PDA
View Full Version : "1/2 A" & "1/8 A" airplanes
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42
  1. Book Offer
  2. Sig Hummer
  3. AP Wasp and Hornet
  4. What is 1/2a?
  5. Super tiger X-11
  6. I dont believe this!
  7. WINTER PROJECT - would these components be OK?
  8. two small
  9. td .051 piston
  10. Box 'O Norvels
  11. power pod for cox .049
  12. New head for Cox .074
  13. Thanksgiving Greetings
  14. Some good news - finally
  15. Build thread - prototype Squirt
  16. Wanted
  17. 1/2A SCALE PLANS
  18. Laying up composite 1/2A fuses
  19. In cowl pitts muffler OS10,TT!0 and more
  20. AM 1.5cc, timing?
  21. When does the doodling stop and the building begin?
  22. Question about Lanier Indicator
  23. .049 OK Cub question.
  24. BATOUTAHELL!!
  25. minor score
  26. MACH NONE BUILD (built up wing)
  27. LA .10 any good?
  28. Something slow for an 020
  29. next step up ???
  30. Vapor
  31. .010 L'il Pearl plans
  32. Ideas for the Building Board?
  33. Fairey Junior, stud "pips" ?
  34. More inane scribblings..
  35. Got some new toys
  36. engine_ace_rc_extra
  37. Comet Taylorcraft
  38. Spare Norvel AME 061
  39. Sanding down an aliphatic seam between sheets?
  40. HOW DO YOU STArt a cox sure start engine
  41. you can buy cox engine on somewhere other than ebay
  42. Gettin' together
  43. Japanese Little Tony
  44. Norvel AME plug
  45. mini flyer engine problem
  46. Herr Lil' Extra throws
  47. 1/2a Rivets Build!
  48. Shrike covering difficulties.
  49. 30 4 stroke looking for a home
  50. New Enya .09
  51. Long lost kit found hiding in my garage: Guillow's Bellanca Cruisemaster
  52. Two flying seasons
  53. coloring clear dope
  54. Balsa USA
  55. 1/2A options today
  56. Magical day yesterday
  57. Sure Shark Short Kit - Flying Models
  58. Torque rods without tubes?
  59. Kangke/supercraft monocoupe
  60. Jett .035 engine
  61. Want plane cleaning advice
  62. Mini Bells, a pair
  63. Skydrill pilot roll call
  64. 1/2A spinners
  65. 1/2 A Taube
  66. new kit!
  67. How to clean an old cox black widow?
  68. Hollis' Simple Duster
  69. Drill size for 1/4-32 tap.
  70. push moth plans
  71. check out this landing with 1/2 wing,,,amazing!!
  72. Subinduction Piston
  73. Norvel identification question
  74. What to say to increase 1/2A
  75. skydrill kits for sale ???????
  76. Hobby Windtunnel
  77. PAW .049
  78. Cox Surestart glow head to cylinder won't seal, leaks.
  79. Cox sure start availability
  80. 1/2A F9F PANTHER
  81. Anyone have or had a thunder tiger scooter
  82. Q-Tee instructions needed
  83. Norvel 074 heli engine conversion
  84. Got a canopy that is showing its age?
  85. Repaired Blink
  86. whats what?
  87. Seahawk 0 ,Falcon 1...
  88. Roy Clough´s Round wing article WANTED
  89. .010 props
  90. New radio prob
  91. ACE GLH II question
  92. rudder on a 1/2a worth the weight?
  93. Cox .049: Babe Bee vs Black Widow
  94. Airtronics vg7p
  95. RCU running slow?y slowly lately?
  96. FIRST 1/2a Flight today. I LOVED IT!!!
  97. Norvel .074
  98. HERR planes are top notch!
  99. Looking for a needle valve
  100. G-Mark .15 single
  101. MJD's BLADDER TANK !!!
  102. question about receiver antenna's
  103. I just realized something.
  104. Ace Mach None Canopies
  105. Hey 020 fans - lookie here - Part Deux
  106. Magnum 061 & 091
  107. Looking fo a new project, anyone got plans (or cheapish kits) wanted trying
  108. Lightening ACE foam wings?
  109. Herr Cloud Ranger / Magnum 15
  110. ACE LITTLE STICK
  111. "Try 1/2A Aerobatics"
  112. Batteries?
  113. Precision Needle Valve Assemblies for O.K. Cubs and more
  114. Hey .020 fans - lookie here.
  115. AME engine mod's for racing
  116. Carolina Crew Reedie Race - 10/04/08
  117. Lil' Rascal
  118. Surestart Muffler
  119. small engines
  120. Rx Battery for a Lil' Rascal
  121. Paramour
  122. Does anyone know of a good 1/2A or similar size glow powered heli?
  123. COX TD .049 WANT STAY RUNNING
  124. SIG Aerkote Lite covering.
  125. OT - A great evening
  126. I like new old stuff!.......
  127. Ace Foam Cores
  128. Joy stick
  129. My first 1/2a Reay to go!
  130. YAMP 8 Mystery block.....
  131. HS-81 servo arms
  132. What is the max prop RPM?
  133. Will Cox engine melt solder
  134. I need encouragement here..
  135. Picked up a Norvel
  136. OK Models, Baby build thread
  137. Really Sensitive Needle!!
  138. Enya .09 Plans
  139. The Great Glow Plug Run Off!
  140. What size allen wrench? Norvel head screws
  141. Modified Pacer .15 Build Thread
  142. Hey, who knows what about voltage regulators
  143. A link for the machinists in the audience.....
  144. Chunky low wing
  145. The Good, The Bad, & The Ugly
  146. .051 Stryker?
  147. 049 and experimental aircraft video
  148. Guillows Conversion, yes another one
  149. Enya .09 prop nut / what size is it
  150. How do you balance...
  151. Wow. It really flies! And fast too..
  152. !!!FIRST 1/2A!!! Morris Hobbies YELLOW JACKET??
  153. Blink - last known photos
  154. I want this! Wahhhhh!
  155. 1/2A stik
  156. Ace Simple Ultamite Biplane Any Thoughts.
  157. Quicke build
  158. Bigger Fuel Tank For Herr Little Extra.
  159. Enya 09-IV w/ M154 muffler
  160. cox tedee
  161. Dynam servos
  162. Reciever on 3.6 Volt ??
  163. newbie with Cox 049 Piper Turbo Arrow III
  164. found in the trash.
  165. VA for Norvel trade anyone?
  166. CREW!!
  167. OK Cub .074 Performance Numbers?
  168. Sykosis!
  169. How much junk do you carry?
  170. Shark XV Build Thread
  171. 1/2A Crew Reedie Race and Fun Fly Oct. 4th!!
  172. E-flight, give me a break!
  173. Plan for "Two Bits"? I can't find mine!
  174. VA 049 vid on YT
  175. Turbo or Nelson conversion for Norvel and Cox ???
  176. Maybe new to some.
  177. A few small engine suppliers.
  178. .15-size build thread
  179. Minwax Polyurethane ? fuel proof
  180. Cox replacement servo
  181. Ideas for a TT GP.10... Also, how to "untile" these free plans?
  182. Blink nearly ready..
  183. Bipe with unstable pitch
  184. Over & Under CG
  185. Herr Little Extra flight packs...
  186. Herr Little Extra discontinued?
  187. Long time no Post
  188. APC Props with Cox Surestart
  189. Wan to help ID some cox engines?
  190. 1/2A society
  191. Mini Bell Maiden
  192. AP hornet .09
  193. cox TD.049 problem
  194. Little Dragon .060 byb Roy Clough Jr
  195. Norvels are back on stock : hurry up !
  196. Hoonker plans
  197. Anybody try one of these?
  198. Fly in the ointment...
  199. moved to the for sale section
  200. Going electric
  201. COX .09 piston/cylinders.
  202. So here we go!
  203. Cox Conquest Piston Liners
  204. What engine to buy?
  205. What size plane should I build for this location?
  206. RCM Plans?
  207. Has anybody built and flown a ACE Pocket Rocket.
  208. Has anybody built and flown a Lainer Dominator 200
  209. Cox on Wikipedia Very informative!
  210. Everything say's go glow!
  211. Who built the Aurora engine?
  212. Hextronik Voltwatch Shootdown?
  213. Quick Battery Question
  214. New radio
  215. Pilot Baby
  216. Norvel .074 carb Glued in?
  217. Small plans & kits
  218. what engine for Baby??
  219. K&B 5x4 Props?
  220. Die Cast Cox
  221. Tissue Covering
  222. 42" Super Cub
  223. Thunder Tiger .07
  224. Need prop advice
  225. 1/2 Little Toni plans avaliable
  226. ARF Plane for a MVVS 15 with a tuned pipe
  227. Pusher Prop size for Cox Tee Dee .049?
  228. Norvel .074 head dimensions
  229. WACO SRE
  230. Help!! I can't remove the head from my Norvel .061 :(
  231. Why Norvel failed
  232. Walter Musciano
  233. COX CUB TRAINER .020
  234. Lathe How To book online
  235. Cheap radios
  236. What did I forget this time...
  237. glow conversions
  238. Christmas in July
  239. New Aquisition
  240. Pilot QB series plane
  241. Starting a Norvel .074
  242. Where to get 0.02 engines.
  243. The Prophet
  244. Where to find Glow Head Wrench for Norvel BigMig .061
  245. Cox .020 Skycopter - First Flight
  246. Which 1/2A motor for this?
  247. Engine Recomendations 0.07-0.09 pusher 6x4 three blade ???
  248. Hey guys, radio prob
  249. On Board Glow
  250. NEED GLOWPLUG IGNITOR
