PDA
View Full Version : Helimax
Pages : [1] 2 3 4 5 6 7
  1. Is it worth Restoring
  2. I need discontinued/ unavailable AXE 400 Parts...
  3. I fried my 230si
  4. Problems with HELI-MAX AXE 2.4 ghz
  5. heli-max axe 2.4mhz tail motor
  6. Axe CP
  7. ec-145 slight vibration
  8. Problem Helimax Novus CX e board servos triming.
  9. Heli-Max AXE CP 2.4hrz
  10. heli-max AXE 100 cp newbie questions
  11. Older Axe CP helicopter help
  12. Binding issue ?
  13. Axe 100 cp rtf
  14. 230si Accessories
  15. old school axe cp radio upgrade
  16. Axe 100 SS whos familiar with "Tags" setup
  17. Help please EC145 does not work
  18. Axe CPV3 belt tail conversion.
  19. Helimax AXE 100 SSL
  20. Heli Max Ec145 channels reversed with anylink!
  21. Blade 450 3D Help Please
  22. Axe CP 100 Servo & Linkage Adjustment
  23. Novus 200 brushless main motor
  24. axe cp 2.4 main blades
  25. 1sq Issue
  26. 100 CP Rudder input cuases heli to Drift
  27. Problem with new helimax axe 100 cp
  28. MD 530 Tx-R wont bind
  29. Heli-Max Axe 100 CP/ Futaba T6EX settings
  30. 1SQ Quad with a TX610 Radio problem
  31. Helimax cutting out
  32. using an ESC from a Helimax with radio for an airplane?
  33. FP 200 Servo Arms ?
  34. Axe 400 head assembly problem??
  35. Heli-Max Axe 100CP Tail Boom!
  36. novus cp rotate to the left like crazy
  37. help with Axe cp
  38. Novus 200 fp heli input?
  39. need help with axe cpv3
  40. novus 125 FP tail wagging?
  41. Larger battery bigger ESC??
  42. axe cpv3 battery?
  43. From FP to CP
  44. axe cp doesn't work!
  45. Heli-Max AXE CP burnt eboard, receiver???
  46. Axe CP 2.4 - 2 questions
  47. Novus CP - can control the tail rotor with trim but not stick!
  48. Axe CX canopy replacement
  49. Will these metal head/ tail kits work on my axe 400
  50. Helimax mx 400 no tail control
  51. Would this work? (Electronics questions)
  52. Need some help from an electronics Guru
  53. novas 125 fp no lift
  54. Helimax AXE EZ Upgrades
  55. Novus 125 CP/Walkera 4g6s Spindle Screw Size
  56. novus fp not enough lift
  57. novus 125 cp: my first heli ever!!!:( help me!
  58. Hosed myself on Ebay purchase?
  59. novus cp upgrades??
  60. Helimax Axe ez take apart.
  61. novus 125 fp issue. please help
  62. What are these knobs for on the CP Nano Transmitter
  63. Help, Axe CPv3 not working
  64. Novus FP N125 Issue. Please Help
  65. Axe CP/Alpha 400 motor
  66. Novus Cp upgrade??? 125?
  67. Rough spool-up/down - Novus CP
  68. fp125 spins in circles befor, and after takeoff
  69. lipo charger
  70. 125 FP training Gear
  71. heli max novus cp will not bind
  72. Axe 400 3D - Setup for beginners
  73. Axe CP gyro install
  74. nouvus 125 fp
  75. Heli-Max Novus 125 FP fail safe
  76. Need a Gyro for my AXE 400...
  77. NOVUIS 125 fp Charger qestion
  78. Axe CPv3 electronic failure???
  79. Axe CPV3 tail rotor replacement??
  80. AXE CP V3 set up
  81. Time to get back in the game!
  82. Axe 400 programming 7cap
  83. Axe 400 with jr 9503
  84. Axe CP and Futaba 6exp
  85. heli max 450 for a proto max micro.
  86. Heli-Max Novus CP
  87. Learning to fly with 125 fp
  88. Novus CX?
  89. Novus CP N125 sub-micro?
  90. Novus CX, Walkera Lama2?
  91. heli-max novus 125 cp up-graded head
  92. Rototing the Rotarywing
  93. Axe 400 Tail rotor Problem
  94. novus cp lipo???????
  95. mx450 battery tray.
  96. Novus CP can't lift off
  97. Axe 400 troubles
  98. Novus FP tail became twitchy..motor or gyro?
  99. axe cp v3 tail pulses
  100. cpv3 questions
  101. Quick Novus CP question, hope someone can help
  102. HELP!!
  103. novus cx performace upgrades
  104. Novus FP tuning
  105. heli Max 125 cp head replacment
  106. In the name of all NOVUS CX owners
  107. Noob Question on CP 125 Transmitter
  108. novus 125 cp exponential
  109. Novus FP N125 - digital servo question
  110. helimax mx 400 pro
  111. ??Help me make my decision??
  112. Brushed motor break-in
  113. Need charger for Axe CX Micro (or similar)
  114. WALKERA WK-2801PRO 2.4GHz Transmitter compatibility Question
  115. Novus CX will not bind
  116. Novus 125 CP vs Walkera 4G6 ...
  117. coax up-grades
  118. Selling my cpv3
  119. Done with the junk cpv3 going to spend the money get one that is worth ir
  120. axe 400 will cpv3 cnc parts fit it?
  121. Helimax CPV3 flybar
  122. Just installed GWS Tail motor and spins like crazy
  123. Anyone done away with stock tail motor on cpv3?
  124. help with novus cx
  125. axe cpv3 phoenix sim
  126. Novus CP a few questions
  127. Is the Novus CP Nano any good??
  128. Bought the AH-1J Sea Cobra....help.
  129. ar6100e in cpv3 lost where wires go
  130. xe CPv3goesfull throttle
  131. anyone interested in a cpv3
  132. settings for dx6i with cpv3
  133. gyro help hm4000 and c-12 cpv3
  134. Can some one explain how to wire a hm4000 and gyro.
  135. Axe CP Flight Issues
  136. axe cpv3 better battery and upgrades
  137. Novus CX main blades/batts & Charger F/S F/T
  138. Novus CP Noob Pitch help.
  139. tail boom removal on CPV3
  140. Helimax Axe CP Tail Motor Brushless
  141. New receiver in Axe CPv3
  142. radio setup dx6i for axe400
  143. mx400 main gear
  144. CX axe micro
  145. Retireing cpv3, cp pro2 or honey bee king3
  146. hk401b on cpv3 install
  147. Eflie 110 gyro on cpv3 ?
  148. GY 520 in an AXE CP??
  149. cpv3 tail motor question
  150. Novus FP - Cant Hover
  151. Axe 400 RxR Adjustments/Setup
  152. Novus CX
  153. Novus CP out of the box????
  154. GYRO?
  155. It's ALIVE!
  156. AXE 400
  157. New Rotofly help.
  158. Axe CPv3 Tail Motor Problems..Please Help!
  159. cx micro not moving forward outdoors
  160. Novus CX
  161. Axe CPv3 Gyro upgrade
  162. my cp-l tail motor will not work
  163. Heli Max Novus CX... should I upgrade?
  164. Helimax Novus CP Upgrades Thread
  165. Helimax Axe CPv3
  166. axe CPv3 tail motor problems
  167. Can I buy a Novus FP by itself?
  168. Novus CP Spektrum
  169. Novus CX is loosing power
  170. Swash Plate
  171. Novus CX vs FP
  172. axe cx mirco fore/aft servo seizure
  173. Novus CX - Unreliable?
  174. New Novus CX - Lower Rotor Won't Respond
  175. axe cx???
  176. Mx450Sx Battery upgarde
  177. HeliMax MX450 SX, Spinning outta control!
  178. Axe 400 Piro Rate
  179. Axe CP NiMh battery troubles
  180. Axe 400 RTF Tail Rotor Failure First Flight
  181. AXE EZ will not climb
  182. AXE CPv3 - Fixed Pitch???
  183. 3 in 1
  184. Novus & walkera
  185. Novus CP Dies on Spool up
  186. Issue removing blade grips
  187. Factory Pitch/Throttle curves Axe Cp
  188. Novus CP RX will not bind with TX
  189. cpv3 lipo for sale
  190. XtremeLink
  191. Sluggish control for FP
  192. Pulsing Motor Help
  193. Reciever conversion AXE cp.
  194. Axe CX Micro 3 in 1
  195. Happy with Heli-Max service today!
  196. Axe Cp Part Needed
  197. Novus FP Death Wobble at 3-4' Off Ground
  198. Heli Connection Fails Mid Flight
  199. Novus CX will not bind
  200. hovering a novus cp
  201. New Rotofly - Charger LED didnt go red :(
  202. AXE 400 3D
  203. New 3in1- NO CLUE HOW TO HOOK IT UP
  204. Settings for novus cp
  205. Heli-max axe ez problem with steering
  206. brushless tail from wow?
  207. belt wear
  208. Need help with Axe 400 fast.
  209. Helimax MX 450 XS SLIDER PROBLEM!!
  210. Got this cp in a trade.. HELP!!
  211. CP3V Motor and electronics upgrade
  212. Cheap 3-1 for CPV3
  213. Best Heli for long term use
  214. cpv3 pinion
  215. Happy to be airborne again!!!!
  216. cx micro spinning to the left
  217. i need links measurement for helimax mx450 xs
  218. Nervous twitch?
  219. will 4#3b brushless tail conversion work on novus fp?
  220. Brushless main on CPv3
  221. Helimax 2.4 ghz tech vs. Spektrum 2.4 ghz dsm2
  222. Axe CX Micro won't lift off
  223. Novus cp brushless
  224. 3n1 not shot on AXE CP
  225. AXE CP possible 3n1 shot?
  226. Axe CPV3 doesn't lift off
  227. Novus CP Servo Question
  228. novus cp bad tail motor ???
  229. Tail Dead on Axe CPv3-Replaced motor and still dead!
  230. Tail Rotor Popping OFF!!!!!!!
  231. transmitter problems with axe cx micro
  232. Pitch Adjust?
  233. Novus CP tail problem
  234. bought a cpv3 today! does a gyro really help?
  235. heli max fp out of control
  236. going brushless axe cpv3
  237. newb Novus CX
  238. Programming Futaba 6EX for an Axe 400
  239. axe 400 got hot
  240. Axe CPV3- What you wished you knew when you got yours.
  241. novus cp tail boom
  242. Novus cp tail rotor issues
  243. Novus CP Help please
  244. Gain adjustment question from frustrated Novus CX newb...
  245. heli-max axe 400 gyro problem
  246. Novus CX Question
  247. CPv3 3in1 Confussion
  248. Novus Cp Problems/Plz Help!
  249. idle up
  250. 400 3d servos
