View Full Version : Aerodynamics
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15]
16
- Change of airfoil
- Open cowl flaps
- formula for wing loading
- Foam wing building
- Airfoiled stabs
- Rarely Explored Territory
- slowpoke 25
- Airfoil Design Software
- CG on forward swept wing?
- gull wings, advantages
- A-10 Flies Better But, Which Incidence?
- Load, Moment, Shear diagram sites
- Now this is what you call "Unrestricted Airflow" NOT!
- slotted flaps
- slotted flaps
- flat spin problems, what is causing this death spin.
- modified laser 30 %
- Stab. LE sweep and control surfaces?
- Aerodynamics Web Site
- wing joint over-kill?
- Endurance model
- Why My A-10 "Hunts" For Pitch Stability?
- Airfoil selection
- Ultimate Pitts
- From model to homebuilt
- Engine Torque
- Pulsing in a spin
- Glider Question
- Spoilers
- NACA Airfoil
- Spiraling Slipstream?
- High Quality (and Cheap) Airfoil Program!
- DP edge 540t vs DP extra 330l
- R/C DC-9
- Calculating proper dihedral
- Let's Talk Calculus
- Fixed Position Slats OK?
- Add flaps,how difficult???
- Long-range, Slow Low Flight Design(s)
- Revising the fuselage
- Pattern plane design construction?
- New release of Profili!
- Rotory wing aifoils
- Positive incidence on surfaces??
- At the risk of being dissed, I come in peace.
- Books on Ariplane design
- RC Propeller Question
- fuselage aerodynamics
- About wing lift
- "Airplanes and the Wind" article - any read it?
- High and Low
- Calculating Reynolds
- Does prop-pitch increase thrust ?
- ? about proping .61fx
- whats the best CAD program for RC planes?
- Angle of Attack
- Boost Tabs
- Tip Tanks
- Multi blade prop efficiency.
- Airfoil for TF - P-39
- Kit Bashing a Enforcer ...need advise
- What's the skinny on 3D wing tips?
- pics of flying car model
- Stabilizer area lateral vs horizontal
- Aerodynamics HELP!..
- making a R/C Uss Enterprise from Star Trek
- flaps
- barn door ailerons
- designing/building & flying for first time
- What is Washout and why?
- venturi calculation
- duration flight help
- delta foam c.of g
- Leading edge design
- Negative G on spoiler equiped aircraft
- glider airfoil
- Airfoil when cutting a swept foamy?
- Berkley B-26 Invader
- Why So Many CG Questions?
- how to determine cg on swept wing
- Weston Magnum Elevator Trim
- Modified All Star Bipe CG?
- At full throttle, it flies straight and level, but when flying straight up pulls to
- Clipped Wing Mustang
- Great Planes Profile Gee Bee Airfoil
- You've gotta love NASA...
- I built the fuse with the wing too close to the nose, what to expect?
- Wing loading?? Vers Aspect Ratio!
- Look at this page of links....... WOW....
- Urgent C.G. Plz read!!!!
- Stab positioning
- Engine Position
- Longitudinal dihedral (Ve)
- A Few Questions For The Experts
- Trimming out a bi-plane
- H9 Edge CG
- Engine Mounting Orientation
- GP Ultra Sport Airlfoil?
- Aileron Question
- GP P-51 aileron roll problems
- dihedral roll-back affect
- Measuring Airspeed
- Reynald's number
- Racing Stabs
- P40 Custom wing??
- Why 90" wingspan for Harriers/Elevators?
- Wing Design Software
- Pay load
- Center of gravitation... Who know????
- Airfoil suggestion.
- power off dive, nose tucks to belly
- Balancing question
- up thrust ..
- Incidense and thrust
- Zapp flaps?
- diahedral??
- Why check CG inverted?
- airfoil difference guestion?
- Proper Right Thrust adjustments?
- question for ollie
- S1223 with flaps?
- Help with prop thrust calculations (formula)
- Wing Loading????
- 1:5 Scale Yakovlev Yak-3
- Multi Segment Fowler Flaps
- A really great book
- Scale Wing
- Basics of R/C Model Aircraft Design
- Leading Edge Slats
- Airfoil Question For Scratch Built airliner
- CG of F-20 own construction
- gas tank effect on cg
- Help on thrust angles
- Vertical stab area
- Distance from LE of wing to Prop?
- S.T.O.L. flaps
- How to find the correct CG
- help on 727 airfoil selection
- Ace Whiz 40 trainer
- Nose Heavy
- ?incedence?
- Biplane Problems
- Wing Rocking during Harrier
- Adverse Affect when using the rudder
- Elevator Stall
- Tiger Moth - Real bucking horse - CG Problem?
- R/C space shuttle?
- Re: Tandem wing plane
- "Built-In Washout"
- right Thrust?
- wingtip vortices
- CG Help Please...
- Virtical Stab Location ?
- Rudder area above & below thrust line?
- CG location of invert V-tail and push engine
- Tight turns.
- Semi-Symmetrical Stabilizer Supplement Wing Loading?
- Datum lines & incidence might as well throw thrustline in there too
- wing length difference
- Wing and chord measurements
- got the moter going
- no ailerons???????
- CG ON JanR HANDSEL HLG
- Control line conversion
- WIng Loading question.
- How to Determine the Tail Volume Coefficient
- NACA airfoil designators
- Super Kaos Airfoil Information Wanted
- Wing design
- calulation for stabilizer area ?
- Autodesk Inventor
- Aerodynamic Turning Model
- Loops look like a cork screw?????
- Biplane CG Calculations??????
- Wind Tunnels For R/c
- Scanning plans into Autocad?
- Duraplane wings on a Sturdy Birdy
- Airfoil's
- Setting up cg on an arf
- Left rudder = Falling brick
- Flaps for my GP big stick 40
- Vertical fin area?
- single aileron control...??
- A question for the knowledgeable ones.
- Vertical tail design
- Aileron Differential on a symetrical airfoil?
- Everything you need to know about lift.
- General CG Calculation
- Help with airfoil selection
- Canard style plane and trans mixing?
- Amount of taper
- midwest extra 300 high speed stall?
- Delta CG determination
- CG expert help needed.
- Aileron tip plates
- thrust line help please!
- FSW (Forward Swept Wings) on a glider
- Airfoils for trainers?
- down-thrust
- Effect of Engine low to thrust line?
- plans for a camcorder carrying plane
- Engine low to thrust line??
- EASY SPORT 40 flutter
- Weighting and balance question
- What is aspect ratio?
- AeroDesigner - PRE-Flight Sim Model Builder
- Friese-style hinges (OK, maybe not... <g>)
- Mach tuck...what happens aerodynamically?
- Fan Wing
- Aerodynamics & Engineering
- Small scale aerobatic planes - poor flyers?
- rolling with power
- Knife Edge characteristics
- Engine mounted off thrust line a bit
- efficiency of 1 blade v. 2 blade props
- G-202
- UP Ailerons on Landing
- Smith Miniplane Incidences
- CG for a twin wing design (fore and aft)
- Adjusting CG
- Props + High altitude
- Dropping the engine down an inch??
- Airfoil selection
- Free Wind Tunnel Software ?
- Flying wing CG
- Lost canopy and knife edge is better??
- Spin tendency help...
- reynolds numbers
- Rudder Stab
- Deviation from thrust line
- Diabolic full flying stab....fluttering
- changing scale size for different engines
- G-202 split flap configuration
- absence of tail spin?
- plane reactions to CG
- wing area ?
- Work in PROGRESS
- delta drag
- Seduction Freestyle trim problems
- horizontal stabilizer dihedro
- Approximate payload for a Eagle 2
- Will shortening the original aileron length change flight charachteristics?
- Thickness tips section in relation to root section
- Giant Telemaster
- snap's out of loop
- Math problem calculating Wing Length to wing area!!
- DP 330 Ailerons Quick fix ? FOR fLutter
