- Battery pack question
- Triton Charger Problems
- Is temp sensor for Ice the same as Accu-Cycle Elite?
- Old CaRa Cycler?
- Charging Batteries - cold or warm room better?
- Li-pos at less than 1C?
- Duratrax ICE.
- Bit confused about the mA after first charge...
- 800ma AA and new electric model
- Charger with backlight???
- Using Cells from Li-Ion Laptop batteries?
- Gell Cell Charging.
- Maximum mah for wall wart
- Similar to Thunder Power batteries?
- What lipo balance charger for accu-cycle elite?
- battery charging question
- Need information on charging NIMH batteries
- mixing battery cells?
- J Connectors?
- Hobbico Elite Charging problems
- Charging balanced Lipo on Non-balance charger, and Nihm amp rate?
- 12v to 7.2v ??
- Transmitter battery pack cycling
- Some battery issues/questions
- 2300 3S Hypersonic Turbo Pack - Align T-Rex 450
- Sanyo KR-1500AUL 5 cell & Digitals
- EXPERT BATTS
- Nicad quality
- Hobbico Quick Field Charger for Nimh
- Greatplanes cell balancer for li-ion
- Dynamite Vision Peak Plus
- 12v car battery charger for 12v starter?
- Voltmeter cable mystery??
- JR 10X transmitter battery
- Thunder Power Balance pin?
- Charging 2 lipos (serial with DN Power Micro-Controlled Lion/Lipo
- Which battery size to use?
- trickle NIMH battries ?
- What charger will do this?
- MRC Super Brain 959 part2
- Power tools dont balance Ion batteries..
- Lion Newbie
- LiMn packs?
- NiCd vs NiMH Charging...
- Current question for charging Li-Po's...
- Rx and Tx battery pack for Nitro Buggy
- LiPo/LiI balancing charge using a multiport charger
- Need a "do it all" charger
- Charging Fromeco batterys
- Peak sensitivity settings
- Bantam 902 and PB5 balancer for Lipos
- I'm lost in a sea of chargers!
- Dynamite Prophet Sport for planes?
- Getting Universal on LiPo (Park/Electric) Connectors
- battery charger help plz
- is my battery checker showing the right thing?
- GOOD Volt Meter?
- LiPo FAQ
- Making battery packs for cars
- Monster Truck Chargers Nickel Batts
- Common Sense RC needs a few good men! or women!
- Which charger Expensive deluxe vs cheap
- dc to ac converter
- Ace R/C Digipace II problem
- Thoughts on ofna charger
- Parkzone F-27C Stryker 3S 11.1 V Balance Plug
- Battery Fire
- Hobbico Quick Field Charger MK 2
- New Electrifly LiPo w/balance plug
- Time to move up to Lithium Ions?
- futaba and hitec
- Hobbico MkII settings
- 7C 1400mah 1:18 IB pack - 0.1A for fist charge?
- Help !! Charging a 1350 mAh Lipo
- Charge settings?
- Need Help powering a small strobe light
- flight cutoff voltage
- Nicad transmitter voltage
- A123Racing Hypersonic Turbo Questions
- A123Racing Charger Questions
- A123Racing Battery Questions
- Lipoly battery
- Maxamps 2100HV - do you like yours?
- A123 on the Bench
- Thunder power balancer
- Field battery for a 109 charger
- Welcome
- Confused
- Noob needs 7 cell help....amp question?
- Wal mart power supply
- Tenergy 3.0 V 750mAh & 900mAh Li-Ion Batteries
- Lithium with 50C charge rate.
- mAh per ounce. I tested a few.
- 6v NiMH initial charging
- Did I kill my nimh pack?
- 2/3A - where does it fall in the line?
- 6V Charger?
- Need some advice on a 6v battery setup
- All-In-One Charger - Does it exist?
- 2-cell male balance connectors, where?
- life of a battery charger...
- 6.0 volt receiver battery packs and servos
- In search for a charger???
- Looking for multi port lipo charger
- 2500 ma Nimh discharge?
- Duratrax ICE - Dead after 1 month
- Li-po charger help
- TME Xtrema - WOW!!!
- LiPoly Cell Balancers
- Nicd or Nimh?
- Hobbico Quick Field charger questions
- Twin Batteries
- Battery Discharger Design
- Specifications for Multiplex & Intellipeak Ice
- 8A Pc Power Supply & Duratrax ICE
- MRC Super Brain 969
- Delta Peak
- NIMH 6 Volt Conditioning before use.
- Quick Question about my deans set-up
- Hobbico accu cycle charger/cycler
- Thanks, Red!
- Racing ni cad packs
- Receiver Battery
- Tp-425 C.V - CHG EXCESS VARIATIONS??
- Midwest products hp-100 electric brushed motor
- battery question
- how to get max power out of nicad
- Electrifly Li-Po Problems
- replacement for 12V lead acid battery for hummer
- Li-Po Battery Capacity Meter
- A smart MCU based Li-poly battery/Ni-MH battey Charger
- Anybody know where I can get this battery?
- Nicad question
- Battery and Charger?
- Futaba T6XA battery question
- Upgrade to Lithium?
- battry charging
- Futaba 6YG Charger
- Will TX Battery last
- 6V MH Batteries Showing 9.35V
- Charging NiMhs- wall charger?
- Triton – Piranha Chargers
- good power house
- Good companies for 7.4v lipo packs.
- I need some info on charging please...
- Switch Ni-Cd to LiPO?
- LIPO CHARGING QUESTIONS?
- chargers & Lipo
- LiPo Storage Question
- Piranha Charger and NiMH battery
- Total Newbie with a Triton and Li-Po Pack
- Triton, TP and Electrifly with Equinox
- Nubie needs some charging help
- Puget Sound help
- Current draw on glow plug
- Swallow charger instructions
- Anyone using the Hanger 9 field charger ?
- Discharged Lithium Ion - Duralite
- Do Ni-MH batteries need to be discharged?
- ESV Measurements
- All digital servos and NIMH batteries-Up To IT?
- Help with Jomar battery backer
- Deans Ultra Connectors on Ebay...
- New to LiPo's...few q's...
- Hughes R/C Spectra 4
- Triton not fully charging lipo
- Recharging Dock???
- another help me pick a charger question
- Lipo <-> Motor Dating
- Odd Battery News -- Seaweed?
- 1:18 (RC18MT) and Deans Connectors...
- Triton NiMH false peak
- 60mah charger for 1500mah battery?
- little problem
- Swallow Advanced Charger
- WHAT EVER HAPPENED TO THE 1 MINUTE CHARGE LITHIUM???
- Wall Wart Charger 160 up to 180 MAH
- What To Do?
- Charge LED goes out
- NiMH charging specs
- Help!! What does mah mean??
- charger for me
- Form charging 3000 nimh Batts
- 30% gasser batteries and regulators need advice and pictures
- Do I Need More Battery
- Fullriver anyone?
- battery power for triton
- savage batery
- AA or Sub-C Batteries ?
- Aero-Nut Lipoly Packs
- AC/DC (not the band)
- UNIVERSAL SMART CHARGER
- question
- help with my Integy charger, please
- Ripmax Prodigy 2 - HELP HELP HELP HELP HELP
- Ace Super Smart Charger correct use?
- Come on Guys somebody has to know this??????
- Need of a new charger
- How important is a good charger?
- Dynamite Vision Peak 2 or Prophet Plus
- NEED a good VOLTMETER< WITH 1-2 AMP LOADS
- Duratrax Piranha vs MRC Superbrain 959 for 2/3A 1100-1400mah 6-7C Packs
- Lipo charge rates and time
- Only 3000mAh?
- Ultra Balancer
- Ace Super Digipulse Memory Backup Battery burst / exploded
- zagi xt battery pack
- 10,000 mah NIMH D batteries - possible to use in RC Cars?
- Discharge rate chart for LiPo?
- Which wires to use
- Why Fromeco or Duralite why not off brand?
- nimh hydra max batt.
- will a ni-cd charge a ni-mh battery?
- Can Battery Explode?
- Lead Calcuim Battery Question
- Lithium Charging ???
- Ignition Battery Question
- Any one got on of these bad boys?
- Discharge rate to = 400 speed motor?
- Lithium goes on fire inside a plane!
- Wiring Controller to Motor?
- Ofna charger w/ 1200mah venom...
- NIMH Impedence
- Can I use this charger for Heli and xp8103 batts?
- Oh and one more question!!
- Hey Guys surely not!!!!!!!!!!!!
- triton Charger - Peak Sensitivity setting?
- Li-poly
- 640mAh LiPo with Flatana Flat Out, flying time?
- Is 1C Too Much Chg Rate for OEM NiCDs?
- review: T-1000 Ultra Fast Dual Use Charger
- could electronic ignition cause a battery to go dead?
- URGENT HELP PLEASE NIMH
- is there a book "batterie charging for dumbies"?
- is it the pack or the cycler?
- Need a 16 cell NiMh+NiCad series charger for a special application
- Thunder Power 425 Charger
- Glo starter nicad 1.5V?
- Triton flashing DLY?
- Hobbico R/C Multi Charger - ADJUSTABLE??
- Marez on Parallel Operation - One more time.
- Batteries and Chargers Questions
- hot wires
- voltage drop
- Charging N-MH
- Regulators, dual packs, switches question
- Capacity of DuBro Sub C NyStarter?
- Charging voltage question?
- Freezing pack?
