PDA
View Full Version : Hitec/MultiPlex Radios- Ask Hitec Customer Service
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
  1. Hitec Servo dimensions
  2. The future for Hitec
  3. Aurora 7 Receiver crashed
  4. Multiplex Royal Evo 12 ch 2.4 upgrade question
  5. D980tw issu
  6. New Hitec D-Series Servo Question
  7. question about the HS-75BB
  8. Hpp-22
  9. Aurora 9X anomoly
  10. HiTec receivers
  11. 4 aileron servos for Biplane
  12. Aurora A9X - Optic (Spectra Module) Buddy
  13. Aurora 9 Tx crashing planes
  14. Aurora 9 vs. Aurora 9X
  15. Owner's manual for Aurora 9X
  16. A9+OPTIMA7+HS645MG glitching.
  17. HS-5485HB Problem
  18. Aurora 9
  19. aurora 9x wont load
  20. Hitec Gyro
  21. Disfuntional RCD 3500 "S"?
  22. Hitec HS-5645MG Question
  23. Bonehead move with battery
  24. A9 with Minima rx?
  25. Hitecservos for High Vibrations
  26. Need more than 9 ch.
  27. burned cuircit board
  28. Dual elevator servos
  29. Hitec Spectra 2.4 module scan mode
  30. Aurora 9 Corruption Problem???
  31. Aurora 9 and Optima Receivers Very Strange
  32. Direct or indirect drive servos?
  33. Flash 7 woes continue
  34. Flash 7 - dual aileron setup not working
  35. Hitec HFP-30 Info??
  36. Optima 9 receiver and a Castle Creations talon 90 ESC with high voltage servos
  37. Hitec Customer Support
  38. Optima 6 receiver, 6 channels on gas plane
  39. Hired A9X optic 6 2 servo aileron setup
  40. HITEC HPF-Mi 72MHz Transmitter Crystals?
  41. Aurora 9 switch
  42. Aurora 9X problem
  43. Dc charging with x2 700/400
  44. How can that happen?
  45. Metal Servo Arm for HS-5585MH
  46. help!! Need to use an Optima/Aurora combo with an Artizan Plane
  47. HFP-30 Servo Programmer
  48. Aurora 9. Binding issue
  49. Hitec fuel sensor telemetry
  50. Aurora 9X Sticky Momentary Switch "H", can I clean it?
  51. 9x battery alarms
  52. 9X TX with a OPTIMA 9 RX
  53. Need Help with HS 5065 MG Digital Servo and Servo Programmer
  54. 12 or 14 channel radio needed
  55. Sbus servos ??
  56. Hitec 7245 w/ excess slop Brand New out of the Box
  57. Aurora 9x Update Problems
  58. Current draw on 5645?
  59. Hitec red protocol
  60. Multiplex Royal Evo update
  61. Hitec Telemetry
  62. Flash 8 switches
  63. Spektrum Servo
  64. Multiplex Royal EVO 9 Tx Battery...
  65. Life battery for Flash 7?
  66. Lynx 4S Throttle up on start
  67. Multiplex Smart SX Flexx and Tamiya Pershing
  68. Multiplex HFMx M-LINK connection
  69. HFP-10 Compatability
  70. hitech servo question
  71. tactic receivers and flash 8
  72. Security feature for gasoline engine kill switch
  73. Over Load Protection on a HS-7245MH
  74. V-tail Sx travel problem w/Hitec 255BB Sx's
  75. Are HS-5955TG's compatable with the newer version 7955 on the same controll surface
  76. Are HS-5955TG's compatable with the newer version 7955 on the same controll surface
  77. Rudder Servo on 100CC yak - One HS-5735MG okey or two servos better
  78. Optic 6 discontinued
  79. HELP! Aftermarket Battery Pack Wired Reverse Polarity
  80. Are the new generation HV analog servos compatible with higher frame rates?
  81. Aurora 9 random faint beeping
  82. HS 5085MG Socket Head servo control horn screw
  83. Aurora 9x Problems
  84. hitec aurora 9 in need of switches
  85. Replacing the antenna on an Optima 7 Receiver
  86. Hitec Lynx 4s Telemetry system, Music/wav file update
  87. Aurora9 with 2 receivers
  88. Aurora 9X Timer
  89. 9x battery warning
  90. Hitec Servos and Spectrum AR9020 RX Compatabiltity Issues
  91. Hitec Servo Precision
  92. standard Servos and 4S Lipo's
  93. Is Hitec discontinuing Optic Sport 6 radios ?
  94. Aurora 9x erratic battery percentage readings on transmitter
  95. Expand 9x # of channels?
  96. Virtual switches on 9X
  97. Maxima 6 9 CH Receiver
  98. 9x vibrate feature
  99. Higher Capacity In the Future?
  100. Hitec Aurira 9 Prog Landing Lights
  101. Servo Vertical Mount Adapter
  102. Aurora 9X update
  103. Twin throttle trims with A9
  104. Hitec Aggressor CRX FM
  105. Hitec HS-7965 on 7.4
  106. Optima 6 case back panel.
  107. Hitech Aurora 9X Touch Screen
  108. copying Aurora 9x to Aurora 9X
  109. Two servos don't 'move' together! HS 5585 servos
  110. Hitec HPP-22 Software compatible with Win 8.1?
  111. Aurora 9 flight conditions ?
  112. Aurora 9/Optima 9 - double slave
  113. Optima 9 receiver - channel 9 ?
  114. Aileron/Flap Operation
  115. magic smoke escaped
  116. Optima 9 antenna orientation
  117. Hitec Telemetry Station Extension Cable
  118. Hitec hfp-10 question
  119. Aurura 9x losing memory on channels when switching from plane o plane
  120. Minima 6E two servos only one works when battery plugged in
  121. Multiple Receivers with Aurora 9
  122. Buddy hitec Optic 6 & Flash 5
  123. eclips 7 72 mhz will not move left ellaron
  124. Hitec Aurora Manufacture Specifications
  125. Availability & Pricing on HItec Flash 7 & 8 ?
  126. lauterbacher billet case for 5765 servo nylon washers?
  127. Hitec Flash 5 Transmitter battery
  128. A9 flaperon issue
  129. flash 5x reversed battery connection
  130. Puzzling Throttle Cut Problem - Aurora 9
  131. servos surge on power up
  132. Aurora 9x
  133. Minima binding
  134. Hp 10 programer
  135. Optic 6 Xmtr Beeping
  136. spc jumper
  137. Poor centering on HS5565MH servo
  138. 7775mg
  139. Hitec H 4 battery charger - charging batteries with internal circuits
  140. Hitec 29431
  141. Delete spoileron programming duplicate
  142. Spoileron programming
  143. Reboot Sequence after Sync
  144. Aurora 9x firmware
  145. Factory reset for Aurora 9?
  146. Hitec HS-7965 on 2s lipo ?
  147. Trouble shooting Air Speed Sensor issue.
  148. Dating Servos
  149. Hitec Servo Availability
  150. Hitec Sensor Station and Gps
  151. Hitec Sensor Station in gas airplane?
  152. Aurora 9 throtle cut issu
  153. Binding Minima rx to A9
  154. Transferring Model Memory from Optic 6 to Aurora 9
  155. A9 giant scale mixing and power requirements
  156. Hitec optic 6. Mode 1 and Mode 2 buddy
  157. Aurora 9 language change
  158. Profi MC4000 - EVO12 Trainer Stick problems
  159. Hitec Aurora 9 Tx.problem.
  160. Using 3 cell lipo for TX battery.
  161. Multiplex Flight Simulator - "MULTIflight" - Freeware
  162. Buddy Box
  163. Hitec HTS-GPS
  164. Hitec Telemetry, Navi interface
  165. Hitec HS-322HD compatible with Fuaba?
  166. can you convert 72 mhz radio to 2.4 ghz
  167. Eagle A3 Pro flight stabilization
  168. HPP-22 - Won't "Connect" to PC/Windows 7
  169. 3 axis gyros with Aurora 9
  170. Otptic 6 - Model 3 - Elevator Problem
  171. Hitec aurora 9x servos
  172. HFP-10 and 5645 servos
  173. scan mode
  174. Optima 7 -very expensive rx
  175. Hitec Aurora 9 + Optima 6 + Eagle Tree Guardian.
  176. Compatability of RX's
  177. Scan Mode Aurora9 ?
  178. Freedom 9S rec. question
  179. Multiplex EVO 9 72 mhz modified with 2.4 ghz Spectra
  180. Please clarify?
  181. Voltage sensor not working in Blue telemtry station
  182. HITEC AURORA 9X any idea when will it will be released ?
  183. Aurora 9
  184. Optic 6 Sport 2.4 lockout
  185. Prism 7 Manual
  186. HS-5996TG
  187. Multiplex's 55th anniversary & 10th Year with Hitec RCD
  188. Optima 7 vs Minima 6T
  189. HS-55s - OK for Maxford GB E?
  190. Sorry for the Double Post
  191. Hitec programming question
  192. Guardian 2d/3d
  193. How to remove balancer post?
  194. RX Voltage?
  195. Cannot access HITEC RCD with Mac computer
  196. Spektrum module for A9
  197. Resetting Hitec 5645 to factory
  198. 5645MG Servos Continue to Move
  199. Servo amp draw?
  200. Battery AND charger swappable?
  201. Hitec TX charge port polarity
  202. Hi Guys
  203. Aurora 9 and Aurora 9X.
  204. Flash 5 and Laser 4 compatibility?
  205. Variometer
  206. Two recievers question about Voltage Tx readout
  207. Optic 6 lockout and crash.
  208. Aurora 9's "apparent" lost signal.
  209. I am trying
  210. Shawn Spiker - Top Notch Hitec Service & Support
  211. Hitec Advanced Telemetry Pkg Discontinued
  212. Aurora 9 /opitima 7 box contents question - newbie here.
  213. Ignore this.... see next post
  214. aurora program for engine kill
  215. Optic 6 programming
  216. HPP 21+ Progamming
  217. Spectra 2.4 / Optima programming
  218. Aurora 9/Optima 9 voltage reading
  219. Hitec Telemetry-GPS speed??
  220. HPP-22 Upgrade to V1.14(0) now available.
  221. Wide operating voltage for Minima 6E and 6T receivers
  222. Aurora 9 trainer cord to other brands of radios
  223. Aurora 9 switch replacement.
  224. Eclipe 7 Pro: Which AnyLink Cable...and/or Tx Settings Needed
  225. HS5645MG for Flaps
  226. Multiplex evo radio support?
  227. Minima 6L
  228. throttle stick issue
  229. Aurora 9 issue
  230. No Head Tracking on Aurora 9???
  231. Help!How to prevent engine running with radio off!!!
  232. Rate control mix support
  233. X-1 Charger
  234. HITEC AURORA 9 TX CHARGE PLUG REPLACEMENT
  235. 5645's and A123's or do I need 5685MH's for safe operation and long life
  236. HS-85mg screw
  237. Old Multiplex 2010 programming information
  238. Can Hitec 7.4v servos take 8.4v
  239. Optic 6 loses comms with airplane when Tx is close to plane...
  240. Eclipse 7 trims
  241. 7980 Servo
  242. 7980 slow to return to center
  243. Problems continues with Hitec 5485 servos-BEWARE
  244. Updates?
  245. Optima rx voltage?
  246. HPP 22 programming
  247. RECIEVER BINDING
  248. Twitching Servos
  249. Problems with the tail t-rex 600 nitro and aurora 9
  250. Hitec Modules
