- Weatronic Bat60
- fly sky fsi6 programing
- Wanted Weatronic JR modules and RX's
- Bat 60/Giga control
- Looking for Clever 6 or Smart 8 receivers
- Still safe to invest in a Weatronic radio?
- What to consider when buying a used BAT transmitter?
- Problems with bluetooth between my Weatronic DV4 and iPad!?
- Bluetooth Audio?
- BAT 64 Lock Out
- Micro 12, almost impossible to connect to all outputs!?
- Weatronic failsafe detection?
- Slave/sub receiver with DV4 transmitter module?
- Service and Support in USA
- Does BAT 60 support Mux Box?
- BAT 60 Programming Workshop
- BAT60 trainer mode
- Timers and virtual switches
- Do I have a bad cell?
- Selling up ,, furs a 14 my with weatronic and receivers mist unused. uK
- What is the SUM Signal?
- Bat 64
- Weatronic Rx for sale
- Airspeed calibration
- Airspeed warnings
- Weatronic Telemetry Protocol API
- Bat 60: Switches
- Jens: Pending questions
- Hello
- Soldered Weatronics leads
- Sky navi
- JR 12X using Weatronic module
- Upgrading receivers
- stabilators with flaperons - help?
- Who is in charge of this forum?
- Display error of voltage values in GigaControl 2.63?
- Model image in Rx
- Retracts and covers
- New WEATRONIC Transmitters (Transceivers)
- Weatronic and long servo leads
- Servo deflection at start-up
- MIcro Receiver Gyros
- Weatronic patch leads
- Flashing Codes
- English Voice File for Weatronic available
- Micro 12 servo ports?
- British flag gone AWOL
- no stock to sell?
- Micro8 2.03
- Converting a JR 12X to use the Weatronic Module
- Transmitter Modules for Futaba
- 12-22R Problem
- Weatronic jr module issues
- Weatronic Seminar at Toledo 4-6
- Is there any plan to.......
- Weatronics is Back in the USA
- Help with Futaba 12Z &Wea combo
- CAN YOU BIND 2 MICRO RECEIVERS?
- Weatronic 35MHz
- weatronic vario unit+sensors ?
- Patchantenne 2,4 GHZ.
- Need help with exi 500 build
- Does Weatronic still exist?
- Giga Control
- Weatronic DV4BT (Bluetooth) Android APP
- gigacontrol
- 14mz and weatronic module fore sale
- Good and bad news 14mz and Weatronic
- WEATRONIC
- Weatronic and the 14MZ
- new fw v2.61 DV4
- Version für Das Sendemodul DV4?
- Weatronic Comments on other Threads
- Wea Data Unreliable. Warning
- NEW FW v2.59 out now
- dv4 temperatur
- FATAL CONTACT/CABEL FAULT
- Weatronic 12-22R and A123 Batteries
- Weatronic MUX-Box (SCU Sensor Interface) available
- GIGASOFT COMPATIBILITY
- Weatronic and Graupner??????
- MC22 switch adapter
- my Wea experience ..
- Quick bind issues
- Programming Weatronic 12/30 Gyro III-Gps?
- Weatronic Transmitter
- Log Files
- Firmware Update V2.30
- Programming
- shift of neutral???
- English version of GigaControl
- Normal Dbm readings?
- Weatronics Webshop
- 9CAP, which weatronic package do I get
- Futaba 12FG and Weatronic 2,4 dual FHSS problem
- Will Weat work with new DSMX radio?
- Wea Problem
- Weatronic Rx range warning
- delete
- Futaba 9Z
- 10-22R Software
- Giga control on an iMac
- Weatronic Voice files/error messages
- Weatronics gear sequencer
- GigaControl/ DR 2.4 12-22. connection problem
- Giga Control Country
- Weatronic Clever?
- Multiplex users
- Updates
- Telemetry EN voice file availability ?
- Installing Weatronic 2.4GHz in a FX-40 transmitter
- Gigacontrol Transmitter config
- Spektrum V/S Weatronics
- Help please
- Firmware updates
- Weatronics GPS and gyros
- DR 2.4 12-30 R GyroIII GPS Questions
- Gig Software
- Weatronic 2,4 6 ch RX
- JR 10X & 12X compatability
- Rx Pack voltage readings in GigaControl
- Software Update Version V 2.30
- Nav files are dated 31. dec. 2097
- Weatronic founder Axel Westphal passed away
- Sleep mode
- CE Compliance in the UK
- Telemetry data on MC 22 display
- Error message
- More operational experience of the 2.4 system.
- Log files problem
- nav view problem
- Purchase Help needed...
- Futaba 14 mz and weatronic
- JR RADIO
- Configuring Gigacontrol
- 12FG Flaps
- MPX Royal pro support
- Weatronic Jr 10x module mounting
- PPM or PCM for 2.4
- Convert to 2.4
- Micro with PowerBox?
- Multiprop support on the new 2.4GHz receivers
- FCC Certification
- System not working.
- Trying to buy Weatronics 2.4 combo.
- Failsafe
- usb drivers
- Servo travel v/s Tx don't match
- current measurement
- Confim Antenna #?
- Really dumb restriction ?
- Trying to get a response from Weatronics on repair of unit
- Weatronic and Futaba MPDX
- Setup Problems.. PLEASE HELP!
- Travel adjust question
- weatronic 2.4 Dual FHSS RC systems launched
- Battery Swapping question
- Red switch board led flash frequency
- Amperage draw, servo synching, and data collection
- Weatronic & Duralite
- Servo % range
- 2.4 - when are you comming out?
- Struggling to get anything but red blinking led
- GPS upgradability possible?
- Idle Current?
- Weatronics many problems
- PPM Failsafe
- 6V NICD Battery for Weatronic?
- Almost lost my setups...
- External Gyro causing servo pulsing
- Holiday and AMA 2008 show special
- Jitter with hitec 5955 servo
- A123's
- New Software and Video link
- No Data being read from Weatronics Unit
- Sequencer & Tamjets air failsafe
- SD card question
- Antenna Selection Vs RSSI
- Can I mix battery types?
- Servo Synch
- Sequencing in Weatronic Dual Receiver
- Windows 2000?
- Welcome Weatronic's
