights video
  51. HeliMax Battery Recall
  52. Axe CP and Realflight G4
  53. Heli-Max is recalling the GPMP0401 Lithium Polymer Battery Pack
  54. E-Board on a Axe-Ez
  55. What charger for li-po batt.?
  56. Lubrication?
  57. Axe cp gy240 problems
  58. the new Axe CPv3
  59. AXE CP.........
  60. how many times has you tail motor burned out?
  61. RotoFly Flybar Paddles
  62. Helimax Ball Link Pliers?
  63. Anyone try the $25 CNC Flybar system?
  64. How do you operate your transmitter?
  65. Axe CP 3-in-1 board
  66. Setting up a Helimax MX 400 Pro
  67. Futaba 401 Problems on Axe
  68. Hi Everyone + Blade tracking help
  69. axe cp baaaad
  70. Photo of ball-link mod. from 74 pg. Axe Thread
  71. Tail fins
  72. Jumping up and down!!!!!!
  73. Programming JR6102 transmitter for Heli-max mx400
  74. helimax axe cp glitch
  75. Axe CP-L Crazy Tail Rotor
  76. Axe CP loose tail boom
  77. Defective Axe EZ Battery?
  78. A couple of questions about my axe cp
  79. Axe CP thrusting down instead of up...**Updatedw/video**
  80. ROTOFLY wobble
  81. Ucando update
  82. AXE CP-little to no lift
  83. axe cp
  84. AXE CP pitch?
  85. New servos, everything is backwards now.
  86. hi maxx in an axe.
  87. CP Main Blades
  88. Bell-Hiller Upgrade Issue
  89. Axe CP motor
  90. Helimax axe cp Problem
  91. Lipo charging time?
  92. AXE CP- eboards burnig out- HELP
  93. Jumps in air after head speed, BL motor upgrade.
  94. How to get more blade pitch?
  95. Replaced 3 in 1 board Full Power Only Axe CP
  96. GPMP0400 stock AXE battery question
  97. AXE CP Takes off into the air with less than 1/2 throttle
  98. Blade Grips
  99. Axe CP - Tilts Right on Takeoff
  100. setup my new mx450xs, need help.
  101. Just bought my first REAL Heli! Axe CP-L
  102. Rotofly Underpowered?
  103. AXE CP programmed and flown FP?
  104. battery
  105. Axe CP-L, or a blade Cp+, or CP Pro??? Please Help!!
  106. Spare partz hungry
  107. DX7 install/program for AXE CP... Please!
  108. axe cp reciever
  109. heli-max axe cp
  110. Not cut out for it
  111. Flying backwards
  112. Used HeliMax Axe CP - Tail Rotor Question
  113. AXE CP Canopy Mod & Paint!
  114. Do they fly realistic?
  115. No power Main Motor Axe CP
  116. Tail Motor Pinion replacement
  117. first time heli operator
  118. Blades
  119. AXE CP Belt conversion question
  120. TX-USB PC Cable
  121. All Brushless and eliminating the 3 in 1?
  122. Axe CP-L - disabling idle-up switch???
  123. Bell-Hiller upgrade?
  124. AXE CP servo horn to middle hole?
  125. Axe CP and GY240
  126. Brushless tail motor for AXE?
  127. axe cp glitches
  128. Wiring Thunder power to Axe Cp-L
  129. how to replace parts?
  130. AxeEZ parts interchange?
  131. Can i do this??
  132. Rear Belt Kit
  133. Best Place for Parts
  134. Axe-Cp-L Lipo battery
  135. New radio in Axe CP??
  136. Skids anyone?
  137. BUMMING...Broken Pitch slider mount
  138. aluminum upgrades
  139. another first heli help thread
  140. AXE CP collective not working. help!
  141. Swashplate up or down?
  142. HELIMAX/ALIGN PARTS??
  143. Tail in circles
  144. Is the E-Flite Blade 400 shaft the same as the AXE CP? Parts?
  145. MX-400/ARK-400 parts/problems thread
  146. Installing Futaba GY401 in AXE CP
  147. My helimax cp jumps up for no reason.
  148. Axe cp No Cyclic control, but swash moves fine?????
  149. Did I fry my 4-1
  150. Axe CP Final (Almost) Form
  151. No Response at all..... Please read....
  152. Tower discontinued the MX450
  153. AXE CP Seperates No Rudder Control
  154. Nasty crash
  155. New Breed of an AXE-CP: MX300!
  156. how to program my Futbaba with mx400
  157. How is a HH gyro connected to the AXE? (Works)
  158. Heads Up!!! Futaba 2.4g systems with identical codes
  159. HBFP motor pinion
  160. set 240 gyro gain thru 6ex transmitter
  161. Throttling Down Automatically
  162. Axe CP - to train or not to train?
  163. Graduation from Axe: Let's see what's next!
  164. Resserected from the dead
  165. replace screws with
  166. AXE CP and eSky EK2-0704A gyro will work
  167. Main Blade Safety
  168. HELIMAX AXE CP ''NEED HELP''
  169. Any experienced Heli Pilots in Miami area
  170. Good Replacement motor for axe cp
  171. Blade Grip Question & Center Hub
  172. No Daylight, No Problem!
  173. Axe CP-L "stock" battery & chrgr. questions
  174. Another NEwb Question
  175. Axe cp mainshaft replacement help
  176. 450 PINION TROUBLE
  177. Replacement Gear for Tail Motor
  178. MX400 overheating battery
  179. Hobbico Support #??
  180. Using the HH Gyro on the AXE CP
  181. Axe CP Main Blade Installation
  182. Can my axe cp handle this?
  183. MX400 PRO Swashplate Type?
  184. can some help me with my axe
  185. spare parts
  186. Looking for detailed instructions
  187. Axe CP: I Wanna go brushless and need advice.
  188. Motor Runs Backwards on MX400PRO and 7CAP?
  189. AXE CP Quality Control FYI
  190. are there other blade grips for the AXE CP?
  191. Axe spins wildly with gyro active
  192. Noob ALERT!!! Axe CP Tail Rotor Arming
  193. MX 450 XS or Blade 400
  194. Axe CP Screw?
  195. Tail Motor Mount/Replacement or alternative??
  196. MX 400 vs the CP Pro?
  197. Axe Cp E-Board/power loss/settings
  198. AXE CP - glitching ?
  199. Balancing Main Blades
  200. Axe CP further out of whack
  201. Heli-Max Axe Ez....Please Read everyone
  202. help with locktight
  203. Position of Futaba Gyro 240 on AXE CP
  204. Axe EZ Tx ?
  205. need help with esc, receiver
  206. Axe EZ Upgrades. (worth it?)
  207. How to ruin a great day
  208. AXE CP Tail Motor Options
  209. rce-550 HH gyro
  210. MX400Pro flight recorder data & motor temps
  211. Tail Wag on AXE CP with Gyro 240
  212. New Axe CP Owner
  213. Modifying axe w/ larger rotors, boom, and BL
  214. New Main Motor & ESC for AXE CP
  215. selling axe
  216. GYRO POSITION ON HELI-MAX MX400 PRO?
  217. Controller Sensitivity
  218. LiPo Battery
  219. AXE CP main motor glitch as I touch blades
  220. Anyone tried the LiMn batteries from Duralite??
  221. need the wiring pattern for the AxeCP
  222. mx450xs question
  223. Help me get my Heli-Max 450 off the ground!!
  224. For those using a 7CHP with their AXE
  225. Did a Scary, bad, funny.
  226. axe cp picth
  227. Flybar Paddle Wrong Fit Help
  228. Lipo for AXE CP Please
  229. Chuck out that 3in1 on the AXE CP
  230. Axe CP Tail motor
  231. Aluminum Skid Supports
  232. AXE CP Getting Better All The Time
  233. Tail Motor ?
  234. Axe CP Transmitter
  235. CNC Bell-Hiller
  236. Axe EZ questions for the experts
  237. Flybar loose?
  238. Will the Great Planes C-25 ESC work on Axe CP?
  239. Everybody just stop right now..!
  240. Need help diagnosing Axe CP
  241. Help!!! I need help setting up a MX 400 Pro
  242. Servo Horn position Help
  243. MX 400
  244. Falling Axe CP
  245. Scale AXE CP?
  246. New LiOn batteries hold 10 times the charge of current batteries!
  247. 3n1 board bypassing
  248. Can anyone help? MX400 Pro and Futaba 7CAP???
  249. Calculating head speed in mph
  250. how much should my blades pitch?
