PDA
View Full Version : Aerodynamics
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
  1. Air foils for Avro Vulcan delta wing 48"
  2. Need some feedback on a scratchbuilt design
  3. Improving roll ability on my GP Big Stik 60
  4. Engine thrust angles
  5. Wing Inertia - what is it?
  6. Help Please on CG for Extra strange anomoly
  7. Airfoil Question Heinkel 46
  8. touch n go airfoil recommendation
  9. Unknown c.g for two planes
  10. Will adding weight make my glider fly better in wind?
  11. my propeller makes a droning type of sound at times
  12. washout on a biplane wing ?.
  13. Need Help in the CG of my super-sport Electric 48"
  14. biplane wing incidence.
  15. Panukl Software
  16. Venom Reborn
  17. Helping Kids understand aerodynamic testing
  18. Will the cg change just by clipping the wing that rectangular.
  19. T-tail woes
  20. Help needed: CG of formation of 3 planes
  21. Dihedral
  22. Airfoil for a Airbus A320 -suggestions-
  23. Stol ch 801 /Sig senior kit bash
  24. What happens if I raise engine on air frame?
  25. Tapered vs straight trading edge wing
  26. Rudder angle and roll coupling
  27. Wing area help
  28. Hunting on Small models
  29. What does"crow" do for roll stability?
  30. Ugly Stik aileron differential.
  31. Difference between Tip airfoil and Route airfoil
  32. Unknown effect
  33. 46% ultimate biplane with 3.1 meter SU26 wing..Crazy ?
  34. Abrupt Takeoff
  35. engine thust
  36. trainer nose pitching up with gusts
  37. Don Lein FW190
  38. CG located on fuselage?
  39. To repair old BVM f-86 Airfoils...
  40. What will happen?If I remove dihedral from wing?
  41. Can a Delta Wing have flaps?
  42. Full Scale Flying speed vs scaled down RC flying Speed?
  43. A-10 aerofoil/ aerofoils
  44. Propellers
  45. Telecaster incidence problem
  46. Tapered wing without washout
  47. Landing speed increase with weight increase?
  48. elevator trim changes
  49. Roll Rate vs. Aileron sensitivity
  50. Pulling and tucking in knife edge flight
  51. 1/4 mac of swept tapered wing
  52. washout or different airfoils?
  53. scaling down propeller for a wind tunnel testing
  54. Figuring CG on a staggerwing?
  55. Tiger Moth incidence
  56. New wings
  57. PLTW EDD Preliminary Market Research Survey
  58. Wheel Alignment, how much toe is too much?
  59. Best lift-to-drag ratio
  60. Increasing Fuse length and Cof G
  61. Eurofighter airfoil
  62. Erratic elevator control...please help
  63. Toe out, Neutral or Toe in?
  64. Yak 54
  65. Need your opinion.....wrong rudder instalation
  66. Airfoil recommendations.
  67. Variable CG?
  68. Incidence problems using Robart incidence meter
  69. Sikorsky Ilya Muromets CG
  70. Attitude issue.
  71. Unstable in Roll
  72. HELP with some bad habits on my new plane
  73. Increasing wing size to lighten wing loading
  74. Setting ailerons to compensate a nose heavy airplane?
  75. Another Full flying pivot location thread
  76. corsair incidence (washout)
  77. C/g programs
  78. Center of Propeller in the Symmetric Plane?
  79. Turbulence Formations
  80. Bill Evans Shooter CG
  81. Left roll and right roll not the same.
  82. Questions following the maiden of a 1929 Travel Air 6000
  83. software for comparing the aerodynamics
  84. Propeller Pitch Speed vs Level Flight Speed
  85. Du bro spinner balance
  86. Center of Gravity for Pylon Free Flight Model
  87. Coding Aerodynamics in Games
  88. Air mass movement calculation
  89. Require Aerodynamic Help for a Uni.. Assignment
  90. prop planes can't do Mach 1
  91. Hollow foam wings?
  92. Dealing with a thrust/drag pitch couple
  93. Plane and Airfoil List
  94. Balancing a Model
  95. Odd CG. Is this right?
  96. Aileron configuration?
  97. Calculate propeller efficiency?
  98. Ultimate Biplane Swept Gear
  99. CG for Extras
  100. How to transfer CG from bottom wing to top wing on a Pitts Bi-plane
  101. Cessna Skymaster 337
  102. Wing Shape Question
  103. Design question for a trainer foam, please need help!
  104. Modifying airfoil
  105. Tower Hobby giant scale 4fu balance problem
  106. Cross wind take offs and landings
  107. Side Force Generators question (SFG's)
  108. FMS 1300 Sbach & Yak54 - Behavior issue i do not understand. Very annoying! :(
  109. CG with tank FULL or EMPTY
  110. Horizontal stabilizer is not horizontal. What to expect
  111. Airbrakes on flying wing to control yaw?
  112. Slowing Them For Landing
  113. 3 point vs. wheel landing?
  114. Airframe pressurization
  115. Difference between speed and thrust
  116. your favorite Star Wars aircraft and probability to make rc model of it
  117. How can asymmetrical planes fly?
  118. Boeing F4B-4 Questions.
  119. Naca Profile
  120. Interesting Aerodynamics experiment of visualization
  121. Air Force Museum error?
  122. Tail volume?
  123. Offset single engine
  124. Golberg Viking Center of Gravity
  125. winglets?
  126. Building a Heavy Lift aircraft
  127. DIY CoG Machine
  128. I have wing problems and I need someone with some intelligence and experience 2 help
  129. Control line plane conversion to Radio Control
  130. Wing tube location
  131. sig wondere
  132. Diablotin XL
  133. Air Brakes
  134. Fully moving stabelizer
  135. Spitfire
  136. Hangar 9 Carden 50cc Extra 300 flying in a nose high attitude.
  137. CG effect of moving tank from front to CG
  138. H9 Taylorcraft ARF Trim Problem
  139. Right rudder causes pitch up
  140. I value your opinions
  141. CG sling balancer
  142. CG effects on landing?? 90" Seafury lost on landing
  143. Piper Cub CG Question
  144. aerodynamic experts only question
  145. Flap to aileron ratios.
  146. NACA airfoils 63A series
  147. Small mods to an Balsa USA Enforcer...
  148. Aileron Differential
  149. RCU site upgrade/shift this weekend
  150. Effect of battery weight on CG
  151. Do props destabilise Aircraft??
  152. Adjusting Wing Incidence
  153. Foreplane to wing incedence on a canard
  154. Angle of Attack telemetry
  155. GeeBee R3
  156. moving CG around
  157. 2 gliders in same thermal one is circling normally
  158. Rounding Stabilizer Leading Edge
  159. Aerospace Degree
  160. how does steerable nose wheel affect aerodynamics?
  161. need help understanding my airplane flight characteristics
  162. MAC calculator?
  163. Aileron ribs not parallel to airflow
  164. Why ballasted gliders fly faster?
  165. Location of CG
  166. How much pitch control would elevons provide
  167. The Eternal CRAP about Center of Gravity (CG)
  168. Balanced Elevator
  169. Symmetrical Airfoil LE Shape
  170. Airfoil Design
  171. Slab vs Tapered Elevator
  172. Who can explain this? Hovering Plane
  173. MOVED: Phoenix Models
  174. Spiral slip Stream is it real ?
  175. Fold down GoPro on bottom of fuselage
  176. CG Calculation Differences
  177. Wing downwash calculcation
  178. How to find CG on unknown plane
  179. More Knife Edge Trim Stuff
  180. Winglets vs central fins on a delta speed plane
  181. STAB INCIDENCE
  182. Stuka aerodynamics
  183. great planes yak 54
  184. Swick Taylorcraft
  185. Which has the least drag ?
  186. do ailerons provide lift?
  187. Neutral Point Help
  188. cubic versus pounds per square foot ? Differences ?
  189. incidence/thrust line/engine offset
  190. question on airplane balance
  191. How to determine CG ??
  192. Sailplane design question
  193. Using Gps for speed without mixup - launch
  194. Vortex generators
  195. Flying Horizontal Stabilizer
  196. Low tail in turn
  197. Dynamic Soaring of Thermals etc.
  198. Is this DS or just Something else?
  199. Knife edge pull
  200. Looking for info on wash in - wings better soaring
  201. tail heavy wants to roll?
  202. RITZ 1-30-15 AIRFOIL COORDINATES
  203. Axial rolls
  204. RC Calculators
  205. downline braking
  206. ducted fan to propeller conversion
  207. Is left yaw induced by fore or aft force?
  208. Effect of wing and Horz stab not paralell
  209. differential ailerons in aerobatic model
  210. Scaling down aircraft
  211. Who's got the formula? centrifugal force applied
  212. Who can help with THIS one? Guru needed :) WILL PAY
  213. Ailerons not straight
  214. Stubby Fat Plane hates right turns!!
  215. why are the motors SO far forward?
  216. landing bounce
  217. Violent dive on rudder right - Fly Baby
  218. Having engine, wing and horiz. stab on a common centerline as opposed to having it otherwise.
  219. Whats it called
  220. Vertical tails
  221. trim question
  222. wing loading
  223. Flutter and air balancing
  224. Fuel tanks and CG's
  225. cessna 182 Control surfaces
  226. inverted flight question.
  227. why are wing tips UP , Down , or flat ?
  228. Wing type question
  229. WING ANHEDRAL
  230. CG On flying wing?
  231. General questions about XFLR5 software
  232. Equations for Pitch Speed, Tip Speed, CL, CD, & Some Crude Flight Testing Techniques
  233. CRAZY YAK 100
  234. Figuring wing loading
  235. New CG application that does multi-panels
  236. Airfoil data - which reynolds number do I take it at?
  237. Typical rpm of a propellor?
  238. Aerfoil data - drag and lift coefficients
  239. CG on a Royal Kit
  240. CG location when fuel is burned
  241. twin motors back to back
  242. Surface Damping
  243. All about Gamma (or k if you want)
  244. constant depth, tapered wing?
  245. Got a free wing, which creates a project idea.
  246. extra 260 maiden
  247. question about my 4 star60
  248. Beginner question regarding CG
  249. Not quite sure where to post this, so I start here
  250. Forward swept wing will it turn like a normal three channel?
