PDA
View Full Version : Helimax
Pages : 1 2 3 4 [5] 6 7
  1. Pitch question
  2. Helimax AXE Cp Radio use with PC Sims
  3. Tracking mx 400 pro help!
  4. LiPo question
  5. Main Rotor Gear Wobbly
  6. Additional wheel collers on the flybar
  7. Does HeliMax still sell the HeliMax HEADING-HOLD PIEZO GYRO?
  8. Blade tracking and adjustment questions
  9. MX 400 Blade Survey
  10. My vacation
  11. will a t-rex main shaft fit my MX400
  12. MX 400 / Phoenix 35A ESC / ???
  13. MAH 315's where to purchase ?
  14. Gyro, Tail Motor Question
  15. MX 400 expo question
  16. Desperate Times, call for Desperate Measures...
  17. Balancing Blades Question
  18. Getting an Axe CP
  19. 3in1 Meltdown?!
  20. The For / Aft Bobble (again) cause
  21. It is with great sadness
  22. Go Brushless Motor question
  23. axe cp help cylic off
  24. My MX400 First Hover , How did it Go ???
  25. part advice needed please mx400
  26. Electrifly brushless
  27. axe cp question
  28. Ducted Fan on the Axe CP Help!!!
  29. Fried LiPo anyone????
  30. FMS sim and ThreeDee practice
  31. MX400 /30A RC expert ESC
  32. OUCH...AXE vs EARTH
  33. Is it necessary... (mx400 )
  34. FlyCamOne
  35. MX450 or TREX-450?
  36. MX 400 tail upgrade
  37. Theory on 3-1 Bias adjustment
  38. GY240 Upgrade // 2 beeps from motor // No initialize
  39. Is It Just Me ?
  40. Where to find info to bring everything into "spec"?
  41. E-Board
  42. I've come to the dark side
  43. I've fried something
  44. Swapping out the z-bend linkages
  45. Roto Fly skid mod
  46. any one use the trainer function?
  47. What causes LiPo packs to swell?
  48. Carbon Tail Boom and Blades ?
  49. Axe CP tail rotor dying?
  50. Great rudder/ tail fix MX 400 Pro.
  51. Longer tail boom opinion needed MX 400
  52. Axe CP, brushless, opinions
  53. Axe CP vs Realflight G3.5
  54. which size lipo's for axe cp
  55. Wiring issues with separate ESCs
  56. 6EX 2.4GHz (Axe Question)
  57. HELI-MAXE AXE CP E-BOARD ADJUSTMENT PROBLEM
  58. Longer blades with stock tail?
  59. Which blades?
  60. Stock woodies
  61. SAB blades
  62. RX antannae routing advice
  63. RX antannae length
  64. MX 400 Pro (stock) rudder question
  65. Not Yaw but fore and aft bobble
  66. Yaw
  67. Hooking the HeliMax radio to a PC
  68. MX 400 Pro Tail shaft
  69. Why does a dual rotor heli need a tail?
  70. Worst crash yet.
  71. Tail fin question
  72. got a question - learning to fly the nose!
  73. First 'controlled' hover
  74. MX Pro Blade Grip "O" ring ?
  75. Is my new LiPo toast?
  76. MX Pro seesaw ?
  77. Servo Question?
  78. Battery agaisnt main motor any cures
  79. Tail boom mount for AXE-CP
  80. twisted
  81. AXE-CP BATT Charge Question
  82. tail motor gear mesh issue
  83. Realflight and Axe CP
  84. Axe CP
  85. Avoiding blade strikes with an EZ??
  86. My usename has changed from tmmatheny to mmatheny
  87. Bummer - screw holes stripped on tail boom clamp
  88. What else will be damaged? Axe cp
  89. Jacks on the 3n1
  90. GY240 or GY401??
  91. Fighting the gyro???
  92. Heli-Max 12Pole versus 6 Pole
  93. Right thumb cramp!
  94. Stupid Axe CP tail question that I couldn't find the answer to...
  95. Pinion change - headspeed question
  96. Axe Cp collective the wrong way???
  97. MX Pro pinion ?
  98. Axe EZ Motor Problems
  99. Axe CP setup guide
  100. MX Pro cutting off
  101. Volt meter
  102. Axe CP Beginner
  103. Problems with e-Sky Head Lock Gyro
  104. New Axe CP..Lemon or is this it ?
  105. I am back.
  106. New Tailmotor (untapped holes)!
  107. just bought an axe cp! what to do first??
  108. Man, am I lucky!!
  109. switch for AXE CP
  110. Changing AX CP REC
  111. Tail Motor Question
  112. Futaba radio for heli AND fixed wing
  113. Terminology please
  114. lights!! oh yeah!!!
  115. AXE Main Shaft and bushing ?
  116. tail control
  117. what the? Axe CP jumping in the air!
  118. AXE EZ battery discharge level
  119. axe cp lipo question
  120. lipo charger/battery
  121. cheap esc
  122. Main gear replacement - do I need to adjust mesh?
  123. Trim question
  124. Anyone seen this? Vulcan 450 SE
  125. why bigger rotors?
  126. HELP! sticks are reversed...
  127. Real Flight G3.5?
  128. 3in1 question
  129. Uncontrolable tail
  130. Battery question
  131. Futaba 6Xa with Axe CP
  132. Move over AxeCP..... Hello Blade 400
  133. can you grab your CP and trace some wires?
  134. Tail Rotor??? question?
  135. Full Throttle-No Flight
  136. Axe Cp RTF tail rotor surge?!!!
  137. Setting up Futaba 7CAP for Axe CP
  138. A cheap and Simple Axe CP antenna mod
  139. Axe cp Flying in wind
  140. heli max axe cheapest gyro
  141. Axe CP vs. Blade CP part numbers
  142. Skid Support Question! Please Help
  143. Charging questions
  144. Charging questions
  145. Not a good day. Advice?
  146. Update On My Axe CP - Signal Problem
  147. Axe CP Bell/Hiller conversion How-To
  148. AXE CP-> Blade CP Bell/Hillard conversion
  149. check out the new Blade 400.
  150. brushless motor?
  151. Great Flight
  152. MX400 Pro Step-by-Step Instructions?
  153. AXE CP Drifts left
  154. Axe glitch and range test
  155. MX400 Tail Control Problem
  156. servo adjustments and pinion gear mesh
  157. 2 Questions re: Tx and Lipo Batteries
  158. Axe CP Blitzes the Neighborhood (Video)
  159. Best Lipo for Axe CP
  160. MX400PRO Test Flight NOT Good
  161. LiPo Ballancer
  162. Replacement Parts Kit
  163. Tail Motor Wiring on Axe CCP
  164. How do I get pitch set on mx400
  165. AXE cp, blade pitch, tracking
  166. mx400pro aluminum upgrades
  167. Axe CP vs Blade CP
  168. what channels do the servos plug into?
  169. Receiver battery not required?
  170. Axe CP tough litttle helie!
  171. Where to mount a 2100mah lipo?
  172. MX400 Owners in Atlanta??
  173. tail rotor misbehaving
  174. Tail boom twister
  175. Carbon vs metal
  176. Yep, I'm a newbie!
  177. Charger/balancer questions? (recommended)
  178. battery and charger suggestion
  179. Help me help me Help me -P-L-E-A-S-E-
  180. Governor TailRotor
  181. MX 400 pro,short flight times
  182. confused about the gyro
  183. Rotation...
  184. OOOWWWWW!!!!!
  185. AXE CP Bounces Up and Down
  186. Tired of my Axe CP
  187. Looking to purchase my first RC heli...
  188. gy-400 gyro and the Axe CP with stock radio
  189. 3n1 adjustments?
  190. Finally...Yahoo
  191. Axe CP -- first upgrades
  192. Axe CP
  193. axe vibrating in flight
  194. Which is better a rate gyro or heading hold for beginners?
  195. AXE CP Help............Please
  196. Head speed and stability issues
  197. Straighten out a bent Main Rotor Shaft
  198. Getting into R/C heli flight
  199. Most stupid question ever
  200. Scale body for mx400pro
  201. Axe EZ, is it normal ?
  202. battery question?
  203. what shoul I upgrade?
  204. Hitec 55's: Tips?
  205. Which Way
  206. Axe EZ Moving Forward Problem
  207. How Do You Like Your Axe CP?
  208. Axe CP Pitch settings
  209. ball link binding
  210. Axe cp, takeoff and pitch
  211. Heli-Max AXE EZ adjustments
  212. Can the heli-max axe EZ handle a 11.1 volt li-po battery?
  213. axe cp both motor problem
  214. Axe CP Training DVD
  215. just got parts
  216. axe cp, issues and questions
  217. Inverted Flight
  218. axe cp spinning left HELP
  219. Hacker motor - any experience?
  220. How tight? part 2
  221. RX upgrade?
  222. How tight? (MX 400 question)
  223. Rotofly not hovering
  224. BL roto fly?
  225. Will my eflite Tx work with mx400
  226. Battery charging
  227. AXE EZ & Hitec Optic 6
  228. Great blades
  229. AXE CP Head Vibration Problems
  230. Upgrades
  231. IIIIIII gooooottttt iiiitttt finaaally!!!!!!!!!!
  232. Anyone want a Titanium main shaft!
  233. axe cp tail motor help
  234. Bearings?
  235. New AXE CP on the way!
  236. Help! Can't trim Axe EZ
  237. CG Question with new Lipo battery
  238. helimax cp rear rotor problem
  239. rudder spin at halft trottle
  240. heli maxx ez controller
  241. AXE CP scale fuselages
  242. Axe CP main rotor gear removal
  243. Blade balance, wow!
  244. rotofly bearings
  245. Super cheap blade balancer for AXE-EZ
  246. Heat shrink Off Better or worse??
  247. Throttle Trim
  248. Hitec Optic 6
  249. Jumping throttle
  250. Compatable AXE Products
