View Full Version : Beginners
- RC - trainers - who is the best in 40-46 size
- What do you use to remove CA?
- Sig LT40 Wing Bands
- Saito 180
- blueprints
- Wing Angle question on a LT-40 - Please give feedback
- FM vs PCM?
- Frequencies?
- Promises,promises
- GP RV-4 for 2nd plane?
- Wind
- Is your throttle stick smooth or ratcheted ?
- When are my batteries charged??
- Hi, I'm new
- how to start the hobby?
- Futaba 4VF
- Electric vs. Gas - newbie flyer
- .46fx in a 4*?
- Do I need a bigger servo?
- Looking for covering...
- When Should I start #2.
- Instructors???
- polyurethane for filling in balsa grain
- What's the difference between a sport plane and a stunt plane?
- Futaba 6XAS
- Sig Kadet MKII
- Covering
- Radio Channels
- Zagi 400 and 400X Qs
- Radio (help)
- Hello
- newbie hello
- Going to build second plane but.....
- newbie ?
- glider
- Tail Rotors Problem?
- Cross-Wind Landings
- rudder only, or ailerons too??
- Monocoat Trim
- Engine Problem!!
- What Servo?
- SIG Kadet LT40
- How come RC car engines have more HP
- Hi-Tech Laser 4
- Trasmitter functions
- Lt-40 tips and tricks
- Flight Box
- Magic plane cleaning spray.
- new engine running question
- What to do with fuel after flying?
- Flight Surface?
- Covering Help!
- Servo Tray
- What tools would YOU buy first?
- Still Deciding
- CG for Royal-Air 20T?
- Where to get cheap Sim?
- Servos and Radios
- New respect
- My first flight........WOW
- Replacing needle
- Where to fly in Sylacauga, Alabama
- What do you think of the "co-pilot"?
- rubber or foam wheels?
- Radio question again (XF 631) .....
- Newbie glow plug help.
- thanks Everone 4 * solo today.
- Spinner Size?
- My wings are not straight
- Newbie wanting advise
- Wattage F22 steering
- Need advice on this trainer...
- Modifications to a trainer.
- BEGINNERS! GET HELP!
- New Kid in the Cockpit
- new 46 fx cuts off with throttle up
- Hello all, Im a newbie and I have a question!
- viewing added photos
- no exhaust pressure line on a 4 stroke 90 surpass 2
- CAD For Models Recomendation Please
- Coroplast
- Plastic spinner or aluminum "safety" nut?
- How much flight time?
- need help please!
- How High do you fly???
- what is a CA hinge?
- ARF assembly questions
- Iron On Hinge
- Throttle servo setup
- Couple of Q's about beginner's planes
- Covering Using MonoKote
- Select an RC Seaplane kit?
- are pushrods included
- plugs
- Good simulators to get?
- Balance plane
- aircore 40
- Few more questions
- Programmable Radios with More Than 6 Channels
- Engine choice
- tomorrow is the day... first flight
- Trainer-- .25 or .40 ???
- crashing
- Battery placement
- Engines on Ebay?
- Apward and Sal_11
- What should i get?
- Docile Bipe?
- Glues which one for what Job
- Radio gear time
- Which way do starters turn?
- pushrod again lt 40
- my new trainer
- SIG Senior ARF Ooops
- Vtail Question
- Your thoughts needed....Trainer plane and Engine??
- radio kadet lt40
- Slow Poke 40?
- Hangar 9 Alpha??
- Radio frequency
- how doi know how much battery to use
- Battery charger/discharger What to buy
- Flaps
- Sig LT-40. Help!!!
- Now want to fly!
- Radio Equipment and Servos for 2nd, 3rd, 4th, etc. planes
- Beginner radio opinions...
- rc for son, need help please
- Building Process
- Sig 4*40
- Question Re Elevator Trim
- Glow Plug Recommendation
- UnderCarriage ?
- Q: about propellers
- SPAD
- Electric plane for 10 year old
- new guy 1st plane
- Congradulations Hypter
- Landing and other stuff
- Servo trim adjusting
- many questions?
- 1st choice for 2nd plane?
- Clueless questions
- kadet lt 40
- Alpha RTF
- Radios
- Thanks RC Universe!!!!
- Pull-pull Rudder Linkage
- What to do with the antenna.....
- Best Glue For Repairs
- Looking to buy first plane
- Servo centering?
- New guy intro and a couple of questions
- Sig LT 40 Wing
- How to fill the fuel tank?
- Discussion Topic: Jet Prices
- Kit Building "Necessities"
- what are some good beginner electric planes?
- in need of a tip building tower trainer arf
- Air strike
- Flying drills
- Kit Questions
- Hobbyzone Fighterbird
- First plane under 200$?????
- First Plane / Radio
- X-EC Diversion vs. Wattage Lightning
- Help! Goop Attack!
- Tx/Rx battery types, which is best??
- Heli blades
- Gearbox Help Please!
- motor manual tiger 61
- Fuel tank angled on install?
- Could someone explain wing loading for me
- eletric Starters
- How much Antenna Internal?
- How long does Beginner's Luck last?
- Please Help!!!!
- Angle of engine
- Mode 1 or Mode 2
- A FUEL PROOFING QUESTION
- About CA hinges..
- Need help! replacing a G23 to a big lift
- Avistar alerons" HELP!
- Wal-Mart Planes RC?
- Beginner's Books/Video's --> Recommendations?
- radio gold stickering ?? where please advise
- Plane Question
- Nose wheel
- Can Futtaba-6VH used for flying planes?
- Ultracote?
- Balance
- Good inexpensive Trainer under $250 but Mail Order
- Trainer?
- Gluing the Canopy
- my own private airstrip
- Field equipment questions
- Spinner Assembly Came Apart While Engine On!
- Electric Motor Stutters
- Long awaited return
- To All Beginners!
- Brand New to RC flying
- Best Mini Car
- Ki t Suggestion
- First low wing, tail dragger ARF ??
- Info on building and flying Radio Controled Aircraft
- Size of plane compared to weight to engine?
- Beginner FAQ thread (sticky post)
- engine mount location
- Taking off?
- The AMA
- Need to buy radio ...Suggestions ?
- Second plane - TF Elder 40?
- Eagle II Balancing after engine swap
- How small can a plane be?
- Anyone got a good plane design
- Gas or Electric?
- Exactly how much does a plane cost?
- Im new to RCs and flying I need help
- Opinions on Engine Run-in and Winter Project(s)
- Any instructers in Austin TX?
- Activator
- field kit & shop
- Adding Weights
- Information FAQ for beginners?
- See my new 4 star 40
- Evader ST - Problem with Radio! Help :)
- Help me please, new to nitro
- GP RealFlight G2
- aileron linkage, or aileron servos?
- kadet lt40
- My first plane
- Need some help on looping my plane, it just corkscrews
- Epoxy vs. CA glue
- Very Old Plane ???
- Reviews for Futtaba 6DA and 6YG Rc's
- Wing in Saddle
- Different terms
- Sky Pup Sport 15
- Top Rudder?
- I found a plane
- What's the best way to get more travel?
- Fuel choice
- Removing oil from balsa.
- Hooking up Fuel Tank to Engine
- Could you guys comment on health hazards of adhesives??
- Trainer 60 Flaperons ?
- junior 50 need spares help
- Exponentials.....when and why?
- Killer Chaos engine suggestion
- Attention New R/C 'ers!!!(New TV Show)
