View Full Version : Batteries & Chargers
- Battery bars
- Replacing Tx and Rx batteries
- Triton Jr Charging question
- Sealed Lead Acid Battery Correction
- Laptop Lithium Battery Fire on YouTube
- Does Backup have to be same as primary?
- Battery Choice
- Triton2/Accu-cycle power supply
- Best Charger ??
- ni-mh vs. nicad
- Battery Heat?
- Battery Storage
- Peak Sensitivity Settings, Triton.
- CHARGERS
- Will this setup work, or it will go on flames?
- Regarding possible Lipo damage
- battery connector
- RIPMAX CONSTELLATION CHARGER HELP
- Intellipeak ICE LCD backlight?
- Banana Plug power strip...will it work?
- li po batteries
- NEW TO R/C BATTERIES FOR TT01
- What battery setup in my 35%,,,
- Power supply question?
- ruined pack
- Giant Scale Battery Questions
- NIMH mah Help
- 6.0 Volt batteries question
- Difference between 1.2v and 1.5v AA's
- Receiver Nicad Pack 600mA
- Li-Ion Safety Concerns
- Hydrimax hype?
- JR Battery??
- Duratrax Ice problems
- Dream Battery center
- Need Charger Schematics!
- platinum ex charger
- Dischargers
- Question about a accu cycle
- CommonSenseRC at Tower's Website
- discharge limit for 7.4 Li-Ion
- Balance charger Vs. seperate balancer
- best charger?
- 1.5 volt NIMH AA batteries?????
- MRC SuperBrain "989" Charger
- NEWBIE HERE! Battery Question
- Question about different balance plugs?
- Will this work??
- Sirrius Quad or New Hughes Charger?
- battery pack getting hot
- Can I Charge 12V through Power Panel
- Astroflight 112D Upgrade Chip?
- Park Flyer on Crack
- discharge rate multiplex ln 5014
- Battery pack creation and charging
- cold weather lipo charging
- T-Rex 450 - Updated Turbo Module - New Test Results
- can a123 systems be float charged?
- charger?
- New Bantam e-Station BC-8 Balancing Charger
- Cold temps and NiMH batteries
- GWS MC2002 Charger Use
- Removed due to double post
- Another foamy question
- Anyone use 4 step charging on their ICE?
- making balance connectors compatible
- Battery Soldering
- FMA Products now available at factory-direct prices
- Newbie question!Please please help!
- Battery question...of course
- RX TX batteries, why NIcad?
- Question for the li-po geniouses
- FMA is OUT of the LI-PO Biz????
- Milwaukee Power Tool Li-Ion Cells
- REPAIR? M.E.N. Model Engineering of Norwalk
- Power supply- question,
- Comments and Suggestions
- Ultramat 25 Timer
- Cell balancer question
- Duratrax Shark 1500mah
- Duralite Chargers keep burning out ....
- battery connection
- Li-Po Problem
- which leads go where
- Problem charging Hitec TX
- charger recommendation for a 10 cell 2/3A battery
- Transformer, AC Adaptor, Power Supply ?
- Charger for under $100?
- Charging Lipos
- Strange battery charging phenomenon
- Balancing series cells in custom pack arrangement?
- Is it ok to charge Nimh battery packs with wall chargers?
- tank with a naff one
- "Forming" charge with a Triton
- Three wires on battery lead???
- Thunder Power Pro Lite problem
- NiMh for electric flight
- Cellpro charging problems?
- Temp probe
- hanger 9perfect peak charger prob.
- Lipo Charging Question
- Hyperion EOS 7i...first impressions
- Help in Afghanistan with A Eflite Pinnacle+ !!
- HYPERION BATTERY CHARGERS
- Triton; Up In Smoke
- batteries don't last HELP
- Buiding a battery pack
- Hyperion ESO 7i Charger Backlite?
- question on and add balancing plugs
- I screwed up....need some Lipo help
- Accu Cycle Elite and my Battery
- Charging sealed lead calcium batteries
- LiPo charging ??
- JR Battery pack revive
- Integy Zero-Thirty What does it weigh?
- Simprop Intelli-Speed
- AccuCycle Power Supply Question
- Seaplane batteries
- Chargers cell limit question ?
- where to buy lipo cells
- Reconditioning large batteries?
- upgrading Futaba 9C Series
- Battery storage
- Microlog Software
- NIMH CHARGING
- Is there a LiPo "reference" thread somewhere?
- speed control or engine trouble
- Saphion battery. Good or a waste ?
- Is a balancer required or recommended?
- Voltwatch 2 settings 4.8 vs 6 volts
- New to Lipo's need some advice
- which batter charger!?
- Hyperion Balancer
- how to charge a 12volt battery?
- does the lipo fit the batt tray?
- 4.8v vs. 6v receiver batteries
- Accu-Cycle
- Can a LiPo be left connected to the ESC.
- Charger exploded
- old rc battery?
- Team Orion Avionics Advanced charger system
- Recommendations on Cellpro 4s vs. TP 425/205?
- AccuCycle Elite vs Triton 2
- 4.8v - 6v receiver pack
- Accucycle Elite
- Finally-a decent job of soldering
- What batteries to buy??
- Electric Conversion Sig Four Star Forty
- PC ATX Conversion Schematic
- Recomend a 14v NiMh Ac Charger
- Can I use this to form charge 3000 mah NiMh's?
- LiPo help: same voltage..but 1/4 the amps
- LiPo: same voltage..just lost all capacity
- Losi 8 LiPo pack?
- Losi 8 buggy LiPo pack?
- Losi 8 LiPo pack?
- Triton Charger
- battery pack info.
- A123 & Moli Lithium packs-construction
- What is the lifr span of duralite battery?
- needle help
- powerflite batteries
- What should I do right off the bat to brand new IB1400 8Cell pack?
- Scared & P!553d
- In line lipo voltage cutoff in NiCad application
- Need help choosing a charger
- Are my mAh calculations flawed ?
- Can someone pls help out
- hey, can I convert my quake to fit rc18t packs?
- New to electrics, just a few questions.
- Watts up meter or Whatts meter?
- Nickel batts vs. NiCads (weight savings)
- 11.1 vs 14.8
- 11.1 vs 14.8
- 11.1 vs 14.8
- lipo over-discharging rate
- 8.4v NiMH 3300 mAh w/ capacitors
- Lipo disassembling - reassembling
- Litco alpha-4 web address
- charging a gel cell 12v 17AH battery
- 24 volt battery charging
- Installation of a JP Micro Battery Checker
- mAH difference for radio?
- what adapters for cellpro balancing charger and common sense lipo
- help with the different batteries
- need a new charger which one.help
- Charge two (or more) SLA at the same time (in parallel)?
- Strange LIpo Battery Problem
- Help assembbling 7 cell RC18MT pack
- Fromeco 8-Ball
- Left receiver on for a while. Battery hurt ?
- 5 cells unregulated
- Did I damage anything????
- Brand NEW The Airtronics SANWA RD8000 Transmitter Battery Problem
- another MRC 977 question...
- rechargeable 9v battery and charger
- Voltage drop accross connector
- question about charger?
- Need help with new Hobbico Accu-Cycle Elite (i am dumb about charging)
- towers 420 charger ?
- Using my stryker car charger in home?
- NOBS Batteries
- Charger recomendation please :) For park flyers.
- question for first charge on NiMH packs with an IntelliPeak Twin Pulse
- AA - vs - AAA NiMh Packs
- NiMh change in internal resistance when getting old?
- ELITE 3600 opinion
- Thunder power 3 cell 1320mah - Dead again
- new Lipo problem?
- TP Balancer Question
- Charger output cable?
- GP4300 vs IB4200
- ***WARNING SWALLOW CHARGER****
- Adapter needed
- Lipo problem
- For those with Triton charger???
- battery life and check
- Old lipo - is it still good?
- Charging NiMH packs with ICE!
- 6 cell 150mah nicad how to charge
- first lipo help
- exploding lypos
- My design smart charger
- battering forming charge ques
- When is a Lithium Polymer Battery No Longer Useable?
- Chagers?
- Question
- Batts for E-Savage
- A123racing Batts in my boat
- TP 6000 mAh 3S3P conversion to 3X 2000 mAH Batteries
- custom transmitter battery advice
- Triton Charger OH NO!
- LiPo has zero volts loaded
- Just bought the Triton charger???
- Lipo cell goes dead-reading 0 volts
- Piranha Digital peak
- Triton charger - help
- AC/DC Charger
- How low to discharge the NiMH AA batteries???
- New to electric, need help with IB4200 and Intellipeak
- Duratraxx twin pulse
- Swallow Advance showing too high voltage
- Ni-MH 8.4 1000mAh ( 7 cell)
- Trickle Charger Question
- Lithium-ion voltage (8v) into JR reciever
- Battery pack question
- Triton Charger Problems
