View Full Version : Batteries & Chargers
- Red's Digital Loaded Voltmeter
- Lithium Ion Simplicity
- Charger advice
- Lithium Ion screwup
- Sirius Limited Edition Question
- Charging 6V with a Futaba 4.8V Wal-wart ??
- What happened to the "Radio Shack" battery thread?
- the Triton dial
- MRC Super Brain 809 charger
- Triton with Power Supply vs. Battery
- Is this right?
- cycling question
- Alpha 4 service ?
- Charging Li+ w/ Sirius through Reg/Switch
- One Hot Cell
- lipo question
- battry recovery
- Charging 350mah?
- Help deciding which RX battery please
- Help needed choosing RX battery please.
- LiPo low voltage regulator/signal????
- lipo batts
- Having trouble finding the right PC PS
- To wall wart or not to wall wart, that is the question.
- Best bang-for-buck battery?
- aaa NIMH cells
- Ignitor battery
- Cheap saddle packs.
- I'M CHARGING LI-PO STAND BACK!
- New kind of PC power supply?
- Wall o car charger
- Hitec CG-340 for 2 cells?
- The first Li-po charge?
- Charging with polarities reversed
- How long to charge?
- need battery lesson please
- Silly Fuse Question
- Cheap alternative for NiMH chargers
- Different models of the Triton charger?
- X-peak 3 manual?
- HELP With the D.I.Y onboard Glow System
- Schulze technical question
- nicad to AA battery change, advice?
- Suspect bad cycler(help)
- General multi-use charger question.
- BATTERY CHARGER - ALL FORMATS & VOLTAGES
- Triton or MRC super charger ((((((((( Which is Better
- What sized resistor for 18v down to 12v?
- Smaller batt for park flyer's?
- Please Help!!!!!!!!
- Not really Clear.......
- Discharging Batteries
- Li Ion v Li Poly
- Alpha 4 heart breaker
- Li Po - Just Say No!
- PC Power Supply- is this right?
- super battery packs (web site) need info
- need help with chargeing rate
- Noise from battery when charging
- Who's got the Astro 109 in stock???
- WILL PC POWER SUPPLY CHARGE 12V 7AH?
- Pyramid PS12KX power supply
- Cyclers, are they necessary?
- futaba cr2000?
- What is the capacity of alkalines in mah?
- How To: Calibrate your Accu-Cycle
- Hitec Laser 6 tx cycle?
- batteries
- I killed my LiPO pack
- Unknown Batty That came w/park flyer
- This whole charger thing is ticking me off
- Battery help
- Difference in Energizer and Sanyo cells
- Losing voltage
- Same charger with 4.8 or 6 volt rx battery?
- could it be this simple?
- Trition Cycling Cutoff Voltage for Nicad's
- nicad batteries
- Time for a new charger......
- chamaleon shutle 6330, and Lipos
- Hobbico Panel wiring question
- How to build the powersystem on a Extra 300.
- Best deal for giant scale lithiums?
- Triton - What to try next
- What do Lithium abbreviations mean?
- Dual battery connection
- Cosel power supply input cord???
- Hobbico Accucycle problem
- hobbico accucycle calibration
- Battery Connection Advise Requested.
- Help with Field Charger
- Can you?
- Lipo Flight Packs on the Cheap
- Charging Large Litho Packs (4S4P) or (5S4P)
- "Multi Session " charging
- Which Nimh charger?
- Please Help – Batteries died in flight
- How to store batteries for long period ?
- Vision Peak2 Charger
- tx pack replacement
- Help pick charger?!?
- RC charger for marine batteries?
- TRITON SUPPORT
- recharging a lithium camera battery???
- LiPoly Discharging/Cycling
- TX battery discharge
- 12V field battery
- GP Triton, did I get a bad one?
- Battery problem
- to all of the accu gurus please help
- Futaba RX 4.8v 700mah pack fast charge?
- Tekin BC100L charger question
- safe voltage uner load?
- Battery/Charger Box
- Over charge w/ stock charger?
- Charging PowerfLite LiPo with a Triton
- Good 3000 NIMH battery stick packs?
- nicad battery short circuit survival?
- Flying time on Piccolo and Lipos?Help please!
- Trickle charge on hobbico mkII
- Dymond Super Turbo or Triton
- FLIGHT TIME
- another power supply question for MKII
- Setting for a Triton
- Li Po Question
- What Connectors?
- Hitec multi charge-a-matic dc charger
- Litco Real or Scam?
- Batteries in parallel
- Suggestions for a Power Supply for my Sirus Pro plus needed!
- quick discharge on rx battery in trainer?
- charger for very small 20mA Li-Po cells
- need help with charging question
- digipace 3
- pro-peak prodagy
- Is the MKII a bad charger? unsafe?
- Hitec Eclipse7 Wall Charger Output Specs
- 6 volt 1100 mAh or 4.8 volt 2100 mAh??
- battery pack trouble please help!!!!!!!
- Check out the homepage
- single D cell 4400 mah????????
- MRC 969 and Lithium Batteries
- Cirrus Cycle pro - polarity damage
- Li-Po swelling
- READ & HEED - ""MRC 969"
- charging question
- Red's forming charge discussion
- 1200 mh
- charging NiMH with Super Nova 250
- Battery for Hitec Focus 4??
- Bought a Sirius, where to get accesories?
- Where to get a hobbico MKII
- Will the HANGAR 9 DOUBLE VISION??????
- Alpha 4, Triton, and SuperNova technical question
- Forming NiMH
- What batteries and chargers for losi xxxs RTR?
- NI-Cd 1100mAh battery leaking??
- Are Rayovac 15-Minute rechargables any good?
- Battery charger choice
- can i use my wall charger for 1100 mah batt
- MRC super brain...
- Hobbico mkII and 4.8 v 1400ma rx batt.
- Triton Limits charge current
- triton charger
- Desperate for Charger Info
- Battery and charger please help
- Batteries any good yet?
- Any good or bad experience of ¨Superbatterypacks¨ LiOn packs and accesories.
- Question about discharging NiMH with 969 Pro
- Triton to charge Duralite packs?
- Cicling question ?
- LI PO instead of NIMH?
- Best way to SAVE BATTERIES!!!
- Schulze charger PC interface and software - free!
- where does the voltage go?
- Time in hours for my batteries with this charger...
- What is 4S4P...Electric Newbie
- Li-Ion run-in procedure
- Left TX on since Xmas, Battery still good?
- Prophet Plus Charger info
- whatsa good source for nicad or nimh batts
- better battery
- nicad or nimh for my rx
- Hanger 9 Surecycle battery analyzer
- Super Digipace 3 help
- Older Tx batteries
- Where to buy Deans, Tamiya, JST Battery Connectors?
- Triton panel light
- Battery life
- making your own battery packs
- JR 600 mah battery
- 6 volt application
- Duralite or TBM?
- what should I make of this?
- LiPo charging.
- Pro Max Black Widow for NIMH?
- 6V reciever Batt.
- accucycle calibration?
- Battery power AA verses sub-c
- hobbico field charger pro MKII
- li-po V li-ion
- SIRIUS Charger Pro Series to charge 6-cell 7.2v/270mA Pack?
- How to cycle and prime new TX and RX nicads
- GP Triton to charge Duralite Plus?
- Charger duty cycle
- battery help!
- Dropped my Nimh pack!
- FMA NICAD BATTERY BLOWOUT SALE
- can i charge a 9 cell pack whit 8 cell max charger?
- NiMH with Accu-Cycle at C/10?
- charger recommendation
- High capacity Nicads - slow charging
- Ni Mh questions.
- DURALITE PLUS CHARGER FOR LI POLY CELLS
- Triton idiot needs help??
- Hobbico Accucycle
- DCX3300 Xapper didn't Zap!
- A4 cycling 4Ah Battery
- To charge or not to charge
- Tx Rx batteries run-time
- LI-ion and memory effect
- Battery Help???
- piccolo batts&peak-5 jamara
- 1st Charge of Radio Shack 1800 NiMh AA something's wrong?
- 1100 Mah or 1650 Mah?? Charger ??
- Ni-Cad Advice
- Li-Po charge retention
- 1S1P added to 4S4P 7800
- charge retention
- slow charge NiMH with wall charger?
- Voltage Regulator & Battery Setup
- Need new batteries
- Battery Charger - Peaker - cycler advice wanted
- charger/battery compatibility
- whats wrong with my batteries?
- NiCad or Nimh determining cells in a sealed pac?Nova 250
- Dynamite Prophet Tango Uniform?
- A charger for my needs??
- Cell Holder
- Ni-Starters - Any preferences?
- wattage PF-12 chager
- What's up with Radical RC ??
- tekin bc 112a
- Amp meter
- Quick charger for RX & TX
- GWS MC 2002
- Hobbico multi-charger
- LiPo Charging Question
- What is thunder powers website
- Help mini t Team orion 1100 ni-mh 6.0 volt help.
