- Problem with HITEC ZEBRA 3CH FM AERO
- Adding fourth channel
- Warrenty Void?
- How much torque do I need?
- HS-5995 question
- HITEC COMPATABILITY
- Hitec Optic 6 w/spectra failures
- Hs65mg servo made me crash
- Hitec Mcro 05S with 4/HS-311's
- Eclipse 7 - servos don't move
- Servo Centering Problem
- When will the HS7955TG be available?
- Hitec Servo Problem
- version 1.04 5955's and futaba fasst..ok??
- ECLIPSE 7
- Suggestions on a good quality throttle servo?
- Eclipse 7 question
- Thanks Mike!
- 5625 digital Servos with A123
- wiring
- programmer?
- HS-645MG's versus HS625MG's on a Cermark SU-31- torque vs. speed?
- HS 5245MG Failures
- Trouble locking signal between Evo 12 xmitter and Fusion 9 rcvr
- I have several new erratic acting Hitec receivers, HELP ME PLEASE??
- Spectra Module Question
- Optic 6 Truth ?
- HFP-10 Questions
- Antenna Length Options for RX???
- BRAND NEW Auto shift Receiver Hitec - Strange behavior:
- please remove this entry
- Servo recommendation, please
- Multiplex/Hitec and 2,4 GHz?
- HITEC servos & FASST receiver compatability
- Micro 555 Receiver Max Current?
- I cannot program the Hitec 5645 servos
- Upgrade HS 85BB to MG?
- >UPDATE< Severe Hitec HS-81 servo chatter
- Hitec HS5625MG servo's
- XPS & Multiplex EVO 9
- Hitec HFP-10 Servo Programmer Upgrade
- 1/10 scale oval sprint car eletric
- dead hitec hs 422
- JR X9303 Gyro Gain Rx Channel for HG-5000
- Assan 2.4G modules
- NI-MH Batteries...HELP!
- Servo noise
- Hitec Programmer question
- cockpit mm pitch curves
- Super Hitec Service!
- Hitec servo programmer
- HS5245MG????
- 180 degree travel on servo
- Spektrum and Optic 6
- Will a FASST module work in an eclipse?
- HFD-08RD Problem
- Hitec Crystal Changing
- 4-wire servo
- Replacement buttons for LN-5014?
- HS-5475HS servo-plug problems
- Fusion 9 Receiver?
- Eclipse 7 and Elevon Dual Rates ?
- servo arms for hitec 645MG
- Evo 9 problem
- hitec supreme IIS reciever crystal
- aerial length
- HS81 & HS55 Overreacting
- Can an FM Xmitter control an AM receiver ?
- HS 5645mg & Interference
- HS-55 Servo ok to use?
- Optic 6 Spectra Module Problems
- 5955 TG
- Hitec servos work with JR receivers?
- Hitec Supreme II S reciever
- antenna length
- RF module in Prism 7x (removing it)
- Hitec HS-45HB gear set
- Identify the servo
- HS-45 geartrain clicking/slop?
- HS 55 and HS 56 GEAR COMPATIBILITY?
- Hitec Supreme FM Autoshift DC Receiver
- Multilex Evo
- Hitec servos and Spektrum DX 3.0
- 5955TG questions
- HS 5965MG smoothness ???
- Hitec Optic 6 Aileron mixing with D/R
- HS81MG?
- Futaba9c and Spectrum Module
- Airtronics and hi-tec servos
- Evo 9 Firmware?
- hs-311
- How much is it to upgrade a programmer
- Jitter
- HFP10 programmer
- Hitec HS5645 Servo Centering Problem
- Eclipse 7 Expo
- Royal Evo 12 v2.0 software
- Tight servo
- Hitec servos with a DX3r radio
- PPM, MPX PCM?
- Neutron 6s
- Hitec rcvr antenna routing question
- 7955's Next month?
- 645MG
- EVO-9
- HFP-20 question
- Evo 12 - Trim & Expo In Flight Phases
- Servo Matching?
- 7.4v Servos
- JR Radio, Hitec Reciever & Servos
- HITECH HS 82MG
- Proper battery & extension leads question
- Another EVO 12 to 2.4 question
- 5925s
- Will there be a 2.4 conversion for Evo 12?
- Futaba/HiTec/JR Compatibility question
- Optics 6, V-Tail, nose gear
- Where's the 2.4 GHz Air Radio?
- Question retracted due to lack of response!
- Batt Size??
- Older Hitec Reciever Question
- Many thanks Hitec!
- Hitec sub micro servo to match Futaba's
- Optic six / Rubber ducky style antenna
- Hitec Servo Programmer - upgradeable?
- HS servos
- hitec sp 520 esc
- r149dp and 5955's
- which Hi tech servo is suitable
- HS-81 servo horn screw size
- MPX Royal Evo 9 - won't turn on
- HS 5625 and 5645 gear trains?
- Servo degrees of travel question 5985/985
- Hitec Lynx 3D
- Blue Servo Horns
- Parts for HS545 BB Servo
- Hitec Eclipse 7 quetion.
- EVO12 QUESTIONS
- Hitec Position Statemen on 2.4 GHz
- Hitech CG-335 charger problem
- Help! with Flash5
- Hitec Does It Agian!!!
- HS-5625MG
- Hitec 5955 Servos-Y Harness
- Servo sticker?
- Problems programming the 5990TG servos
- Optic 6 range problem.
- Eclipse 7 mixing???
- Rx Difference?
- Optic 6 Tx with single conversion receiver
- Thanks HiTec Customer Service
- 2.4 ghz
- Back case replacement
- 7955's
- Happy New Year
- Hitec Hs-985MG issues
- Hitec Servos and A123 Batteries
- Christmas Has com and gone....
- eclipse 7 ch for mode I??
- Hitec Focus 4
- Apollo 115 servos
- Hfp-20
- Newbie question re: setting of end point adjustments
- Flash 5X crystal
- HiTech Electron 6
- Hitec ball bearing servos
- Royal Evo 9 Synth
- HS-5975HB FELURE AND ALMOST CRASH
- Dgital Servo's
- HFP-10 Programmer Upgrade Program?
- HP-10 Problematic in old age???
- Older receivers
- HS-81 for throttle in 10 lb plane?
- Flash 5 v-tail mix programming
- Spectra Module Screwdriver
- RCD Platinum Rx Service - KUDOS
- gyro on a plane
- Composite ARF 2.1M electric
- Optic 6 flaperon setup
- Eclipse 7/dual elevator servos
- Platinum Series Receivers
- HS 65 gear train
- 645MG issues
- Hitec programmer took a dump?
- HS-5625 MG Servo:
- Hitec Digital Vibration
- direct servo control for hitec
- compatibility Hitec Rx with JRXS3 radio
- Gear switch to Gain pot?
- hitec 5645 screw size
- 2 Eclipse firmware revision
- trainer cord
- Eclipse 3-way-switch for speed brakes
- HS-654MG in a Hanger 9, P-47, 150 size
- Blue metal servo arm
- Servos for SIG 4-Star 60?
- What Servo?
- Hitec leads ?
- Optic 6 Set up
- Replacement transmitter switches
- Hitec Service/Repair estimates
- No response from receiver
- Hitec programmer no volts no pulse
- Eclipse 7 with spectra module and FMA Direct fs8 receiver
- Hitec Optic 6 not working
- HG5000 Availability
- 81's round servo horn
- Prism 7x gimbals- correction
- 7955 question on torgue
- compatability of servo arms HiTec vs Futaba?
- Problems with Fusion 9 channel receiver
- Hitec 7955 ??
- Hitec radio replacement parts
- New Hitec Programmer?
- !! Forest Fires In San Diego !!
- 6975 suitable
- Hitec HFS-05MS Receiver
- Flaperon versus EPA "Eclip 7"
- What parts are missing here?
- Optic 6 Aileron Mixing Switch Assignment
- Upgrade for EZ Glider??????
- Bizarre Behaviour-Flash 5 TX
- Using 490T gyro with Eclipse TX?
- New HS-81
- 5955TG Issue
- 5945 Servo cases
- Multiplex battery monitor problem
- Cycling Transmitter Battery
- aerial
- Evo 9 Flap Servo Offset
- HiTec 605 gears
- Hitec Eclipse 7- dual elevator servos
- Help: programing optic 6
- Hitec 5945 factory default settings
- 2.4 GHz SS Air Module in the offing?
- Hitec Prism 7 - "given up the ghost?" * new TX
- Multiplex-Kombiset XM-M1 2.4GHZ
- trim changes on high rate
- Eclipse 7 problem
- servo for trex 600 and spectrum dx6
- HS-5985MG Servo centering
- Hitec eclipse 7 "jittering" with full forward and left!
- Optic 6 Sport Stereo Jack Trainer Cable
- Royal Evo HFM-S module heating ??
- HS-55 not Centering
- Programmer or servo problem?
- Elevon reversing on Flash 4
- MPX Rhino problems
- new surface transmitter
