- Like to try Eclipse with Helis need advice
- HS-475BB and HS-545BB
- Mini digital servo
- Idle Up 'stuck' on Hi Tech Eclipse 7
- Training cord
- switch for challenger 720
- Hitec Eclipse 7 pcm upgrade
- HS-255MG Reversable?
- FM RF Decks - Upper and Lower Bands ??
- Focus - 6, radio sets.
- Is HS-55 servo strong enough for my plane?
- Eclipse bug or print mistake??
- Flash 5 W/Futaba 4VF, Trainer Cord
- Hey Mine :)
- Neon Single conversion FM rcvr. range
- HS 925 Servo for Heli ?
- Range check distances ?
- ? Mike
- Eclipse 7 transition
- servo reverse and travel extension
- Trouble with the HFP-10 programmer
- laser 6 trouble
- Hitec 225 strength...
- Hitec HS-101 servo specs?
- Flash 5x Problem
- Mike..please read
- 3d?????
- Hs-81
- Mike?
- GWS receiver with Eclipse7
- Vibration mounting needed for HS-55?
- ?? mike
- How are these?
- programing servos
- Setup problems!!
- voltage regulator
- HS-5625MG Problem
- tightening the neutral?
- Futaba buddy cord w. Eclipse????
- Flying Site Spacing/Radio Interference
- 5645's
- Early Eclipse 7?
- hitec focus 4 question
- Hitec digitals and voltage regulators
- New Eclipse
- hitec feather flight pack setup q
- Really strange problem.
- HiTec CG-335 charger acting funny
- Mike:
- "Whiney" digitals?
- Glitching Eclipse
- Failure rate of 56xx servos
- Dual Rate Problem on Hitec 5245 Mini Digi
- radio glitch
- Laser 6 & Eco Picc: How do I Mix the Tail?
- Eclipse 7 "Idle On" warning
- TX Battery cable
- New Servo Play HS81 mgs
- Crystal failure in flight
- Is the 5645 a coreless servo?
- Is the Hitec Eclipse 7 worth the money
- Help. Reversing a 425 servo
- M8 TX with Novak Switch
- Rf Noise Help!
- 5925 Question
- HPD-07RH Q-PCM Receiver and Spectra Module
- HITEC Laser - mHz change?
- HFP-10 Programmer Update
- crappy transmiter help
- Hitec Eclipse 7
- Crystals for AM DC Hitec Receivers
- Hitec CG-335 charger
- Prism 7 Mixing
- 5245 geartrain
- Eclipse problems still. Bad news?
- Transmitter stick extensions to suit Flash 5?
- Changing freq
- Digital Failsafe
- Programmer / Extensions
- Battery pack ?
- Flash 5x TX & Tower 3000 RX????
- Hitec Laser 6 Range
- New Radio Comparison
- noncentering 425BB
- Hs-805 Bb
- How often should servo gears be replaced?
- Slop in 605BB's
- HS-60 Side Brackets
- Antenna radiation pattern
- subtrim
- different wires on same servo
- Which Hitec Radio system for pilot training?
- Servos for glider's elevons
- Demolished
- What size battery
- RCD 3250 support
- Outstanding Customer Support!!!
- Hitec Micor 555
- Servo programmer
- Hitec HS 55 cable broken...
- Q-pcm
- Full house Glider with Eclipse and Electron
- Eclipse 7
- need charger and flight pack for focus 4 Tx
- JR servos & Hitec RX
- Questions About Laser 6
- 10 Channel Hitec Receiver?
- Question glitches and 6 volts
- New 5475's and 1/4 scale
- 555 plug hiarchy
- Recommended servos
- 5735 aluminum arm screw holes?
- 605
- 5735 Made March 02, Need Update?
- Gear EPA?
- Very Unhappy with Flash 5
- Feedback from Servos-interference
- Tx Low voltage indicator
- JR receiver frequency-synthesizing system
- Eclipse 7
- Hitec Micro 555 Newbie Setup Question
- Flash 5x
- Need an Honest answer
- Hitech 555 problems ????
- 6 volt systems
- Programmer problem/question
- Spectra module...Eclipse 7 ??
- Eclipse Dual Elevator Servos
- Mike and Y Harness
- hitec servo wire gauge ??
- Hitec Flash 5 "System X help?????
- Supreme Receiver
- supreme receiver
- 5475/475
- Hitec Servo Programmer= bad product?
- 605BB Rumors?
- Metal servo horn
- MIKE, Could you PLEASE help me out? Maximum Program Values For Hitec Digitals?
- 605bb vs 605mg
- HS-81 servos won't center when off
- servo arms
- Eclipse 7 extra battery
- Hitec Digital servo programmer
- Eclipse 7 and Airtronics RX
- HS 80's
- 5625 failure.
- hitec hs 645 mg servo screws
- Mini Servo Repair
- Charging and cycling TX batteries
- 6 volt
- Eclipse 7 & V-tail mixing question.
- AT-6 Top-Flite Gold Edition wing servo
- 225/225MG failures on the rise...
- Mike is out of the office until 2/25
- Which servo for throttle
- Trainer cord problems Eclipse 7 - Focus 4
- AM Tx as buddy-box to FM Tx??
- deadband
- Programming Questions
- 605 BB concerns
- Feather receiver question
- programmer?
- Eclipse 7
- Servo setup
- mode?
- digital servo factory deadband
- Hitech HS-475HB vs HS-545BB
- 535 Rx repair
- dual conversion crstal
- New Hitec digitals - a report
- Club Hitec.... join today!
- Hitec Wire, Connectors, etc
- Do all digital servos make a high pitch sound?
- Lite as a feather
- servo reversing
- HS-5645MG Goin back for fixin.
- Hitec servos?????
- Metal gear or not?
- Arrival date of new HS-5975 ?
- Focus 3ch vs. Neon
- Bench testing Hitec Digitals
- Eclipse upgrade ?
- 5945 and y-harness
- Hitec channels
- Electron 6 - more info?
- Hitech Neon
- Problem with Hitec HFD-08RD and Supertec S03 Servo
- Helicopter servo recommendations
- Can I clean the servo pot?
- Hitec Master 5P information
- HS 5945 - 5 cells??
- Modified Digital Servos
- hitec channel
- Disregard,solved
- Low or High band
- Servo & Rx Recom. For Sig Rascal Elect.
- Hitec Digital Servo Question
- internal Hitec Laser connectors
- **total System Failure**
- HS 605 MG overshoot problem...
- Eclipse, D/R changes Center position
- 605bb hd arms??
- receiver for lynx 3d
- Question for Mike
- Laser 4stops Working When Trainer Card Is Pluged In
- Terrible chatter from Eclipse 7s (mine and friends)
- HS-5735MG lasts less than 10 minuts before failing on bench.
- HS-225 Centering at low temperatures
- 5975
- flash 5 expo & dule rates
- changing frenuencies hitec eclipse 7
- Mike,question about Prism7 and the updated version of the Eclipse7
- Dual elevators on updated Eclipse
- Digital Servo Power Consumption Question
- extra crystal storage in the flash 5
- Interchangeable servo's with IC ?
- Eclipse Problems
- Digital Torque
- Flash 5 sx PROBLEM
- want buy hitec flash 4 tx only
- Prism 7x and
- Another HS-5625 Failure -- This one from Jan 02 Lot
- 81 mg
- Eclipse and GY401 Question
- Challenger 720
- Hi mike, PRISM7
- Digital Programmer
- Servo Noise?
- Hitec servos
- Neon
- Eclipse 7 Update
- Flash 4 question
- Long Leads
- Hitec radio setup for BTE Delta
- Multiplex buyout?
- Antenna lenght
- Thanks Mike
- 475
- HS-5645 & HS-5625 Wire Extensions
- 5645's and long extensions
- Hitec Eclipse Question
- Digital problems fixed!
- Hitec Receivers on 50MHz
- eclipse 7 with Aerofly sim problem
- Need plastic parts for Prism 7X
- cold jitters - hitec servo
- Eclipse 7 w/ spectra module
- RCD reciever
- Help Mike, older 6 wire servos
- Buddy Box Compatibility
