PDA
View Full Version : Batteries & Chargers
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66
  1. Wheels and tires
  2. Battery adapters?
  3. Warning! warning! warning!
  4. Connectiong 1S to Onyx 150
  5. Confirmation on safely charging lipos
  6. Lipo worries?
  7. Anticipated Run Time? Tamiya stock buggy on 3000mah.
  8. Can I use a switching type wall charger with parkzone PKX7040 charger
  9. transmitter battery charging
  10. HPI Reactor 500 - How Auto
  11. HTRC B450AC balance charger help
  12. Balance 2s-4s balance charger to 3s battery
  13. Arrma Senton 6s BLX battery/charger?
  14. Spy Tank replacement charger
  15. Star Connectors
  16. Y-Cable Switch
  17. HTRC C 240 lipo charger sound Sucks how to make it louder
  18. 2S1P vs. 2S2P Shorty LiPo Packs Longevity
  19. Low voltage settings with onboard Lipo monitor
  20. Starting all over again with the new battery technology...need help getting started
  21. Unboxxed my first FPV drone and oops...
  22. Charger for Futaba 16SZ
  23. Is this safe to do with LiPo batteries?
  24. Need help on figuring out the problem with my batteries.
  25. dumb question time
  26. Any fly in the F3A?
  27. what batteries now?
  28. Life Battery Status/Cycling
  29. Batteries going to low
  30. nimh 3000 battery prob?
  31. Starter Battery
  32. Reuseable: Salvage swollen li-po.
  33. Gforce G8 duo working with logviewstudio
  34. Balancing Lipos help
  35. Looking for a battery
  36. Popping sound
  37. Inadvertently pulugged two NiMh batteries together
  38. Inadvertently pulugged two NiMh batteries together
  39. Duralite EXB Magnum Ion Battery - Charge Setting ?
  40. Isdt q6+ issue
  41. Keenstone charger message
  42. LiPo Charging Help for a Newbie
  43. Batteries flipping low voltage in less than a minute
  44. Swollen battery
  45. Super powers to charge
  46. A123 Issue Question
  47. nimh battery charge rates
  48. new batteries.
  49. correct charge rate
  50. Sitting Batteries
  51. HK LiPo's Shipping to Canada
  52. Nicad versus NiMh for 4.8 volt RC exl ignition
  53. talk to me about 18650 batteries for rx use
  54. Keenstone C1-XR charger
  55. Running 3 cell vs 4 cell
  56. Hitec X2 charger question
  57. Is this battery too puffed up?
  58. Lipo battery help
  59. ISDT BG-8S any good?
  60. Li ion jump start pack as source for charger for field use
  61. Looking for New Nimah Batteries>\:
  62. Organizing chargers
  63. Gens Ace vs Pulse vs Hyperion Performance & Cycle Life
  64. quick soldering question
  65. Putting 2s batteries in parallel?
  66. sirius charger
  67. Best charger?
  68. Buyer beware
  69. lipo batteries, where did they go?
  70. Battery 3s 2200 plane
  71. Hot motor and gearing ? so lost
  72. NoBS Batteries
  73. Charging 2 LiPo with 2 charges and common ground
  74. Discharge rate during Nimh cycle
  75. elctronoics expert needed !.
  76. Vampower 320W x 4 charger problem
  77. NiMh battery+Hobbico Accu Cycle Elite charger question.
  78. Taotuo LiPo Batteries. Any good?
  79. LiPo / ESC help needed
  80. Lipo storage charge
  81. charging at slightly higher voltage.
  82. Futaba charger lights flickering on and off.
  83. FMA Revolectrix Powerlab 8T - TOUCH
  84. Hitec X4 AC Pro
  85. Battery size for my 30cc yak m
  86. Recondition this Ni-Mh battery?
  87. C4 V680AC Charger question re NiMh
  88. SKYRC imax B6AC V2 Questions
  89. Gens ace New RS Pack Test
  90. what battery ?.
  91. Sub-C NiCd's with Different capacities
  92. Newbie Battery Question
  93. Hard of Soft case
  94. Running a LiPo battery on its' side
  95. Best deal to charge 2, 6 cell lipos, ac/dc
  96. Schematic for Accu-Cycle Pro Series charger
  97. Max amp draw for Turnigy Graphene
  98. schematc for ACE super digipace
  99. Combining Batteries
  100. Ammo box LiPo battery storage
  101. Minimum discharge voltage NiCd and NiMH
  102. New To RC, Want to make sure I'm charging LiPo right.
  103. NiCad & NiMH quick charger
  104. Find Battery by RC Car Brands
  105. 20% of my MotionRC Admiral Lipos die after 6 months!
  106. Have JetCat Battery, not sure what charger to get
  107. Reviving dead nicd/nimh packs...
  108. lost charger instructions
  109. Charge Less than 1C
  110. Beginners charger and battery
  111. Pretty sure I ordered wrong lipo battery
  112. mAh size
  113. lipo Balance lead error on charger
  114. Fire Proof Lipo Vault
  115. Charge rate for stored Lipo batteries ?
  116. Lipo battery charger within $40
  117. Influence of the RC Industry Caused by Cobalt Price Increase
  118. Battery Volts and System
  119. Battery upgrade from 6.4 li-ion
  120. increasing run time in an rc boat
  121. Charging JST Lipo batteries
  122. why does a good charged battery fail?
  123. Buiilding two 6v nimh sub c
  124. Puffed LIFE
  125. Help for greener than green
  126. Help for greener than green
  127. Can I run a 2S lipo with a 13t brushed motor on a Hobbywing QuicRun 1060 ESC
  128. 1200 mah battery 500 ma charger
  129. Balance charging 2S Life batteries
  130. Hobbico Digital mini-Tach
  131. Upgrade battery for longer use time
  132. Cheap field generator
  133. Vok 2s lipo balance plug
  134. Voltage Question
  135. battery and charger rec for old and new
  136. Battery connectors ?
  137. flat lipo battery charging
  138. traxxas
  139. Jumping back into hobby need a new charger
  140. Chargine NiMH batteries
  141. Speedpack Silver 3000mah not charging?
  142. 4 port charger ba. single port with parallel board
  143. 20-30A 300W AC/DC charger
  144. Hyperion eos 0606i parallel charging?
  145. Enerland A123 charger; need instruction manual
  146. Hyperion eoso 606i charging issue
  147. hi tech 2x 400 charger
  148. first post
  149. What is this connector type?
  150. What kind of battery would give me a max flight time?
  151. LiPoly Conversions
  152. Fleureon lipos. Any good?
  153. Help with Hexfly charging setup
  154. transmitter battery recovering it
  155. Lipo battery current draw question...
  156. 14.8V 2200mAh 50C 4S RC LiPo or 40C lipo
  157. Over heating a lipo battery?
  158. Battery and charger question
  159. Recommendation for 4x 6s Lipo Charger Under $250
  160. Ace Super Smart Charge label reversal
  161. Ammo can for LiPo's
  162. Any links to a DIY battery charger toolbox? Like what fans do I need and so on?
  163. Hyperion G7 Silicon-Graphene Batteries
  164. Lipo condition?
  165. How to solder - Frustrated with multiple connector ends.
  166. Need help charging AA/AAA batteries from this charger..
  167. hexfly 5800 life expectancy
  168. I need a charger
  169. DIY RC car 7.4v pack from 18650 3.7 batteries...
  170. SkyRC imax b6ac v2
  171. Which Connectors for 12S 29 Battery Pack
  172. Tattu 5200mah
  173. Triton 2 can't select charge
  174. Intellipeak ICE problem, Please Help!
  175. how can this chargr balance without any balanc connectors
  176. Best Bang for the buck on a dual charger 200w per channel and internal resistance
  177. AARRGGGG! The PUFF!!!
  178. All my R/Cs discharge very fast after 2 years standby
  179. HRP lipo batteries
  180. NiMH guideliness.
  181. What if I plug a Lipo battery into my RC vehicle without a balance plug?
  182. Digital camera with plug in battery charger?
  183. Dromida Nimh-charger, crap?
  184. LiPo voltage way too high
  185. Can't figure this out.
  186. If I understand Li-po batteries right
  187. New LiFe battery - how many cycles?
  188. Conection Dangers
  189. Duraflight A123 Sentinels
  190. Lipo Battery: Good or Bad:
  191. Charger mod ?
  192. Using Accucel 8150 charger with Traxxas NiMH
  193. Landing lights electrodynamics battery?
  194. Switching from Nimh to Lipo.
  195. Charge / discharge or?
  196. Lipo pack not fully charged
  197. Battery Fire
  198. Help!! Need 30c 14.8v 2200mah li-po battery for my ft011
  199. 2S and 3S batteries for Walkera Rodeo 150 Racer drone
  200. is thia a dud
  201. Is this a bad battery?
  202. 6 volt battery
  203. Power Lab 8 or GT 1200
  204. LIFE Battery Charging Issues.
  205. Battery Leads
  206. What's wrong with my lipo charger ?
  207. What is your experience / recommendation for a charger?
  208. Traxxas batteries
  209. Charge lead for Futaba RX LiFe battery
  210. Low voltage for Life-Li-ion
  211. Can i use this battery with drone ?
  212. Timeout before reaching max voltage with 680AC charger
  213. Issues charging zippy life battery- help needed
  214. Hitec X1 mini Balance Charger Question
  215. ponderosa
  216. Unknown Battery Charger
  217. Lipo Parallel Charging board DIY
  218. Can I do this with Lipos
  219. Is this a 14s Lipo pack??
  220. LiFe or NiMh?
  221. Is this normal?
  222. New 8s battery capacity meter
  223. What charge rate?
  224. Stock Small Lipo Chargers
  225. Go-to RX battery?
  226. RC plane noob saying hello.
  227. NiMH vs LiFe Available Current
  228. Hitec charger not going to set amperage
  229. 5C to 90C High Quality RC Lipo Battery
  230. Looking 4 a way to have one charge input to charge several battery packs
  231. Li-Ion battery for airplane starter?
  232. Real Balancing chargers?
  233. Battery Returns
  234. Hyperion EOS 0840i 8S DC Charger (1000 Watt output)
  235. Hyperion EOS 0720i SUPER DUO3 7S CHARGER.
  236. Hyperion G7 Si Graphene SV Lipos
  237. Multi-Use Charger
  238. Thunder AC6 not saying FULL anymore.....ideas?
  239. LiFe Charge/ Discharge rates
  240. Blade 200 S battery supplies
  241. Battery & Remote Controller Car Charger with Digital Display ,Will it useful?
  242. Onyx 210 question
  243. Looking for more mAh
  244. Lipo not always charging.
  245. Charging params chart - peer review
  246. Charging Params chart - peer review
  247. How do I charge this?
  248. Thunder AC charger getting extra duty
  249. Hydramax 2000 mah Battery - Use it or Not?
  250. Traxxas ez peak dual charger
