- i need a hobbico nexstar
- Saito 100 T twin ...Best ARF to build around it ?
- World Model Super Stunts 40
- MAIDENED MY P-51 - MAN I'M PUMPED !!!
- Open/Close retract doors
- Arf
- Beyond the Ultra Stick
- engine for hobbico extra 300S
- Great Planes Sportster 40 Wing tip problem
- Engine Mounts on ARTF'S !!!!!!!
- Looking for Robart 631 Retracts
- matching ARF covering
- Seagull Edge 540
- Cermark Pitts control throws
- aeroworks 63" ultimate
- Best Extra ARF?
- Sig Rascal Forty
- Kyosho P51 Mustang
- 4-stroke for Somethin' Extra
- 1/3 Scale Model-Tech J3 Cub ARF - Comments ?
- Hangar 9 1/4 Scale Cub J-3
- Hangar 9; Seagull; VMAR - One in the same?
- Does anyone have pics of an aerotech ARF??
- Engine for GP Christen Eagle
- GP GeeBee test flights
- Phoenix Su31 and Saito72 mounting advice
- Engine for Seagull Spacewalker
- Building Hanger 9 Aspire ARF
- CG for H9 Aresti
- Seagull Spacewalker
- maiden flight on ARF...
- Help... UCD 60 flight problems...
- Hobbico Superstar Wing
- Hanger 9 TWIST
- WHICH WHEELS FOR TOPFLITE 1/5 P-51 ??
- What brushless for wattage ultimate bipe?
- 540 EDGE..How in the world????
- CG location for H-9 Cub
- VF Extra 300 66'
- the truth about vmar
- CM Pro comes to the rescue
- Goldberg Extreme 540 Pictures
- Cermark Sukhoi Landing Gear question
- Pacific Aeromodel Edge 540T 60/100 Motor
- MOVED: Airplane Battery Question
- GP Tiger Moth Maiden~pic
- Best .40 size Cub ARF
- Where To Put Switch on VF 66" Edge???
- SEAGULL 540 EDGE!
- Supertigre G-90 for a VF Extra?
- Tail wheel question
- TT Super Decathlon OR WM Clipped Wing Cub
- Yellow Aircraft G-300????
- WM Super Emeraude 60
- TT SUPER DECATHLON 40
- H9 CAP 232 twin servo elevator
- World Models CAP 232 40 Size Pictures and Build Description
- SA 30 Waco setup ?
- Which airplane for US 40cc ?
- Max hight by a R/C plane?
- u-can-do-3d .60 vs funtana 90
- H9 1/4 Scale J3 Cub - How long to build ?
- Phoenix Giles 202-Thrust Line + Cowl Fix
- Harmon Rocket II
- New Ultra Stick 40 Engine
- GP Patty W. Engine mounting question?
- Little Toni
- Here it is beauty bird #2 for me :) check it out
- Funtana Owners - has this ever happened to you?
- Teqila Sunrise
- another smoke system settup question....
- VMAR Tomahawk
- Engine mounting question Lanier Stinger 60
- 3d trainer for evoloution tps engine
- GP J-3 ARF w/ OS LA 65
- Pheonix 120 Suchoi, build along.
- Can someone give me some measurements for GP Wagstaff?
- Aerobatic ARF Selection and Satio .91 4 cyc
- Hangar 9 P-51 .60 size - RETRACTS
- Good .15 ARF's?
- Vector Flight Muffler Problem
- Hi! i have a question about
- Ultimate bipe
- EZ Laser 200
- Goldberg Sukhoi ARF - how much does yours weigh?
- GP Soucy Extra - how much does your weigh?
- extra pics
- Something Extra Throws
- U-CAN-DO 3D Performance
- GP 1/3 Scale Pitts with OS 1.60FX
- GP Super Stearman
- GP Venus and Irvine .53
- New VMAR Forum!
- Hobby shops in Miami area?
- How important is Lateral Balance
- Goldberg Sukhoi
- CAP-X CONSTRUCTION
- Hanger 9 80" Cap Servos
- H9 J3 CUB W/FLOATS
- Smoke system help
- Wild Hare Extra arrives
- Cheap Servo extension and y-harness cable.
- MOVED: Bad Customer Service or Bad Customer?
- Zlin 526
- New GP Super Stearman
- Funtana 90
- AW Edge 90 Wing Panel!
- What is YOUR favorite 40 size bird?
- Wattage Cap 232 problem pls help me!
- MOVED: 4.8 and 6 volt Rx batteries
- Lanier Laser Arf wing to Kit fuse
- New Ultra Stick versions?
- Kyosho Pitts
- Patty Wagstaff first fly
- OS Surpass 120 Pumper In PA Tiger Moth?
- TDL Extra 330
- H9 T-34
- Global Aviator - cowl colour
- engine for GP Ryan
- ModelTech Giles-202 (CG)
- hanger9 xtra easy
- Kyosho Autokite XP Review
- Check this out
- ENGINE FOR HANGER9 T-34
- Kyosho Spitfire
- Need help with H9 1/3 cap
- GP Super Stearman
- Super Craft Cap 232 .60 Firewall question?
- PACIFIC AEROMODEL'S EDGE 540T .40 SIZE RECOMMENDED CONTROL THROWS
- Lanier Extra 3.25
- Who all overpowers their plane? and which plane and engine
- Sig 4* 40 ARF.... assembly mods or changes???
- Is This a Good Choice for a 1st Plane ??
- THANK YOU EVERYONE!!!
- Sig Kadet Senior ENGINE Size
- My new Pacific Aeromodels 540T 60
- Phoenix Models Giles 202 question
- Great Planes Shoestring/previous posts
- Goldberg Decathlon ARF Quality
- WM GS Miss America Replacment Retracts
- ARF Wrinkles ???
- DP Ultimate 120 Blue Test Flight
- Seagul Models Harrier 3d ?
- OK, how do you fix this?
- LANIER EDGE 1.20 CG PROBLEM
- ACE Sprit 3D
- 25% Sig Cap Tail gear help
- Frustration with Dave Patrick Ultimate 1.20
- Sig CAP 231EX throws
- How to set up Airtronics styl. radio
- world models ultimate 30 ARF
- O.S. 160 in C.G. Sukhoi ARF
- Phoenix FunStar???
- Dihedral Measurements for World Models P-51
- .2 sec ok for ailerons on 1/4 extra ?
- How would you fix this?
- Phoenix Sukhoi blues turned fortune!
- GP Extra 300 40, which engine did u use?
- Gee Bee Video / Photos Show Me!
- .61 in a .40 Pacific aeromodels edge?
- Snapping flying wires
- SKY SHARK - CHRISTEN EAGLE II Who Else Pre-Ordered?
- ARF manuf. engine recommendations
- How do you use Robart struts?
- CAP -X
- Idea for a prop jet
- Where can I buy ARF Prop Jets .40-.60+?
- H9 Xtra Easy 2 RTF flight time?
- Major problem with GSP Yak54! Need Help!
- CG Sukhol SU26MX ARF
- Which ARF is best for 2nd plane (Aerobatic)
- Great Planes Cub ARF
- AW 27% ultimate biplane ARF
- FuntanaS 40 wing bolt - sloppy fit
- ad skyraider arc
- Any opinions on the World Models Sky Raider Mach II (low wing)
- Sukhoi
- Anybody flying the Midwest Aerobat?
- Great Planes/Cosmic Wind-it's back!!
- picking a ARF for a saito .91
- Bought SIG Kadet Senior
- Is there bigger than 60?
- ARF's considered which category
- GP Piper Cub done!
- Capitol Flyer Speed
- Adequate engine for a Rascal?
- WHAT IS THE BEST .60 Trainer?
- GP Extra 300s .40 size
- SIG Somethin' Extra Modifications/Additions
- Building First Trainer
- H9 Xtra Easy 2 trainer and the Evolution engine.
- Zenoah G-23 ARF/RTF
- PROGRAMMABLE MIXERS 6XAs/T6XA
- WACO 60 U/C FIX + OTHER ARF'S
- MOVED: a few questions about glow plugs
- Ultra Stick Rebuild
- MOVED: Newbie Question
- "New" Lil Toni by Great Planes
- U-Can-Do 60
- Quick Fuel Valves
- GSP Extra 120 size
- Good ARF for Saito 90 Radial
- Crazy Pilots, where did they go?
- nuttin special
- GP PITTS AND PULL-PULL SYSTEM......
- Saito 1.2 on GP PT-19??
- Good plane for Irvine 72
- Funtana control throws
- H9 TCraft - Best price?
- Looking to buy - Tiger sport 40
- Best Warbird ARF Manufacturer
- P-51 1/5 Scale Maiden
- 69" Christian Eagle (Giant Planes)
- P51 Mustang questions
- Hangar 9 60 size P-51
- Any info on th H9 33% Extra(new)?
- GP patty Wagstaff wing tube
- UCD3D
- Funtana 90!
- GP Piper Cub aileron problem, NEED HELP!!
- Flaperons or not for GP Patty/9CAP?
- Lanier "Rebel" (parts missing)
- GP Pitts Special
- H9 Taylorcraft
- MDS 2.18 Glow engine
- sig kadet senior tail heavy
- World Models Spitfire vs VQ P-40
- VMAR Edge 540T
- KMP P-51 Mustang ANY GOOD?
- Lancair servo extension being detached.
- GSP 65" Extra
- Funtana or Vector Flight Edge/Extra help
- GP Gee Bee Robart struts
- GP Lancair $225
- GP Wagstaff ( Gas ) Owners - How much your plane weigh ?
- Best Profile arf????
- GSP 72" Katana vs Great Planes 73" Giles G202
- I picked up a GSP Zero @ Toledo today
- Lancair assembly problem
- GWS slow stick +
- Best kept secret in 60 size ARF........
- Help with Hanger 9 Cap 232 (73” WS)
- Kyosho Space Walker ??????
- Creek Hobbies 72" Katana canopy
- Sliced off nosewheel !?!
- New Great Planes Super Stearman 1.20 ARF
- Big Stik CG and engine mount
- Sneak Peak RCU Toledo Show Coverage!
- Extra 300S FINISHED!
