View Full Version : Batteries & Chargers
- ? Red ? MCNAIR Batteries opinions please
- Can I charge AA NiMh with peak charger?
- Dead 12V battery?
- NiMH packs getting hot
- Help with Battery and charger
- Nicad Cell Sizes
- Charge rates for new NiMH 2000 mAh / Triton Charger
- Duratrax Intellipeak Twin Pulse
- 3000 Mah NI-MH batteries
- What batt for 5 digital servos
- What about these new very large Tx batteries?
- Battery Charger
- 3 Chargers-Choosing-Help If You've Time
- Attention: Red
- Adapter to charge LiPos from any charger
- Warning Duralite regulaters
- Battery & charger, please HELP!!
- multiport charger w/ peak detection
- Hydrimax - Panasonic or Sanyo???
- 9000 MHA D Cell Charging
- Outstanding customer service at Fromeco
- VOLTWATCH vs. ESV (Expanded-Scale Voltmeter)
- Gell Cells vs Lead Acid
- Dymond Super Turbo/gell cell
- A Question on Li-Po.
- new here need help...
- 12v gell cell charger test??
- gell cells?
- My lipo charger is acting up Apache 2500
- Whats up w/ my apache 2500 lipo charger
- accu cycle elite..how do i charge 2 things at once?
- Battery that lasts 10 years !
- Starting battery voltage ?
- Battery Test Question
- Sensing Peak on small battery packs
- Li-Polys: same rating, different capacities?
- Triton question ?how does it know ?
- Selecting the correct type, voltage and output power for a battery
- BEST DEAL ON NIMH BATTERY PACKS?
- Accu-Cylcle Plus problem
- Align LiPo charger for 11.1V 3000mAh?
- Is this NIMH enough?
- Explanation of how charger works?
- Eloy Marez & Parallel Packs
- Robbe Power Peak Infinity 2 Li question
- Battery Pack impedance-Very important factor
- Wiring Battery Packs in Series and Parallel
- Which do you prefer and why
- Help with going to lipo
- What should 3.6V NiMH packs Charge to?
- Help me find a charger!!!
- To charge or not to charge that is the ?
- Proper Piranha Programs For Nihms? (Can't Find ANY info!)
- LiPoly Help
- BalancePro HD System for Lithium Safety and Longevity
- Supernova 250S problem
- Good cheap charger?
- Hobbico quick field charger II problem charging li-ion.
- Glow Lipo receiver battery with BEC regulator
- charging Ni-MH batteries???
- Charging LiPo Battery 3S3P
- Charger compatability?
- Li-Po storage
- Accu-Cycle Elite Calibration-Help
- Cold battery
- Tronics Li-Polymer Test Result
- Ok to keep recycling?
- Dry Cell Batteries
- Red Scholefield - TX Resist
- Is my lipo dangerous?
- Welcome Greg Covey
- LI POLY BATTERY IS CONFUSING NEED ADVISE
- charging nimh with graupner ultramat 25
- Help superbrain 959 internal transformer???
- Power supply unit recommendations for Schulze chargers
- When stop flying whit LiPo????
- Hobbico Quick Field Charger MKII-SQUEAKS
- Good Field Chargers?
- Safety cut off....
- IS 8.2V MAX NORMAL FOR LITHIUM USING SCHULZE?
- Tx Battery question
- Will these Ebay Batteries work for me???
- Peak Detection Question
- NiMH Charging
- Burning motors...
- Rx battery drain question
- High Rate discharge Li-Polymer Battery cycle life defination
- Digipace 3
- 2400mAh Li Ion will only charge up 1200 using Schulze
- Triton Q's
- Charging Batteries; specifically NiMH
- NiMH to replace NiCd
- Replacing 9C battery ?
- My rx battery question?
- Correct me if I am wrong...
- Tronics 10C and 15C discharge curves
- Picojet - Down weight, up stamina.
- Triton Peak Detection
- Futaba wall charger question
- Digital Voltmeter ?
- Battery bar question
- Need a manual for an Einstein XL charger...
- 6 volt pack voltage
- Powerbox 40/24 and batteries of different capacity
- ATTENTION: Red Scholefield
- Li-ion question
- What charger to buy please help !!
- Battery Storage...
- Walker 4 LiPo???
- 4.8 to 6.0 volt help w/retract servo
- NiMH battery questions,,,,!!!!!Please Read,,
- Power Capacitors - Newbie
- What size batteries for my Cuda?
- Solderless Power Tube (SPT)
- Fast charger for Evo 9 TX
- Accu-Cycle Elite - NIMH Problem
- duralites charging question
- Charging rate
- CHEAPEST WAY OF CHECKING "mah"
- Battery holder
- Cheap Ebay Bundle , Alot of RC stuff!
- Charge Voltage
- Battery Mah
- NiMH Discharge End voltage
- Duratrax Ice converter?
- Lipo battery info
- UPS battery usefulness/testing
- Hobbico Elite Charger
- New to Electric Please Recommend Batteries and Charger
- New Charger
- is this save??
- Scorpion is Here! SKYVOLTS are Next
- Great portable power supply
- dc charger power supply
- Tx Rx charge question with Add-a-Trickle
- power supplys and chargers question
- Need help to find suitable battery to power brushless motor.
- Etec manufacture
- Short Discharge Time on New Sanyo Packs
- 12V Shelf Life
- GWS 7.4v 1050mAh and 1300mAh with Accu-cycle Elite help!
- Wacky battery
- Hobbico charger - info wanted please
- Sirius Pro Former ?
- Battery "HOT" after run?????
- fast charge
- Which battery for Funtana 40?
- Xmitter charge question
- Basic Battery Question
- Using Li-po's. Not for thier Intended application
- Newbie charging question
- LiPos on Airlines
- Battery Capacity
- Battery Voltage Question
- Charging TX/RX Batteries - Best Practices
- gel-cell battery power/life
- The NEXT,NEXT, Myth Buster
- Celectra 3-cell AC adapter
- How Do these batteries Fail
- checking voltage with li-ion's
- Is PowerfLite still in business?
- Tronics High Rate Li-Polymer discharge curves
- Ace CVC Battery Charger LED
- Accu-Cycle Elite back to factory defaults.
- How to figure Battery Size/Load
- double vision charger aligator clips
- #7404 - 4000 mah - Redundant
- field charging lipo's
- High Rate Li-Polymer Battery
- Using RadioSouth 5.1V and a 5.4V regulator together?
- Need Info?
- Need 4 output charger for NiMh
- ace digipulse Help it stopped working
- Battery Charge Rate
- Fly with a 6v Camcorder Battery?
- Duratrax ice trickle?
- li-po story...your opinion?
- 15C Li-Polymer Battery for R/C model assemble
- Charging with Lipo-502 charger
- WHAT IS THE BEST USER-FRIENDLY CHARGER/DISCHARGER/CONDITIONER ON THE MARKET?
- Welcome Josh Glavin
- High Rate discharge Li-Polymer Battery Experts
- li-po RX battery?
- newbie with some battery questions
- Battery, Motor or Pinion problem?
- New NiMH pack doesnt reach full capacity?
- Load testing
- Automatic repeat cycling possible? Triton? Accu Cycle Elite? others?
- HOBBICO ELITE
- 4 Cell NiCd AA pack – Voltage too high?
- switch question for duralite battery
- General Formula For Discharging Batteries
- 6.0 Receiver battery question
- Battery for Dubro Kwick Start
- Help ID - Lithium Ion Bats
- What Setting to Use on My Charger?
- Problem with GP Triton?
- Best Charger???
- wireless LIPO battery checker
- Lithium Ion TX pack ?
- Safe Charge rate
- Battery Charging, Please Help
- 6.0 volt Regulator
- wrong first charge on NIMH
- How big and how many??? (A battery Issue)
- Sealed Lead Acid battery flight pack?
- Need identification help!
- ,,,Want to switch between 12 & 24 volt,,,
- Batteries
- How Cells are Rated for Capacity
- KOKAM 4TH Gen Cell Safety
- Exploding Lithium Battery Pack -= Video =-
- I need a volt meter with a load...
- Triton discharge Inaccuracy
- Schulze 6-330d Quick question !!!
- Intellipeak ICE problem
- "Do all" charger with Neon light?
- How to cycle a Transmitter battery
- charger
- battery pack for AXI 2814/12 on a Junior 60
- Question for experts... Battery change in turbine
- 2 Li-ions on a Y to reciever
- Cheap batteries for playing around?
- Triton: Discharge to 1.1 0.9 or 0.8 volts/cell
- How many amps should I set charger for?
- Batterio
- Battery questions
- MRC 969 help!!!!
- TX battery help
- Battery Seller Truth in advertising
- total Li-Po confussion
- New Pack Over Charges
- New discovery in LiPo ?
- Duratrax Intellipeak Ice looks like a better Triton
- New Toshiba Lipo recharges 80% capacity in 1 minute!!! Breakthrough
- Electronic Guru needed
- 3C li-po Parallel Charging ?
- NIMH battery charging question
- Toledo show
- Slow charging large packs with GP Triton??
- Future batteries ! Recharge in 2-3 mins
- new Orbit Pocketlader
- accu-cycle vs accu-cycle elite
- 3C li-po chargeing?
- Eliminating receiver battery with MSC?
- Cell unbalance
- NiMH recharged on a NiCd Fast charger
