PDA
View Full Version : Ask the Expert Sal - Electric Airplane Advice
  1. Disconnecting red power wire from ESC Q
  2. Tech specks -advice for motor
  3. flight time.
  4. .Motor/speed control shutting down....
  5. Senior Telemaster conversion
  6. 2814 vs 2836 Electric Motor
  7. receiver
  8. battery balancer plug incorrect
  9. Batter/ESC compatibility
  10. Tactic 650X flaperons
  11. replacing a spektrum receiver on a t28 with a Futaba receiver
  12. Looking for specs: Xtra 2826/12 outrunner motor
  13. Given a tactic TTX403 transmitter, what can I use it with?
  14. I don't know whats causing this
  15. Snap ring pliers
  16. If closed, why not remove it?
  17. Opto esc red wire
  18. 2 blade to 3 blade
  19. advice needed
  20. Advice needed re:setting up the innards for secure flying.
  21. Do not post in this forum - this is an inactive forum
  22. Do not post in this forum - no one will respond to your post
  23. Hacker X-70-SB -Pro and Futaba SB rx
  24. Do not post in this forum - this forum is inactive
  25. equivilent inrunner 3-4 cell for .25 nitro airplane
  26. dx8 and leader 480
  27. grinding noise in outrunner at mid rpm
  28. Thrust tester
  29. 5mm Reverse Thread Prop Adapter?
  30. futaba 617 rx
  31. AS3X Beast no rudder servo operation
  32. Need help picking a replacement motor.
  33. electric jumps to full throttle
  34. Kadet EP-42 upgrade advice
  35. Thrust?
  36. Need some prop guidance
  37. BL Outrunner for Electron 400A
  38. Mini Funtana by E-Flite
  39. Help with Xtra 2826/09
  40. Electric free flight Guillows P-40 set up
  41. learn how the fly a jet!
  42. ubecs
  43. Set up for a Race Rat
  44. help selecting ele. motors
  45. Cessna 337 Skymaster/OV-10 Bronco
  46. Brushless set-up 2610 combat
  47. Reviving an old bird
  48. wireing balance plugs
  49. Ultrafly Bae Hawk
  50. Christen Eagle struggle to turn right
  51. motor won't turn anymore?
  52. Brushless ESC switch or no
  53. Nicad to Li Po conversion
  54. Old falcon 56 conversion
  55. Question about ESC
  56. Cooling mods.
  57. Need to know
  58. Want to go vertical
  59. Issue with new Funtana setup
  60. Decathalon to Electric
  61. servo setup for canards
  62. Yet another new to electrics
  63. Fliton Prodigy with E-Flite 450
  64. Aerobatic control problems.
  65. Need simple project for GWS 350B
  66. H9 Spitfire /ESC & Switch question
  67. Transmitter not sending full throttle
  68. recommend plane,brushless motor,lipo
  69. Li-pos in Parallel
  70. VOLTS Ignorance
  71. best TIMING for the 2W20 ?
  72. Choice of motor and esc for experiment
  73. 2408-21T motor and ESC Problems
  74. Castle Creations Berg Receiver Issue - Help!
  75. motor madness!
  76. multiplex twinstar
  77. Blown motors
  78. electricstar jitters
  79. NES Wendy Brushless Setup?
  80. GP learjet con to twin ducted fan brushless
  81. a Wing and a prayer
  82. ESC troubleshooting - ALIGN ESC RCE-BL35x
  83. Glitching, as related to speed controllers.
  84. JR 66 Radio & Flaperons
  85. Power setup sanity check
  86. What makes e-props different?
  87. Will this work?
  88. Crystal information needed
  89. LiPo batteries
  90. 1/4 scale P40
  91. What plane can use this stuff?
  92. End Point Setting?
  93. power on a minimag
  94. Super Cub Engine sputter
  95. VT Belle
  96. Electric setup for HoB 2x4?
  97. Charger questions?
  98. DagoRed Street-Racer
  99. Brushless power for Porterfield
  100. Sal- Can you help with this?
  101. Storm Launcher spare parts.
  102. Hobby Lobby all-in-one combo question
  103. Electrifly Lancair Setup
  104. 3 blade prop
  105. Radio crystals
  106. Loose Magnets
  107. Double Trouble on a twin
  108. GEARBOX W/ BRUSHLESS OUTRUNNER
  109. Where's Sal?
  110. B 29 build
  111. Basis questions?
  112. twin motor amp draw???
  113. voltage for a charger
  114. What can I do with this little motor??
  115. raidentech cessna 337 25 size
  116. Firebat build
  117. First elecrtric sailplane
  118. 81" OV-10 Bronco ARF/Hobby Hanger
  119. Brushless Motor Stutter
  120. Electric PBF (Flying pizza box)
  121. NEED HELP PICKING POWER TRAIN
  122. Hotliners - What to look for
  123. going brushless
  124. Dead Renny???
  125. jump to brushless
  126. New to Electrics
  127. CG info.
  128. MOTOR INFO
  129. Help with conversions, motor and battery selection
  130. Filip 400RG
  131. cermark Islander conversion
  132. Li-Po help
  133. HET rc KI61 power suggestions
  134. What do you have to do to make a brushless twin?
  135. some e-conversion questions
  136. help my battery started smoking
  137. Finally.
  138. LiPO Cell Definition
  139. microjet trim
  140. New ESC
  141. GWS C 47
  142. Sal {center of gravity machine}
  143. Center of Gravity Machine
  144. Speed 400 to brushless conversion?
  145. Toledo Show
  146. engins shutting down
  147. Lipo charging/wiring
  148. Balance tabs for LiPo
  149. "Forming" a pack....how do you do it?
  150. nose dive first test - zagi
  151. E props Vs Glow props
  152. Cycling a Li-po?
  153. Hacker 20-22L on 2 Cell Lipo
  154. Little blue foamy
  155. NSP Merlin
  156. OV-10 Bronco Motor Setup
  157. Surging
  158. FuntanaX 50
  159. Motor Amperage
  160. HOW DOES THIS FORUM WORK? Read this before posting!
  161. How to- big electric conversions
  162. FUNTANNA E-CONVERSION
  163. E-Flite J-3 Cub 25
  164. What plane(s) would be a good fit for my Nippy?
  165. Will brushless reduce Current?
  166. Motor troubles
  167. SR71 blackbird
  168. Dual edf?...
  169. Help with Motor and ESC selection
  170. Sal from northeast Audio Interview. Listen to it now
  171. Kyosho Flip 3D
  172. Next Plane
  173. HELP...Motor/speed control shutting down....
  174. GWS Tiger Moth brushless conversion
  175. Trim Help ?
  176. Ferrite Beads
  177. Electric power systems
  178. Carbon fuselage and reception
  179. propellers
  180. Best LiPo Charger
  181. H9 30% Extra w/3W100...Need Mufflers?
  182. LI-PO Ballancing
  183. Combat Models A-10
  184. "Push me - pull you props on one motor?
  185. Electric = .46AX?
  186. Moving up, next plane?
  187. Mystery 80A ESC programming
  188. E conversion help
  189. Welcome Sal!
