- Junkers type control surfaces?
- Control surface trailing edges
- Control surface effectiveness?
- Thrust distribution
- Center of lift
- Clark Y
- Thrust line question
- airfoils of the same family
- Ultimate Biplane
- Weight/lift/thrust question
- Converting a low wing to a Bipe. General questions.
- Stabilator Questions
- My elevator idea?????
- Lots of Questions!
- Figuring neutral point on biplane
- Wing affect on horizontal stab
- CG on a swept wing
- What do you know about "T" tails I would like to know
- Methods for determining CG and thrust angle
- dual servos on elevator
- Anybody know anything about scaling?
- Effect of changing thrustline
- wing angle
- CG Change?
- 'Drooping' ailerons?
- MOVED: scratch building/engine selection
- Flat turn...Loss of lift
- Winglets in racers
- Flaperons
- Stall safety and tapered planforms
- Distance between wings for biplane?
- a great aerobatic flying video
- Low wing design faster than a high wing design?
- going to 33% from 60-90 size
- Tail question
- Biplane vs Monoplane
- Same Wing, Different Fuselage??
- Prop size and performance effect
- Thrust Calculators?
- Lift-Roll Spreadsheet - Clarify "Twist"
- Chart for relative wing loadings
- What makes a high wing "high"
- 25% of root chord.. Huh?
- Hangar 9 Aresti 40 ARF
- Biplane/dual control surfaces?!!
- Flying Thingz
- Pylon Airfoil
- H9 Arest 40
- One airbrake,no computer
- Calculating control surfaces pressure?
- Balance tabs AERODYNAMICS
- Great Planes Sporster-Ailron Prpblems
- Spinners: AERODYNAMICS vs WEIGHT
- Multi-holes drilled air brake : any good ?
- Sharp edges and drag?
- CAP 232
- Predator like wing
- Ventral Fin
- wingspan vs length
- Hangar ( P-51
- What Would Happen?
- Why Lifting Stab?
- Rudder control?
- Delta static margin
- FLOATER's
- Pusher design
- Stanford Wing Analysis Program
- V tail design
- ENGINE OFFSET
- Nervous Airplane
- ROLL TO RIGHT ON POWER UP
- Front wing airfoil in canard pusher
- This is a new one on me. Help needed.
- spitfire
- Elevator & aileron throw
- C G effects please
- Root chord for C.G. calc.
- Laminar flow vs. turbulant flow and visocity
- Trying to set up my Seniorita ** Please Help **
- Votex Generators..how do they work?
- GWS C-47 S&C
- Biplane Wing Incidence
- flying wing
- Wing span, weight, and engine size
- Airplane will not trim
- MOVED: what most people don't know!!!
- building F22 Raptor to fly slow
- Effect of modifying trailing edge?
- NOAA Aerosonde UAV
- CPLR's T- Tail
- WING LOADING APPROXIMATIONS
- Dihedral types
- Airfoil coordinates P-51D
- Deep Stall Recovery
- Airfoil Geometry (Sr Telemaster)
- New way to control roll?
- Airfoil Questions
- Rascal 40 Rolls
- EPPLER 423 x CP
- ENGINE OFFSET THRUST FORMULA
- Positive Incidence Definition
- Effectiveness of boost or offset tabs?
- MOVED: Nylon wing bolts - big airplane
- Swept Wing Flight Characteristics
- H9 T-34 and Flaperons
- CG calcs tapered wing?
- Airfoil help
- Rudder infront in canard design
- New project from RC Skunkworks
- f22 stabs and rudders
- Trimming For Landing
- Moving the CG aft
- Variable Lift Geometry Ideas
- SFG's and roll coupling w/ rudder?
- Canard lifting area
- Need rib help
- Polars for flat (non-airfoiled) wings
- why does my stick roll with just rudder?
- Aircraft yaws after cartwheel!
- Can´t get the static margin right
- Aspekt ratio (AR)
- Aileron Throws CompARF Extra 2,6m
- Need help trimming plane please
- Hinge line for ailerons?
- MOVED: Modelcad
- Pitch up with new prop!
- incidence on WM Tai-Ji 40
- CG vs Airfoil
- NACA 2412
- four star CG
- Help on wing design
- Flaperons to control snaps?
- knife edge?
- rudder problems
- My Edge 540T Rolls with full elevator application
- Engine placement/alignment????
- Landing gear help
- Incidence at Kyosho PT-17 Stearman.
- Wing tip engines + rudders.
- need delta cg
- I cant loop any more!?!?
- CG of F-16
- Lomcevak
- HELP!!!!!!!!!!!!!!!
- I have recently built the World Models electric P-51. I installed an AXI 2808-20. I am a very exp
- Stab and elevator size... need help!
- Replacing Midstar 40 Ailerons
- Symmetric airfoil
- just saw the movie stealth...
- Wing Loading for dummies..
- Winglets
- Does dihedral increase drag ?
- Leading edge slats-how to place?
- Ground Downthrust
- High speed tail surfaces.
- "6-10" PITCH PROPELLERS
- Combat airfoil
- Canister's Tunnel exit shape
- What fight charactoristics would you expect from a nose heavy plan?
- Dihedral?
- Lateral balance
- aerodynamic counterbalencers
- What exactly are Flaps used for
- Props
- Flaps?
- Roll Rate of Tiger 2
- Fix a Phoenix Giles G-202
- airfoil max thickness position
- Climbs while inverted!
- Naca 0012, 0009 file request
- question on angle of force modification
- extra 300 wings
- Ailerons, How they work
- Trailing edges
- MOVED: Building from scratch
- MOVED: control feel
- 2 stroke vs 4 stroke and CG problems
- Engine position and Thrustline/ CG on A-10
- Showmaster Camber/Dihedral
- erLeading Edge Crash Damage
- duck configuration pros and cons
- 110° Dry or Humid--power & Lift
- BME PROPS!!!!!!!!!1
- Help me tune the Pico Cub Roll - Adverse Yaw
- Questions about wing loading and CG
- Glider basic questions of AOA and airfloil selection
- CG point
- Stability/inverted stall issues with CG Sukhoi ARF
- X-wing Type Plane Possible?
- Effect of decreasing airfoil thickness from root to tip but maintaining the same camber?
- wing tip shape
- Canopy position for pattern-Why?????
- Tapered vs Constant Chord wings and wing loading??
- Bi-plane wings
- Could use help with AK Models Cub CG
- Engine/thrust to weight ratio chart
- Wing drop with vertical pull
- Wing Loading
- clark y and camber mixing
- CURTIS PITTS
- Tip stalls..... any fixes?
- Mass Positioning
- Canard Airplanes balance point ( CG )
- Tail volume calculation for CG
- help finding balance point???
- Wing Area & Weight
- Tip speed of a Prop
- Help with props?
- Airfoil selection for Newport 11
- Twin speed plane : faster or not ?
- Tip Stalling Airplane
- simple inverted flight question
- Rate Gyros for Automatic Control
- finding thrust needed for parkflyer
- "shrike" alterations
- MOVED: Me and my bro are arguing
- Engine mounting bad...
- Kyosho Cap 232-60 Breitling ?'s
- First Scratchbuild--need help with airfoil
- Standards for V-tail design?
- Su-27 L.E. flaps
- HIGH SPEED ELEVATOR STALL?????
- GP Extra 300S Reccomended CG
- 30%mac
- flight dynamics. noob.
- Multi wing design rules?
- Triming of aircraft
- MOVED: Flash Gordon/Buck Rodgers type flying model
- Vortex Generators
- Custer Channelwing
- F15 CoG
- MOVED: P-51 trailing edge spliting
- Airfoils
- Removing wing tips affect flight?
- calculate effective dihedral
- Calculating lift ?
- airfoil q!
- CG of a biwing
- Forward thrust reduced by too much right thrust?
- MIxed signals regarding wing loading numbers.
- PT 20 with flaps ????
- MOVED: Spar Location
- Mass blancing ailerons
- Ben Lanterman
- CG on Bi Plane
- My Spectra Tucked in and Ate It.
- Aerodynamic of undercambered vs. flat-bottom airfoil?
- THRUST
