PDA
View Full Version : Airtronics Support Forum
Pages : [1] 2
  1. Battery polarity
  2. Airtronics Zenith Manual
  3. Vision PCM 8SP
  4. airtronics
  5. Airtronics wiring.
  6. rds 8000 and SD 6G tx problem?
  7. SD-6G buddy-box slave to a RDS-8000
  8. sd-6g range problem?
  9. RD 8000 Throttle Curve
  10. Throttle Cut on Airtronics RD8000
  11. SD10G transfer question
  12. Issues when Aux Servo added to RX-442FS
  13. Airtronics spare parts
  14. Airtronics Championship Single Stick "CONFUSED"
  15. RDS8000 shows "ID_UP" on screen, no response
  16. ID Older Equipment
  17. airtronics rd 8000 glitch short time out air rec used
  18. calibrate the gimbals
  19. airtronics transmitter low voltage alarm change
  20. Airtronics Transmitter needs Repair. Airtronics.net no longer works
  21. SD 10d Aileron Stick broken
  22. Airtronics M12, Compatibility with Airtronics Rx's
  23. Reprogram radios from mode 1 to mode 2, and mode 2 to mode 1 help here.
  24. Airtronics SD10 making strange noise
  25. Airtronics Delta wing mixing
  26. I need a small, quiet servo, a small receiver, and a small radio
  27. infinity battery pack ? silver rectangle?
  28. Sd-10g oem charger
  29. RDS-8000 Switching back from mode 1 to mode 2
  30. Airtronics 94809 get extremely hot on the bench
  31. Airtronics Trainner cord?
  32. Sd-10g set up conditions
  33. need airtronics service info.
  34. Airtronics crystal question, transmitter repair question.
  35. 10G question on glider motor switch set up
  36. Airtronics switch setup question?
  37. Airtronics MT-4 installed in Redcat Lighting - no reverse
  38. Airtronics Service Question
  39. Rx-371 with Mt4 shows only 2 channels
  40. *SD-10G Antenna orientation*
  41. *Kill switch Setup On SD-10G*
  42. Kudos to Airtronics service
  43. 92104 10 channel receiver voltage?
  44. *92824 Receiver & HV Servos*
  45. Sanwa MT4 vs MX3X
  46. Is Airtronics going out of business...?
  47. RDS 8000 Transmitter Battery
  48. airtronics radios
  49. Glider Flaps SD 10G
  50. SD 10 G Issue with dual Ele. Servos
  51. Airtronics Service
  52. 10g for ALES
  53. LiFe for SD-10G
  54. 94761 and 94809 Max Voltage
  55. Dual batteries into a 92104 10ch receiver
  56. Old Airtronics Servo Compatability
  57. 2 Motors 1 Channell
  58. Airtronics repair info
  59. receivers for RDS8000
  60. An SD-10 criticism
  61. Channel Delay question
  62. Range check with SD-10G
  63. Can we expect a radio with more than 10 Ch soon?
  64. new 8 channel anytime soon?
  65. airtronics and gyro's
  66. lipo for SG-10
  67. SD10GS programming issue
  68. Airtronics RDS8000 Parts Help
  69. 5-channel receiver problems and new receivers?
  70. *Anodized Transmitter Stick*
  71. Airtronics Rx crystal question
  72. usb controler cable from transmitte vg600 to pc
  73. Airtronics 92164 rx
  74. Airtronics Aquila 6 ch
  75. UMMM..... Where have all the 92104 10ch recievers gone??
  76. Rd6000
  77. Airtronics 92965 receiver voltage requirements?
  78. Airtronics RDS 8000 Receiver Binding
  79. 10G w/10 channel Rx...RCXEL kill switch...problem
  80. *Airtronics SD-10G Battery Meter*
  81. Airtronics Servo spec
  82. RDS8000 wont bind with RX-500's
  83. reciever antenna
  84. RD8000 can't get out of HELI
  85. RD 6000 sport throttle and rudder
  86. Refresh my memory......
  87. SD10G servo saver???
  88. RDS8000Issue with electric retracts
  89. increase number of characters for SD10G model diplay
  90. VG6000 TX
  91. RDS8000 Transmitter gimbal wire failure?
  92. TWin throttles
  93. 10 channel Rx with analog servo's...
  94. nential
  95. vg 600 Dual rate? switches
  96. Digital Servos
  97. New servos
  98. trainer cable
  99. SD 10G or what?
  100. Module 7SP Flaps setup for power plane.
  101. Program SD-10G stopwatch
  102. Airtronics Receiver question...
  103. Airtronics (Sanwa) RX-61H RX running HV
  104. Vanguard 72MHZ signal strength
  105. Compatible RX for SD10G
  106. M11x fail safe
  107. SD-10G stick alignment
  108. Can i use a lipo 11.1v pack in my RDS8000?
  109. RD8000 replacement case?
  110. SD-10G Flap Setup
  111. I love my RDS8000
  112. Have flaps work as ailerons
  113. Servos jumping on power-up
  114. SD10G and EQ6 compatability question
  115. SD10G: Stick sensitivity as a mix?
  116. RDS8000 compatibility
  117. Serial Number ???
  118. Finish wearing off my SD-10G
  119. SD-10G making a buzzing noise
  120. Composite insulators overview
  121. Flight Modes and throttle trim
  122. power line insulators in model
  123. SD 10G Flight mode clarification
  124. SD-10G parts identification
  125. Has anyone used the SD-10G with RealFlight 6?
  126. Airtronics Service is the Greatest!
  127. 94403 servo spec????
  128. RDS 8000 question
  129. 10G problems
  130. Trying to get a RD6000 to work with a Vanguard VG4R
  131. airtronics vg4r
  132. Head tracking on SD-10g
  133. 94815 servos
  134. SD-10G broken switches
  135. Need help setting up Elevons on SD-10G
  136. RDS8000 Replacement switches
  137. Signal loss with SD10 G
  138. Range checking a RD8000
  139. Redundant Receivers
  140. SD-10G training with
  141. researching a new radio
  142. Need help. RD6000 Super PCM LOST???
  143. Buddy Box for RDS 8000
  144. Help with rds 8000
  145. Airtronics SD-10G TX and RX with Futaba digital and BLS servos??.
  146. No Representation
  147. MX-3X not scrolling
  148. 6.6v in an older 92824 Rx??
  149. Dynam t-28 retract problem
  150. Expo on new 10 G Tx
  151. SD10/Analog servo?
  152. sd-10g 2 servos per aileron surface c-mix does not work right past 100% throw
  153. Stylus - throttle channel issue
  154. Dual servos on elev
  155. 2.4 Conversion
  156. SD-10G Issue With TX Battery Voltage
  157. Air92744 antenna
  158. SD-10G firmware update request
  159. Cleaning the SD-10G Transmitter
  160. Programming a 3Way Switch on SD-10G
  161. Dual flap servos on a 6G system
  162. SD-6G Servo, Servo Monitor Indicator Movement, Interference Flicker
  163. Failsafe
  164. SD-10G Servo reversing under Flight Mode?
  165. SD-10G limit travel question
  166. RCEXL Opto Kill and Airtronics 92824 receiver issue
  167. Reciever Antenna
  168. dual aileron servos on sd-10
  169. SD-10G Programming
  170. SD-10G sailplane programming
  171. SD-6G Timer
  172. SD-10G & RX700 Range Check
  173. Competitive priced Airtronics 2.4GHz receivers ???
  174. CS SS Transmitter
  175. challenger 250
  176. SD-10G stick switches
  177. SS CS 7 Channel Transmitter
  178. SD-10G and 92224 Rx
  179. 94772's jittering in ailerons
  180. Need help with SD10G Throttle Control
  181. REPLACEMENT FOR RDS-8000 ?
  182. rd8000 setup questions
  183. 94141 servo connectors
  184. stylus status
  185. Temperature limits for Airtronics 2.4ghz receivers?
  186. vanguard receiver
  187. RDS 8000 problem
  188. stylus 2.4G module
  189. Radio Help
  190. Infinity Tx battery packs
  191. Quasar 6A Op Manual Needed
  192. LiFePo4 batteries in the SD10G
  193. SD10 Flap to Elevator mix problem
  194. RD 8000 Buddy Box Question
  195. JR&Airtronics Compatibility
  196. SD10-G DISPLAY
  197. Servo question
  198. SD-10G Super
  199. Mate two Channels
  200. Flap on throttle stick
  201. SD10-G Size?
  202. Antenna Length
  203. Trainer cords
  204. Trainer Cords
  205. RDS - 8000
  206. VS8SP manual
  207. Throttle Advance issue on one Model w/SD10G
  208. Electric Rotarywing
  209. Dual Servo Flap throw
  210. good service from airtronics
  211. SD6G whats in the box?
  212. SD-10G Antenna
  213. Momentary loss of down elevator RDS8000
  214. SD-6G Battery Charger Question
  215. Bind Light Blinking on 92824 Receivers..
  216. RDS8000 Programing to turn on LED lights
  217. SD10G Battery charger issue - again
  218. RD8000 programing
  219. SD10G BATTERY
  220. RD8000 transmitter problem
  221. Airtronics/Sanwa Heli Dual Rates Question
  222. Airtronics RD8000 Channel 34
  223. Pattern Servos
  224. MX-3
  225. 2 or 3 ch. FM recievers
  226. FHSS-3 Receivers
  227. sd10g transmiter question
  228. Dual Rate vs Flight Mode
  229. never mind I think I have figured out
  230. FHSS1, 2, 3 4, 5 ,6?????
  231. Screen goes black?
  232. Metal Arms for Airtronics Servos
  233. SD 10 Mixing problem!
  234. mixing elevons with variable wing geometry
  235. SD-10G Problem
  236. Free Sync SD-10G software ?
  237. SD10G Service Bullitin - Service
  238. Smoke Switch Question
  239. Analog retract servo
  240. ...........MX-3FG, adjust from 70/30 to 50/50? how??
  241. sd-6g receiver battery
  242. What happened to the Futaba module?
  243. Whitch Airtronics 2.4ghz reciever for 3D foamies?.
  244. Airtronics 2.4 reciver
  245. RDS 8000
  246. New SD-10G - Was it updated?
  247. SD-10 Owner bought an SD-6 but
  248. Stylus battery holder.....
  249. SD-6G Serial Number Location
  250. SD-10G Service Bulletin
