PDA
View Full Version : "1/2 A" & "1/8 A" airplanes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42
  1. something to put a .049 on?
  2. AP .061
  3. AP .061
  4. Ken Willard Drake II... Free Plan
  5. Venting!!
  6. Cox 049 replacement
  7. I had to ask...
  8. After market head for TD-.09
  9. Reseting Piston
  10. DNU Twin modification (CAD)
  11. cracked plastic on TD 049?
  12. OMG! .074
  13. Showing off my new Upstart
  14. My Blink
  15. Tyvek hinges
  16. Modded Blink
  17. 1/2 A how much wind can you have?
  18. Control Line PT-19
  19. kit suggestions cox td .010
  20. Mecoa head for Norvel .074
  21. Tiny Tot Bipe
  22. Geared Twin Pee Wees
  23. Futaba's answer to the HS-81
  24. Sealing decals
  25. Foamy--lipo
  26. Herr Pitts Cowl
  27. CP; I thought of you last night
  28. .15 in a .074????
  29. Brit Bipes
  30. Quantum Models
  31. SPEEDY BEE for France
  32. Servo problem
  33. best 1/2 a scratch build for .049 dragonfly?
  34. Testing battary flight time on ground.
  35. Thunder Tiger GP-18
  36. Cox/Sanwa Servo help
  37. G MARK .061
  38. the thread has disappeared
  39. .25 Sized Bi-Plane
  40. Push rod freferences?
  41. Is this what Cox would have used...
  42. Decisions
  43. Tee Dee .051 Strange Design
  44. Herr Little exta
  45. The 2008 Fora .15
  46. CLANCY MICRO BEE
  47. Wild (possibly heretical) notion
  48. Covering, hinges and pins? What order?
  49. My Dad's 75th Birthday
  50. My SureStart .049 Throttle Design
  51. 4 Bladed props
  52. Is this the end of Cox product engines?
  53. Foggy Bottom Boys
  54. Our "other" hobbies and similarities:
  55. Just saw a new product!
  56. .049 Throttle
  57. Sun Fli IV w/.074
  58. Sig Hummer....... CHEAP BUILD!
  59. Crazy prices?
  60. Radial Mount for GZ???
  61. Ugly Bug used the Ace foam wings. Plans?
  62. Doug Galbreath Head = more power? + other Tee Dee mods
  63. Print your next motor...
  64. Not 1/2a but pretty impressive
  65. How much are NIB Norvel R/C engines worth?
  66. Tic Tock
  67. Cox FAQ sticky ?
  68. Help - .020 pusher prop
  69. Are they really that good?
  70. G MARK .061
  71. Lightweight Ultracote alternative?
  72. Some Juggling
  73. Big Spinner
  74. Norvel glow heads - Hypercolor?
  75. A need for 1/2A again
  76. D.G. .061 MP-JET
  77. Too windy ya'll
  78. Ace Simple AT6 - overpowered?
  79. Fuel /Oil calculator
  80. Cross one dog owner with one model builder..
  81. Ace Simple Series Staggerwing
  82. any videos?
  83. Valentine Carbs
  84. engin I,D
  85. cox tee dee .09
  86. cox rc pt-19 cg?
  87. Cox parts
  88. DNU w/ Norvel .049
  89. Any with cox PT-19 R/C Trainer?
  90. Hey crew,,,10-27-07 funfly
  91. Off topic but astounding, jaw dropping technology!
  92. A gram
  93. COX TD .09 WITH R/C CARB
  94. Norvel .074 inverted
  95. Obituary for 1/2A?
  96. small park flyer designs
  97. Beginners question: mounting receiver upside-down? Mounting small servo?
  98. Pacer or Mach None?
  99. who makes this kit
  100. search not working for "VA".
  101. Upstart build & 1/2a Racing article from '71
  102. Traveling Grace
  103. Herr Pitts Special Kit Build Thread
  104. Tee Dee 049 with reedie cylinder
  105. Herr Pitts Bipe - Servo Setup (sanity check)
  106. Strange Reed Valve...
  107. What I did today.
  108. How to read DOC files for plans???
  109. removed...
  110. DQA 704 first flights
  111. Reedy race winners
  112. What are you folks using for fuel these days?
  113. A new DickeyBird project.
  114. A glimpse into your future
  115. 1/2A Water ski-ing anyone?
  116. Anyone know the name of this covering?
  117. Really aerobatic (close to 3D?) 1/2A kit for Norvel 0.061
  118. LA Stick
  119. Painting a sheet model with dope
  120. For engine builders, machinists and tinkers alike
  121. Club combat with 1/2A
  122. Ralph Barnette
  123. Which engine for Nitro Rascal
  124. Herr Piper Cherokee - Park 450 power
  125. OT -- Airshow
  126. Are Norvel handistart inserts available in the UK?
  127. Drill and tap AME prop screw hole to M4?
  128. Cox TD .09 with rc carb
  129. semi semitrical wing chariteristics
  130. Gone to the Dark Side
  131. Norvel 0.061 - problem - compression too high?
  132. cox micro warbird conversion to glow
  133. Plane Design
  134. Crew Approved!
  135. Galbreath adapter/ Nelson plug spec?
  136. Heres a new one..
  137. Zero for surestart
  138. Turning some 1/2a wheels
  139. Who sells Norvel
  140. Excess small kit sell-off
  141. Longer Flight Time???
  142. last of the production littlies...
  143. Oh the Horror!
  144. Ace 1/2A Pacer engine selection
  145. What covering do you like?
  146. paw diesel owners
  147. DQA 704 parts
  148. Model wanted...
  149. Norvel: grey in exhaust residue - what to do?
  150. How to use this hinge. Picture
  151. Cox .074 Cylinder Swap
  152. BMJR Simplex 45
  153. Canary 1/2A Bipe
  154. OUT FOR 1/2A BLOOD!!!
  155. Wen-mac
  156. Gym-e airplane
  157. Norvel .061
  158. Sources for propellers
  159. AP Wasp idle rpm
  160. Pong Two build thread
  161. Cox .15 TD Mk II
  162. FUEL SUPPLY PROBLEM
  163. how do you mount your surestarts?
  164. How to clunk a 1/2a fuel tank?
  165. guillows p-51 27inch
  166. TT .10 and .15 performance expectations???
  167. Whatzit? (Need model ID help please.) Now With Photos...
  168. Norvel 074 Need Help
  169. 1/2a flyers in the Chicago area?
  170. Which .049 should I buy
  171. Servo Help
  172. Has everyone seen the new air races?
  173. Walt Musicano
  174. remember
  175. OS 15CVA - what racer plane?
  176. Herr Pitts Bipe - .10 LA or .15 LA?
  177. Incredible Hobby Shop Finds
  178. Breaking up Sure Starts
  179. How much does your Q-tee weigh ready to fly?
  180. AP Wasp needle valve loose?
  181. Hey Crew
  182. Just ran across
  183. Electric to Glow? Impossible?
  184. I need a muffler for a TD.09
  185. question on TD.09 tank pressure
  186. A Betreyal......and Redemption
  187. Diesel, FFF Project Report
  188. R/C 1/2a Texaco kit reccomendations
  189. New 1/2 A engine
  190. Best 'advanced children' 1/2A (or 0.15) plane suggestions?
  191. Medallion vs TD
  192. Cox Prop Chart
  193. For less than the price of a value meal...
  194. How much does a TD .020 weight?
  195. Small Bladder Tanks ?
  196. Littlest Stick radio question
  197. FLY POWERED PLANES ??
  198. Diverting exhaust on an AP
  199. Break-in fuel for AP .061
  200. Hi to all my 1/2a freinds.
  201. Lancair Evolution
  202. Metal tank for .49 Baby Bee
  203. Guillows Hellcat -No fly Zone
  204. Suggestions for .25/.30 Build Kit
  205. Flying the Dog- AKA Queen Bee .074
  206. Hiscott exaust throttle
  207. Original Schoolboy
  208. Octoberfest 2007 Oxford, PA
  209. Dang its been hot!!!
  210. Plane for a OS10LA
  211. Skydrill Build Thread
  212. Another machining post
  213. Hmm.
  214. Need TD .010 help
  215. CS 061RC
  216. New method...
  217. Castor oil makes a big difference!!!
  218. Remove Cox crank?
  219. PROBLEM WITH GLIDE
  220. Falcon JR convert to electric
  221. Blowout notice
  222. 1/2a Shrike motor mount issue
  223. How much additional castor oil?
  224. Vibration Problem
  225. How much would you pay?
  226. 1960,s rudder only plans for the DQA airplane
  227. Is grish product still available?
  228. Attention 1/2A Machinists...
  229. NIB Tee-Dee's Use or Collect?
  230. modifications to an 049
  231. Davis Diesel Development?
  232. Cloud Ranger build questions....
  233. Keith Laumer
  234. 1/2a Shrike build question
  235. Big Mig .049
  236. wasp 061
  237. fuel question?
  238. TT .07 Engine
  239. Fun Flies
  240. os la10& la15 discontinued!!!!
  241. APC props and .049s
  242. Latest Effort
  243. Radial Cox backplate... progress!
  244. How do the HOB 1/2a's fly?
  245. hitec micro 05s reciver for 1/2A
  246. Chart for weight to engine size?
  247. Hey Rog,
  248. Small canopies for 1/2A
  249. AP Wasp .061 - in stock at Tower Hobbies!
  250. House of Balsa p-51 Electric?
