View Full Version : Batteries & Chargers
- NiMH proper charge rates?
- Charger for my spektrum dx7
- Battery for hobico torque master MKII
- Battery charging problem
- Is TP aka as AET?
- CHARGERS
- charging 9volt rechargeable
- LiPo Charger Balancing Tap Question
- 4200 intellect build
- venom problem
- However hard a human can kick himself in the face, I'm doing it right now.
- Drain rate to voltage comparison/Best cells and names sold under list
- Whats a alright cheap ac charger?
- Duralite and FlightPower
- Blowing Fuses in my parkzone chargers,,
- blowing fuses between thunder batt and parkzone,
- Ooops! What damage did i do?
- Field charger for RX packs
- V-Balance Question
- Super Nova Deluxe /Mega Power 960sr Owners
- bat checkers - simulated load
- Older Triton chargers....
- rc18r or recoil
- Balancing LiPo packs
- Team Orion 3200 Lipo question
- can a simple discharger be made?
- dead lithiumios
- Newbie needs help with charging Tamiya to Deans
- Multiplex LN5014 charger PROBLEMS
- A123 Receiver packs
- high capacity nicads
- Minimum required current for charger to work.
- An odd glitch- explanations?
- Supernova 250S & 12 V Battery
- dischargeing a 6.0volt 5Cell pack
- nmhi vs nicad reliability
- Yuntong 4300
- Lipo Battery For Castle Creations SideWinder
- NiMH Charging/Discharging Battery Formula
- New 123 user...HELP
- Looking For LiPo Balancer
- What could I buy/rigg up to charge multiple single sub c-cells?
- Which battery pack?!?
- Discharging Lipo on a INDI 16X5v6
- 2S to 6v lipo regulators, heat a concern?
- Power Supply Help
- How to use Super Brain 989. Any battery charging rate chart?
- First Charge?
- Burning wires
- LiPo charger and NiMh
- a123 balancing question
- Need some help with new charger and new battery packs
- 2s / 2s2p - What Is The Difference?
- How you determine bat size?
- mAh ratings bogus?
- Built my first battery packs from scratch
- question on cell type/charging/assembly
- what discharge rate for 6.0v 1100mah Rx pack?
- Charge NEW 3800 NIMH with Dynamite Twin & Prophet Charger??
- Balanceing lead
- nicad battery charge with multiplex LN5014
- TP proprietary balance tap- Converter?
- Where to find 2500 mah NIMH batteries?
- Alpha 4 resale value?
- A123 customer service
- A123 2300mah from sincity jets
- Convert a 7.2V stick pack to saddle packs?
- Battery life expectancy?
- UK NiMH charger help
- cell types?
- newbie electric questions
- noob! need help with my polycharge4 charger
- Correct charge time Ni-Cd
- Transmitter pack for Spektrum systems
- What is the best charger to charge multiple LiPo packs at once
- Charger Suggestion???
- Please comment on astonishing lipo readings!
- venom Ni-MH 5000 mah
- Thunder Power lipo with Triton2 charger Help
- Lipo Battery adapter
- Attaching Thunder Power Balance Connector to LiPo Batteries
- Tenergy 3S 2150 15C CBA Curves
- Why not charge at a 2C rate??
- Ace RC DDVC Charger
- Hyperion charger problem
- Sonic charge error???
- Affordable charger that charges 2 batteries at the same time?
- Pihrana digital peak charger
- power supply
- Bad instructions for a charger lead to a suicidal battery
- Lead-acid battery charge state
- Battery charging question
- Duratrax Ice Please Help
- Triton charger and lipo questions
- Can someone tell me if this is possible?
- Maxpro X6 Intelligent Charger
- I want to charge multiple plane recievers at the same time with one charger
- A new (Tower) charger?
- Need NiMH Battery Help
- "C" rating criteria of Lipo packs
- Lipo parallel charging HELP
- Deans Connector Tip
- A123 Brick Packs
- Anyone used a Thunder Power 610C charger ?
- Stock Charger w/ 7.2 v 1100 NiMH battery
- Trinity Reference 8.4v 7 Cell
- 6 cell radline, 4AAA and 2AA??
- Converting 7.2v 2200mAh Lipo into a 3.6v 4400mAh ??
- Cheap LIPO charger
- Piranha Digital Peak Charger + Nimh AA cells help
- Lipo balancers and balancers connectors.
- TP eXtreme V2 lipo, MRC 989 and Astro Blinky
- Accu Cycle for charging 700 mAh nicad battery packs
- Conection problems charger-battery
- What Charger?
- Elite 4800 LiPo
- Tritton II is not enough
- Are Maxforce batteries any good?
- Lipo battery multimeter
- Bantam BC6 or Hyperion 0606i
- ni-ma ni-cd help.
- United Hobbies Lipos?
- Turbo 35 Bl - Anyone Use This Charger?? Having a problem- please help!
- New!! Bantam e-Station BC-610 Charger!!!
- battery for starterbox
- Check this Vid out of my Rustler with 6s1p A123
- Duratrax ICE Question
- 50 cc
- Making list of A123 chargers
- LiPo Voltage Regulator for Reciever.
- Fromeco Regulator Setup
- how to make a homemade nicd glow driver charger?
- Good Chargers
- TP730-3JPL = No Balance Tap?
- Accucyle Charger question
- Low mah vs High mah
- Cycling JR Tx batteries
- simple battery question
- A123 in my starter box?
- Hyperion eos 5i fully charged ? discharged ?
- Triton+Dapter for A123?
- Step down from 6v. to 5.2votls????
- Balancing Lipo's?????
- Vision Peak 2 And Revo3.3
- TP210 balancer problem?
- Problem With Charger
- discharging lipo's?
- Very odd cycling results...any ideas?
- Accucycle trickle charge problem
- Looking for reliable, no nonse 6.0v high mah NIMH flat pack
- Looking for lipo CHarger and LIpo
- can you re-peak lipo?
- lipo balance connectors
- Bought a MRC Super Brain 977 and would like a balancer.
- I need some insight with my batteries
- Nimh Batteries will not hold a charge after 5 years of storage
- Toast ! (NiCd 9.6v 600 mah)
- E-flite battery issues, did I fry them?
- Brain is not working
- Charging VPX batteries
- Ni.Cads not in use
- Charging 6.0 with 4.8 charger
- Questions about LARGE 720 M1 cell pack...
- Batteries for E-Firestorm
- Dual Battery Charger
- Thoughts on this charger for A123?
- a123 M1 voltage specs 3.3v or 3.6v?
- Building packs for Traxxas Rustler XL5 - 2s2p or 2s3p??
- Am I under charging my batteries.
- Cycling & a Pocketlader
- getting into mini electric rc
- can I do this?
- black and decker charger?
- Need quick help on this charger.
- Something I found out about my Hobbico Accu Cycle
- straight vs. balance charging lipos
- Accucycle and NiMH batteries
- battery selection with digi servos
- I need a cheap Fast Charger
- Best Charger
- CellPro DPM HELP Please
- need help fast please with a power supply and charger
- Please Help Re: What Lipo?
- 2 vs 3
- Dymond Modelsport Lipo's?
- Would this be a good lipo setup?
- any health hazards?
- charging a123 pack with nimh charger?
- DC power question: FMA cellpro 4s charger
- Lipo charger question
- New NiMhs
- A123 Failure Modes
- High AH/C Lithium Polymer Batteries - Milwaukee / Emoli
- Can I charge a NiHM Battery with a NiCad Charger?
- What connecter is this called?
- Using a Lipo 3.7v charger on a 7.4 batt?
- Are my batteries shot?
- CellPro 4S Charger Attachments
- which is better
- Triton 1 Question for Lipos
- Rx battery question ... 4.8v or 6.0v for .46 size
- r/c 1/24 and 1/16 tanks
- Alternative Uses
- Uneven Lipo cell discharge (3S), Problem?
- Duralite & Orbit Pocketlader
- 6V 12A charger help needed, suggestions
- Charging a Dual Battery Setup - Question
- Manual settable charger?
- A123 Batteries Vendors
- GP 3300 MEC tube project
- Looking For a Neew Lipo Charger???
- Xtrema or Cellpro 10
- New to this please help!!!!
- Whats the deal ?
- charging batteries in cool temps
- Custom wiring from my charger to my batteries
- Homemade charger
- Triton charger & LIPO
- TRITON 2 SAFETY TIMER
- Trick Hobbico MKII to switch to trickle?
- My opinion CSRC
- Charger for A123 cell
- Need some advice on charger
- Question-Digital Peak Charger with NO Cell Count Option
- LBA10 in network mode
- Charging two gel 12v cell batteries wired for 24v
- Is the MRC 977 limited?
- What resistor do I use to check battery with VM
- Pleaces to get A123 batteries?
- Prodigy batteries
- Battery and Charger Questions.
- Ain't she pertty?
- Someone want to do some leg work? :)
- Longer life batterys
- Best balancer for my Super brain 989
- MRC Charger Enough!
- team orion 4800
- What batteries are best?
- Looking after Lipo batteries
- MRC 959 amp ?
- 7-cell 4500mag 1st charge resulted in ..
- imaxb8 power source?
- beware
- Pro max 885600 charger
- Memory Problems & initial charge
- JR Battery Packs
- Don't get those A123's Quite Yet
