View Full Version : Batteries & Chargers
- Megapower lipo 11.1V
- Is this a good battery pack?
- how to power for cellpro charger
- Bad cell
- Triton Jr charger question
- Xcite Battery
- Is 6.0V Needed for 2.4 (W/ Dual Packs) ?
- Duralite 6V/7.5A regulator
- E Flite Blade CX Battery Problem
- How do you connect / charge Thunder Power 2-cell?
- How do build shotgun pack??
- A123 radial
- FMA 4S Charger Power Supply Requirement?
- Thunder power 610C charger experience
- t-15 all in one charger with balancer
- LIPO HELP low voltage question
- How I connect two MPI switchs with one A123 battery
- What does 'C' mean?
- A123 implentation question
- battery experts needed
- simple power supply defect
- Quick charge Nicd charger >Nickel Metal Hydride
- Airsoft charger
- Where to buy a single Ener-G cell? - Need it fast!
- 2 cell 20C pack
- 10S 10A 200W Charger/Discharger built-in cell balancer (CY-1010B)
- tenergy smart charger
- Tower Hobbies 420 charger with scale question
- Where you buying?
- Team Brood Ener-G cells suck (as does their customer service)
- Lipos wont take a charge
- Sirius Charge Quad Plus really safe to use?
- Elite HR-1500 Real Capacity
- Charging Nimh's? (Hydrimax)
- Charging question
- Voltage of 5 cell rx pack
- Help: Hissing Cell!?!
- Lipo Balanacer
- charging problem
- 3D Plane Receiver Battery Problem
- Accucycle Computer Interface
- Safe to remove heatshrink?
- LiPo/Hyperion question for the masters.
- What Brand of Lipo Do you use and WHY?
- mAh for trickle charge.
- Flight Pack 100% Balancing ?
- How much power drain from 12V battery.
- Charger for dual 7 cell A123 pack?
- Balancer for Zippy lipo?
- *Hangar 9 Sure Cycle*
- What causes lipo packs to swell?
- Starter Box charging Question
- Art tech 182 Crash
- Battery Pack for 12 volt starter - not enough juice
- A123 charger adapter for LiPoly charger
- 12-Volt, 5A. DC Power Supply For R/C Battery Chargers
- A123 Battery for ignition system
- Tx/Rx charger confusion
- FMA 10S won't charge A123 thru Node Connector
- Yeah Racing LiPo
- Vision Peak charger stops in mid cycle
- Battery conn Tam vs Deans, TRX
- Help please, charger that will plug into 115V wall socket
- 6 volt 1800 mah oack question
- DuraTrax Piranha CX-10 AC/DC Fast Charger
- Lipo storage charge
- Sky Rocketing battery price
- looking for a fantastic AAA/AA/subC/D charger
- IB4200 Battery Care?
- New to RC - New to Battery Charging
- Venom Pro Charger with Power Supply [VNR0657]?
- how do you make a hump pack from AA batterys
- Understanding Duratrax Ice, confused on all the options
- charging NMH on trition
- Don't toss those LiPo's out Yet
- Can I use a Li-Po charger on Li-ion batteries?
- Charger to embed.
- A123 Charger
- Seeking Charger Recommendation LiPo/NiMh
- Glow PLug Problem
- Which of these chargers is better for me?
- Will a NiCad charger charge my NiMh batt?
- ProMax Black Widow Pro Peak Charger
- 15C? 20C? Whats it mean?
- 8.4v 7cell charger
- the right rx battery for my setup?
- Will this work in my Kadet Sr Hobbico HydriMax 4-Cell 4.8V 750mAh
- Shoud I toss my Mystery battery now?
- Charge voltage question
- cellpro 4s safety code?
- LiPo charging extensions
- Lower voltage battery for Mini T
- hyperion 1210i - repair
- lipo for reciever pack
- Which charger is better ?
- Hangar 9 Sure cycle question
- Replacement cover for alpha 4?
- Are balancers a necessity?
- LITCO ALPHA 4
- A123 Pack Applications
- Load testing A123 batteries question
- i4c products
- Mega Power infinity 960 SR
- triton jr?
- Duratrax ONYX chargers
- 12v lead acid acting weird, dispose of it?
- Ouick field charger..no clue
- Accu-Cycle Pro for DX6I TX
- DBC-14 wired to RC car lipo?
- FMA Direct Cell Pro 10 Charger
- Cell Pro 10 Charger Duplicate Thread see other one.
- XTM X-cellerator car receiver battery
- Lipo pack for JR 10X TX
- UPS or Backup power wiht A123 system
- Bigger battery or parallel setup?
- Problem w/ Hobbico Charger or not?
- HELP PLEASE!!!! ANYONE! need a balancer.
- 1600mah ?
- Robert Suding Ultimate Charger II
- CELL PRO 4S
- What batteries to use with Mamba Max 7700
- Is anybody has a picture to how to install the new A123 batteries?
- new sanyo ni-mh/alkaline hybrid battery
- Tourers that fit A123 (2S2P) Packs & wat mods if any?
- how to freeze a nicad pack
- What charger do you recommend?
- shrink wrap for A123 ???
- Charging A123 Batteries
- cell spy
- Connect two LiPo Battery (7.4v and 11.1v)
- Wal Wart Voltage Question
- Lipo charger and balancer selection help.
- A123 Batteries and Futaba Servo/Receiver
- LRP Pulsar 2 Competition charger: best setup?
- LiPo voltage drop device
- Help with A123 Kodiac switch to reciever
- Questions on A123 Batteries
- Different voltage readings on same charger?
- Help restoring Capacity Nicd
- Did I screw them up?
- What Regulator
- Portable Car Starter Battery Charging
- How do I calculate the remaining capacity of my batteries?
- balancing lipos
- When the batteries say to stop flying.
- Small 18V pack??
- Looking for a way to fast charge glow igniters?
- Flightpower LiPo's
- Anyone use the new Airthunder packs
- A123 Or M1 cell question
- Max Amps 5000HV 2s 7.4v lipo pack
- lipo basics
- MAX AMP 6000
- Sanyo 1400 AE battery problem
- does size matter? (newbie)
- Question about Troybuilt Models Li Ion
- LiPo Storage--Advice Please!
- Charger Schematic, Ace HD-500
- Unbalanced NiMH's?
- Which batteries to go with?
- Battery Pack Construction in San Diego
- Batteries Buzz While Charging (NiMh)
- Noob at building need some advice
- TP 2070mah LIPO question
- Orion vs trinity lipo
- NiCd 1000 mAh Voltmeter Reading Strange
- Battery cycler query
- Mystery Lithium Battery ?????
- high capacity AA NiMH questions
- Please delete
- IntelliPeak ICE HELP PLEASE
- Is it OK to use Nimh AA's in a Transmitter?
- 12 volt code
- A123 solution for rx pack
- Can I put 2 7.4 LIPOs together to get 14.8?
- faulty Eagle Racing CDC v6.0b
- The impossible Charger
- 'VoltWatch' LED Battery Monitor - Should LED's Flicker ?
- Giant scale electric power with A123's
- Lipo balancer for ICE charger
- Should I let my batteries cool before throwing them on the quick charge?
- Discussion - New Bantam BC6 reaching temps of 113F while charging
- Charging A123 cells with astro 109 upgraded with a123 chip
- Duratrax IntelliPeak ICE opinions?
- 9.6V batteries......
- Elite 1500 2/3A cells the highest capacity of that type?
- lipo alarm?
- 183 peak Amps recorded in rustler
- Who sells 1s lipo's?
- Duratrax DTX4200 or Ener-G 4600 Sport or ProTek 4200 Speed - help choosing batteries?!
- gel cell lead acid 12v 7ah battery charge
- Problem with Cameleon 33od
- ** Damaged Battery?** Please Help!
- Is it safe?
- Charger Problems
- Battery Break in for IB4600
- Do I have to fully charge my LiPo?
- which charger
- Charging a 3600 nimh pack @ 300ma?
- BANDIT - NOT VXL version
- Astro Blinky, Common Sense V2, and you!
- Do NOT use cheap cells with brushless (they just exploded/vented)
- How to Revive NiMH batteries?
- Is it safe to fly....?
- Charging CR123A cells
- question on battery charging time
- understanding batteries
- Stupid newbie question: What does IB, EP, GP stand for?
- brand new whiplash 1400 battery pack what should i do first???
- New charger destroyed my batteries.
- LHS Stocking CSRC
- Ace AT 2000
- Sidewinder/5700kv needs juice
- chargers
- nimh charge rate
- nimh charge rate
- Is my battery still good?
- 8C 11.1V 1250 mAh ooopsie!
- rx battery upgrade
- Question about a Schulze 6-330d charger.
- Got new batteries, Now I need to upgrade my charger
- NICD Recycle Batteries - When to discard
- Thunder power lipo question
- Fast Charger 11.1V
- Duratrax ICE settings for 3600mAh 6 cell
- lipos charge discharge
- Club Deans Fusion 4600mah
- DIY battery discharger
- Lipo Pack Orientation
- New type of lithium battery you can charge at 2-3C.
- Just an Idea...
- Hangar 9 Spitfire MkII .60 and a123??
- 3300mah battery only charges to 2600/2700mah
- Best Battery for my Buck?
- Venom lipo problems?
- A123 Rx Switch Choice...
- Lots of choices here for charging ...
- NiMH self-discharge rate
- Old Li-ion testing / cycling
- GE Invests in A123 Systems
- Dual lipo receiver set up...
- NIMH battery weights
- Dead lipos
- Xtrema Charger vs CellPro for A123.....
- Charging Trinity EP4600 6C Zapped Stick Pack.....
- Parallel RX Battery Sizing & Nicd vs Nimh
- NOKIA BL-5C phone cells, any experience?
- charger availible now
- Any suggestings on using pull start with body on?
