View Full Version : 3D Flying!
- Can I fly an Aeroworks Yak .90-1.20
- Looking for 3d Plane for Magnum 61 4 stroke?
- Moki 180 or OS160 ?
- What size prop for os 160?
- lanier 87" yak 3d cg location???
- any one have a FRENZY
- Funtana 50 vs. Pulse XT
- cowling dimensions
- Is 3D Flying Hard?
- What engine for Wild Hare Edge 540 73"
- e-Flite mine funtana X nitro conversion
- katana Knife edge?
- MOJO RIBS
- Calling U Can Do 60 owners
- Smoke?
- showtime 90 os 120ax
- I really need your help!!!!
- Saito 82 Tru Turn Spinner Which Adapter?
- Torque Rolling Q
- Fun fly question
- U-can-Do 3D 60 Size Servo Suggestion ? -
- A smoke system problem
- 3d prop size
- GP Patty Wagstaff with Hitec 5475 hb's?
- aeroworks yak 90-120
- EXFC in Czech Republic, 26th of August
- 3D Flying half time show...
- Seagull Edge 540 or H9 funtana
- 52" FUSION BUILD HELP
- edge 540 identification
- gyro ?
- Good .90 size plane?!?!?!?
- Would this work?
- Smoke On!
- receiver battery checker
- u can do 60 wheel pant question
- su-do-khoi 40 CG ?
- sd model 30% yak cg
- Magnum 180 vs. saito 180
- Nitromodels extra
- fliton inspire 60
- Matt Chapman Cap 580 .46
- Which Yak to use with my YS 1.10
- saito FA220, any problems mounting inverted?
- Need help with Yak Choice
- Prop Selection
- Showtime 50 vs. Funtana X50
- nitro planes yak?
- glow powered e-flite diamante?
- hanger 9 twist 40, i went electric anyone else tried it?
- Fromeco LiIon Batteries
- Profile pilots
- Review: SebArt Katana 30E
- Wildhare Extra 300 Prototype Video!!
- Saito 150 and 18x8 prop, need help!
- Servos for Twist 150
- Mojo 60 or moass 60?
- Extreme Flight RC seeks to add 2 pilots to “Team Extreme” roster
- Pull pull cross or not to cross?
- Saito FA91 adjustments- help needed!!!
- Cougar+saito
- Aviation Model (SD-Model) 33% YAK-54 --- Build Thread
- CMP Giles 202 140 Question?
- what size 2 stroke?
- Need advice on Engine Selection
- Aileron differential?
- need someone to fly with
- Which do you prefer for U-CAN-DO 3D 60
- Which Prop
- Plane Decision
- Great Planes Sukhoi SU-31 Performance Series ARF
- Okay, need to replace my Yak 54...
- Great Planes CG machine
- Looking for my first Profile
- Motor question
- Plans for 3D aircraft
- engine question
- All Seagull Model owners, Please help!
- Harrier 90 Vs Mustang PTS
- Hanger 9 Twist 60 fans and setups!!!!!
- Won's stop having bad luck!!!
- Flying a yak
- different weight on groovy 50 3d?
- RCU Build Thread: Aeroworks 1.20 YAK QB
- PA Edge 540T 84" ZDZ 50cc new video by Aerofun
- SOMEONE HELP!.
- New 87'' Sukhoi SU-26 Build and fly
- HANGAR 9 SHOW TIME 90 W/ YS 110 ??
- Showtime 90, Saito 125, 30% heli, sea level, what prop???
- Best 3d park flyer RTF
- Great Planes Ucando 60 cg
- tower uproar 40 3d?
- What To Do What To Do...
- Ultra RC Giles 202 29%, need help!
- Plane for OS 70 ultimate
- Knife Edge Snaps
- 3D ideas for YS120
- Snap rolls areilon or no
- Seagull Models Edge 540 CG
- prop or rpm?
- Super Tigre G-2300 and G-3250
- Which 3D starter plane?
- Somenzini Yak 69"
- Testing video of Extreme Flight Yak 54 (74 inch)#3 added
- Knife edge MIx vs. Torque roll
- Video of my Carf Extra 330S-150cc
- I NEED A PLANE!!!
- Will Hobby Yak 54
- HS-985MG
- Help me decide 35%?
- Need advice.
- If you could only build one. Showtime 50 or U-Can-Do 46
- How you fight against wing rock in upright harrier???
- 4 stroke fuel
- What plane is better?
- Jim Leroy killed in Ohio crash
- Giles 202 owners? Did I screw up?
- somthign that hovers?
- Feather Servo on Nitro Throttle
- 3d fuel
- U-Can-Do 46
- Make my mind up for me...
- OS 55 AX - Which MOJO?
- props for 3d???
- Hangar 9 Frenzy 100
- New plane from GP Sukhoi
- U know what move would look pretty cool
- Need a top 3D plane
- TANK SIZE
- best prop
- ESM/KMP Katana 2m, engine selection??
- edge 540t and o.s. 46ax prop question
- AV-8 Harrier II
- Gas Engine? Giles 202 140
- Bought a Hanger 9 Twist 3D 60 Today
- Summary on reactor ep/gp 50size?
- ANY OTHER YAK THAN THE QQ 102" 100CC
- propsize for o.s.91 on 8.38 Lbs plane
- Beginning to Torque Roll
- showtime 50
- Brand New Edge 540 OS 91
- ucando46 AILERON NEUTRAL POSITION???
- HYPE 3D
- RV-4 3D!
- Why Can't I Crash???
- P Factor and engine offset
- Tired of funtana x50, want knew plane
- is it possible!?
- How to teach an old dog new tricks?
- Cermark 260 and SPE 26, and some others.
- What prop for Hangar 9 edge 540 1.20
- Indecisions, Indecions....
- Tunnel flyer
- Great Planes Yak54 25% + 0S1.60, enough power?
- HS5955 and HS5985
- Does Anyone know this Yak54?
- Roll Out Issue- Extra 300s
- Are ya Yakkin? (small plane version!)
- Where to buy servos
- Split Elevator Mixing
- ESM KATANA (40)
- H9 Twist 150, anyone?
- ShowTime 4D 90 and a OS 91 FS
- Songs To listen To While 3Ding
- NitroModels Extra 260 50 - 53.5"
- H9 Extra 260 27% - DA50 Owners
- Saito FA91S i love it :D
- 55" WS 3D Hobbyshop Extra 300SHP Build & Fly Log
- Lipo's for Rx pack?
- What to get next?
- 3D Hobby Shop 55" Extra 300 SHP:
- showtime 50 help!
- GP Patty vs WM Patty
- help with U can do 3D 60
- aerofun extra 260 new video
- What Makes a Better Hovering Plane ?
- Which Yak???
- Prop selection for 3D
- U-CAN-DO 60 + O.S. 120 AX - Will work?
- Looking for 3D aircraft
- the best 3d airplane for begginer
- Beginner 3D Advise
- 3-D prop for YS .63s 4 stroke
- Mojo 60, UCD 60, or Fusion??
- Servos for 67" Yak
- How to post a video?
- Modeltech Sukhoi Profile Wood Built ARF
- Twist 60 vs. FuntanaX
- YS 1.10 new version vs. old version?!?!?!?
- Is a YS-63-S engine enuff for Kyosho Pitts S-2C?
- What prop for a supertigre 75 two stroke
- why so much pitch?
- What Prop To Use For a .61 O.S.
- prop shop in aussie
- Timing off on a Saito 91 will?
- Delete this post...
- MOVED: Servo issue....
- Seagull Models Razzle ...CG?
- YS 110 Idle Issue
- Best .90-1.20 Sized Yak???
- *RC Slang*
- New Muffler for O.S. .61
- FuntanaX 100 or Mayhem
- CMP Extra 300S
- Good plane for a .25 Glow motor?
- New GP Sukhoi
- funtana x 100
- YS DZ140 IN ADRENALINE 2M (HELP)
- Wing Loading
- twist 40 with saito 100
- single servo elevator anyone on UCANDO 46??
- 3D Setup need help
- U can do 3D,Aero-Works Yak .90-1.20
- MOJO question...
- Funtana X100 and Zenoah 20ei
- lets just say WOW!
- Battery capacity ?
- Need a new plane
- First true 3D plane choices
- starting out in 3d, crazy? or the truth
- FUNTANA X 100 + OS 120 AX + PERRY PUMP QUESTIONS
- search for 46 3d
- SD 260 or a Double Vision
- heres a question?
- Need help with 33% TOC Yak
- Seagul models harrier need help!!!
- Showtime 50 with YS FZ110S??? To much???
- tower hobbies uproar
- Fliton's email?
- Dual Servo for Elevator - Extra 330
- Learning 3-D, Glow Power or Electric
- Looking for gifs that show how to perform common manuevers
- Anyone tried ACE RC Digital Servos
- os 120
- best 3D prop? Anyone?
- Showtime 50
- NEED A PROP SIZE FOR FUNTANA 90
- 67" Fusion with OS 91 fx
- Twist 60 3d with 26GT
- E-flite Mini Pulse XT PNP for second plane?
- Saito 150 vs Saito 125 For Showtime 90
- funtana 100x with saito fa-150s ???
- Who Makes a Good Wood Prop (16x6)
- UCanDo 3D Prop Size With .55 AX
- Funtana X 100 vs Showtime 4D 90
- 50 size 3d??? Which one???
- Profile Suggestions
- aircraft, car and boat user gallery
- possible fuel delivery problem
