View Full Version : Batteries & Chargers
- 12V gel cell damaged ?
- Q: 10cel 2600 NmHd
- can you believe this advice (its from a battery manufacturer!!)
- Never mind a Triton for dummys manual, how about a new charger designed "For Dummys"
- 6V Regulators
- c/10 charge time?
- Anybody deal with batteryspace? Their RC Batteries has unbeatable Prices
- Shorting Packs?
- Charging Lead Calcium Batteries
- Different Batteries and Chargers
- 4.8v vs 6v
- Trickle charge NIMI batteries??
- solar panels in glider wing
- Discharge rate for nimb sub-C?
- NIMH Battery Questions
- Inexpensive 1500mah pack maximum, Charge current?
- Soldering Energizer NiMH
- NICAD 10 year old
- Storing new batteries.
- Li-Ion's & Supernova
- Battery,Reguator & Switch recommendations
- Charging time from a Protech .7 & 4.7A
- Ace Digipace Information Needed
- newbie - a good universal charger?
- Use AA instead of sub-C cells?
- need help with a charger for a zagi 400x
- How do you wire up a Lith-Ion cell phone battery for a park flyer
- Triton Display Question
- Wiring Question
- NiMH Buzz when charged????
- SR Batteries web site - don't use nimh nor lithium
- Off topic: 2 way radio battery
- Cell Phone Chargers
- Gasoline in ignition battery. Toss it? Keep it?
- Charge rate question?
- More Triton questions
- Battery charger idea?!?
- Cheap Alternative to an expensive DC power supply
- QUESTION: tx charging time
- Question for Red
- dual battery charging
- TRITON Charger available in NORWAY??
- Litcos on Ebay
- 6 Volt Battery Range
- Sirius Super Tester ???
- Can I cycle Transmitter & Rcvr at same time on Einstein XL?
- Question about my charger
- Accucycle Schematics
- extending charger wires
- Safe cheap DIY adaptor to use a PS with a Battery Chargers (like SuperNova 250)
- 1/2 price Radio Shack 25 Amp Power Supply
- Lithium Polymer packs?
- anyone have the manual for the AstroFlight 110 ?
- Ok to"Y" harness together two battery packs?
- price check
- Spot Welder
- Would these be suitable for making Zagi packs
- Switching DC Power Supply ??????
- Sanyo 2000 NiCad
- Question for Red
- Charger problem with Zagi
- Has anyone seen this info about Cermark?
- Triton, odd result, Whats going on here???
- Batt. Question
- Batt ?
- Hobbico Accu cycler
- Which is better - Alpha 4 or Triton ?
- Ion's for transmitter?
- Dymond Super Turbo Questions
- Battery Pack Question
- Jr 8103
- Charging from a 12V battery?
- Triton for Lithium-poly
- Best Charger for Multiple JR Flightpacks
- Battery Charger direct connection
- Ultimate Charger 2
- Triton for Dummies
- Anyone Use this charger?
- Lowest voltage for flying?
- Can a standard charger be used on a NiMH TX pack
- Super Digipulse not available. What is going on at Ace?
- Cycle question????
- Why Triton needs 13 Amps to charge 5 amps??
- Suprise!!! 6 volts!!! ???
- Best source for nicads?
- Airtronics Vanguard 6 channel
- OK, how about a simple start for Triton.
- charging 270mah rx packs
- PC Power Supply - Power Good line?
- 4.8 volts vs 6 volts
- rayovac NiMH
- Graupner Ultra Duo Plus II Battery Charger
- How to charge TX and RX batteries
- Triton Charger used with 5 A P/S
- Is a 370mah 8.4V Pak OK for GWS Beaver?
- Computer Power Supply Switch Question
- Charge It!!!
- AccuCycle and NiMH
- Red I Trust Your Judgement
- Hanger 9 12V Battery Charger
- Optimum RX Pack???
- Unknown Battery Pack + Diamond Super Turbo
- digipace 1 questions
- Tekin BC 112 C
- charging question
- Triton fan does not turn on??
- More problems with Triton instructions, Help.
- size for .60
- Best Battery for Sky Scooter
- How to use a Astro 112D Charger?
- NT100ATH Batteries
- $3 Lithium battery sets
- which charger for lith-poly
- Where can I buy an ACE Super Digipulse?
- Triton - in stock at Tower.
- ace digipulse and 2400mah nimh batterys
- same voltage, MA. bosst question
- Reducing Voltage on Lithium cells
- Using my schulze on the Bench
- Dynatron Starter Battery Question?
- Should I be concerned??
- Glow Plug Charger??
- Dymond Turbo Super Charger problem need help!
- In the market to replace Einstein. What fits the bill?
- TRITON MANUAL IS INADEQUATE, confusing, HeLp
- Charger Suggestions?
- Graupner Ultramat 25
- I'm loaded- Thanks Red!
- digipace 1 and 6v batteries?
- what Switch Harness to use ??
- More ?'s!!!
- Discharger?
- Battery Pack Construction???
- Astroflight 111 Charger on NiMH?
- settings?
- Battery Holder for AA NimH
- GP Triton Chargin Two Packs?
- Triton - now have temp probe! Question:
- PC power supply not AT or ATX no green or orange wire help
- Battery Question
- Which Multimeter logging software to use
- Multi Charger
- Victor Engineering Hi-IQ sr
- New Hobbico Quick Field DC Charger MKII
- flight box power
- charger help 8 cell zagi
- Triton..... Where to buy? Best price?
- Fma Supernova Problems?
- Did an whoops
- accu cycler users read this
- Soldering Nimh batteries
- Red, What would you buy?
- test
- Digipulse operators manual
- Accu Cycle not dischargiing
- Battery Chilling
- Wall charger ??
- dead lead acid 12v 7.2Ah
- Dymond Super Turbo-She no work anymore.
- Going from 1300mah to 1200mah
- Types of NIMH batteries
- PC Power supply question
- Lithium Battery question
- Battery Maintenance
- Proper use of the Dymond Super Charger???
- Mixing packs,Please help Red
- Redscho... need your help
- Warning To All Triton And Supertubo Users
- Dead tx battery when I bought it
- Where to buy GP Triton Charger
- Left transmitter on...dah! Will battery be OK
- NiCd receiver pack
- How to charge field battery encl. in box
- TRC field charger question
- At Home NIMH peak chargers?
- Can I do that: Plugging 4.8 V pack and one 6V pack on my receiver?
- Wall Chargers Modifications
- Cycle a field battery?
- 1.2v 50 mili amp charger?
- the best charger
- What Size Rec.pack
- Receiver Battery charge
- Jr. Circus IV 4 Charger??
- Tekin Bc 48 Charger Question?
- Einstein XL Deluxe
- Charge rate...
- triton and which power supply
- How long of a charge using a Futaba 50ma charger....?
- trition and power supply
- Voltmeter Question..........
- Power Supply
- Another one!
- Old Duralites still good?
- Slow Charge Help
- Can somebody please explain why I need this?
- ok lets try this again
- 3 wire Battery
- Charger prob
- duralites Plus and Orbit Charger
- Adjusting Triton Charger while discharging
- What rates should I set on my new charger?
- ATX supply shuts down under Triton load
- Best lithium charger?
- Nimh experiences... (feel free to jump in, Red)
- what is the best formula for cycling on the triton
- Pinnacle charger -
- Tamiya connector parts
- Triton vs. SuperNova
- What can charge multiple packs at same time
- starter and field battery question
- Hitec CG-25A Chargers Out Of Spec?
- charge time for new nimi 2100 battery
- Ferias battery!
- Graupner Multilader 6E
- Hobbico MKII question
- Charger Advice - What do you use?
- Hobbico 900+1400mah charging times
- TX Battery Plug Connector
- Whats the Difference? 6.0v vs. 4.8v
- Triton buzzer help!
- Have you ever bought a new "BAD" battery
- What is a safe charge rate for cp1300's?
- is this a good batt?
- Charging Rules
- Peak Charger recomendations?
- Discharging with Triton safe?
- Battery selection for Dynatron starter
- new triton charger. what is DLY?
- Thanks Red for the Triton review
- Air Tech Stealth Battery
- Nano Racer battery
- Charging for dummies 101- help.
- Hobbico Quick Field Charger MK11
- need 12v rechargeable batteries
- Reciever Battery Melted!!!
- Go - No Go - Voltage
- NmH battery?
- Batteries!!
- "C" cells vs. "Sub C" cells
- Sirius Pro Charge Rate
- GWS MC2002
- How many time can I cycle in a row????
- Proper use of the Triton charger....?
- :drowning: advice on charger/cycler & has Ace DigiPulse/Pace question
- Chargers & Power Suppliers?
- HOBBICO R/C Multimeter
- GP Triton and 12-volt Field Battery
- which batteries to use?
