View Full Version : 3D Flying!
- Joe nall Newbeeee questions
- Spinner for 17 x 4w prop?
- Simulator and real life!
- Tower Engines
- I need a good Yak!
- How to Outfit this Profile 3D plane?
- Small rant about gassers
- waterfalls and elevators
- U CAN DO 3D???
- Is the 36 enough for the Tribute 3D
- Tribute 3D Plug N Play
- Does the Mojo come in a ARF
- Extreme Flight Chinn Yak 55SP - Tail Help??
- showtime50 help
- Plane for .46 two stroke
- new plane - what to get
- Inspire 60 and saito 91
- Funtana X100 with Zenoah G20EI Anyone?
- BME Cap Maniac
- Roll rate and aileron travel question
- HECKLER fromm Wing-Tote
- ys fz 140
- H9 Tribute, CG and expo.
- Best plane for 3d
- Carbon tube for Extra 330S 27% Greaplanes
- sig mayhem .40
- Laser 3D Sport from Laser Models - 46, CG ????
- seagull edge 540 with smoke :)
- Real Flight 4.5 3D
- Best 3d CF pushrods?
- os 120 ax what 3d plane to use
- Showtime 90
- Showtime 50 elect motor conversion
- Wildhare Baby Edge.
- How to improve 3D flying?
- Seagull Harrier 90 NIB. How much $
- yt tmtr katana
- Electric 3D plane for my OS 30 4 stroke
- what prop to use
- cg on qq 73" Yak
- Yak 54 74in - Gas tank and c of g help!
- The Funtana Lives!
- Looking for my first large 3D plane.
- Balance Twist 60 laterally
- Hangar 9 27% extra tailwheel problem
- Has anyone had problems with covering peeling off with a smoke system?
- Peakmodel Sukhoi SU 26 (68 inch) Maiden complete Video clip
- Showtime 4D 90, EVO 1.00NX what prop?
- Hangar 9 27% extra 260 w/ smoke
- Aeroworks Edge 540T. .46-.60 or Extra 260 .60-.90?
- Need help.
- Funtana X 50 SFG's
- need to choose plane for a da 200
- C of G for Ripmax Xtreme
- Single Wheel Caster to be used as a tail wheel
- 3D competition
- Video: Yesterday, I performed my first inverted flight!
- Fliton EXTRA330S 120C
- Seagull edge 540 60 size
- 3D/acro props for 46AX
- fading gas engine
- servos for 40 size Extra
- Best plane for the job ?
- u-can-do cg question
- Bling 3D flyies in tail down attitude all the time
- Wood prop advice?
- MoJo .25 build questions
- Seagull Extra 300S .75
- reactor 3d ep series to glow
- I get bored.....
- Mojo 40 or primo profile? will os 50sx be enough?
- True Turn Spinner
- Twist 3D 60 Prop question
- Got lift? whats your take off roll?
- Twist 3D 60 CG
- QQ & Wayne are closing shop
- Pro pilot?
- what servos for the Twist 3d 60
- Hoving 101
- Rc 3D Flying Videos
- Four Stroke or gas
- What engine would you pick for this plane?
- nitro planes yak 54-120
- Power box 40/24 and A123 batteries
- Flying foamy
- Opinions on the Aero-Works 90 to 1.20 Yak 54 ARF-QB Quick Build
- black horse extra 300s 60 -90 size
- Engine offset
- EF 58" Extra vs. AW 60/90 Extra
- Approximate weight savings: CF vs. Alum.
- Funtana X 50 and engine fitting help!
- Best all around 3d prop for chinn yak..one with saito 82 other o.s. 55 ax
- coroplast primo
- are zenoah engines good to prop hang ?
- flutter problem...
- Engine mounting on EF Yak 74"
- Whats a good 3D kit???
- Peakmodel 50cc planes?
- 3D training
- crrc pro 26 cc
- Do I need up or down thrust??
- SAITO 91sgk problem
- Altitude affects on 3d and other rc planes
- mojo 60 who sells?
- Funtana S40 engine
- wild hare 88"edge,anyone flying this plane yet?
- Extreme Flight 74" Yak 54
- new at 3D Fliying
- O.S. FS-120S Surpass II Pump Prop
- Saito 91 tank
- im not a plane guy, ima heli guy but thought you might like this
- spad Primo
- 3D prop Saito 125
- BEST TYPE OF PROPELLAR!?!?!?!
- Edge 540T 3D EP
- Showtime 90 4D discontinue?
- How to balance OMP Edge 540?
- Battery/Servo combo
- G4.5 Airplane Hover Training?
- weight verses size of airplane
- Vent tube length on a Saito 72
- New Carl Golber Ultimate. Is this a 3D ARF?
- Has anyone flown both planes: OMP Edge 540 V3 & Mojo 40
- What is needed to complete Mojo 40 ARF?
- engines for 3d
- what the differences of these 2 YAK54?
- Virtual Freestyle Challenge 2009 - check it out
- Nitro Models 69" Yak
- Which is the best simulator to practice airplane 3D ?
- Fliton Edge 540 Recommended Engine size??
- How much covering for Mojo 40 kit?
- RPM's out of 55AX??
- Extreme Flight Yak 68"
- Jeremy Chinn Yak 55 or OMP Edge 540
- Sebart Katana 30E too much built in Right Thrust?
- Extreme Flight Yak 55 good for learning 3D?
- new edge v3 omp problems
- Are the wings stalled in Harrier flight?
- OS12AX and Perry Pump
- Twist 60 setup for 3d?
- HAPPY NEW YEAR
- Gyro Help!
- Recommend 3D Plane for a OS 56a
- phoenix models yak 54
- Edge 540 v Glens 30% CAP 232.
- Seagull Models Extra 300s
- Recommend me a new plane!
- OS 120fs Four Stroke
- Nitro Andrew Jesky Extra 330s
- glow andrew jesky extra
- Typhoon 2 Wing bolt
- tips how to do rolling harriers
- Improved Nitro Planes Yak 3D 56
- Electric Mig hover
- Seagull Models .60 Yak 54 57" wing
- witch Engine should I use?
- Airplane design
- Making turns during rolling harrier
- prop for U Can Do 3D .60, os 91 fx
- Catching AW Extra 260QB 50cc in Hover
- Funtana X50 with supertigre gs 45
- Favorite Edge 540 ARF?
- What can i expect?
- mojo / primo setup
- os.91fx (RINGED) what prop?
- Austars Model "New 75 inch/28cc Edge-540!"
- Nitro Models Aerobatic Extra 330 90 3d 63" plane
- 3D sim
- learning 3D
- Getting into 3D foamy
- Modeltech 3-DEMON, FORMULA 3-D, or MAGIC 3-D
- Check this out
- H9 Funatana-50 VS. H-9 Showtime-50 ???
- Will Chip Hyde resurrect model design?
- 3D plane for a OS 120 surpass pumped
- new plane
- O.S. 61 SF what prop?
- Nitroplanes Edige 540 .40 size
- Belly-In Hovering
- Seagull 300S 75
- will this engine fit?
- 3D flying
- 3D Prop Guide/Chart? GP UCD60 w/ Saito 91?
- twist 40 with saito 72
- engine help
- Opinions on Beginning 3D planes from Tower
- 3D help - will it hover???
- aeroworks 90-120 yak QB
- Indoor flyin
- NOW PICS !Twist 150 CG? Maidened my Twists Pics!
- Hobby King's Yak-55 3/D Monster
- My first Moass Mojo 60!
- Finally Maidened the Edge 540t 25e!!!
- set-up in electronics [ servos] etc
- Aeroworks yak 90-120
- If you could have only one 3D plane which?
- Spinner weight?
- Help identifying a 300s
- 3d plane for an ax 55
- CA Models Funky or OMP Yak 47" ?
- GP Reactor 160 similar to Chip Hyde Vision 3D?
- New Aeroworks .60/.90 Planes
- sunny hobby? anyone?
- Hyperion Edge 540T 25e [my builld]
- Wing rock?
- Nitro Planes 2008 Yak 52 3D 50 - 56"
- Airplane prop on heli motor-How?
- PROP HELP?????
- Long servo arms or short control horns?
- Tower Uproar Mods.
- Manual needed for Minicraft Whizz/Hanger 9 Pizazz 40 ARF
- servo to control rod options?
- Yak 54 Which one?
- Great Planes U-Can-Do 3D .60 ARF
- Great Planes Performance Series
- tower uproar ?
- 3 position switch
- Expo settings for a Mayhem 40
- 3dFLY?
- Gyros
- Saito 125 or YS 110
- extreme flight yak or ultra r/c katana?
- Seagull 540 68" gasser engine for 3d evo 26gx
- First 3D Plane (servo help)
- Newbie in YS engines
- Help me pick a 3D plane.
- Need build directions for a Katana mini
- Seagull ultimate 46 with ys 63-s
- Peakmodel 30%EXTRA330L
- Profile for a ys 63
- Twist 150 servos
- MOVED: Servo Torque - Please help!
- 46 size edge 540
- extra 260 from Abell RC
- 1st 3D plane for an TT f75s
- servos for a Extreme Flight Chinn yak?
- lhk yak 54 CG
- Twist 150 engines?
- Aero-Works Yak 54 .60-.90 Size
- Seagull edge 540 .46 size CG?
- 3D/Floater for a Saito 100
- Great Planes Ultimate Biplane ARF 1.6-1.8,65"
- what servos for mojo moass 60?
- New video of the Hangar 9 Su 26MM
- 3d foamie
- 3d for .91 4 stroker??
- I have, NO Mojo
- TBM's 23x8 Prop
- 3D plane for a Brison 3.2?
