View Full Version : Beginners
- Book Help?
- need help setting up floats.... *UPDATE* Float fly a success!
- Where do you balance a swept wing???
- Large Scale Plane Servos?
- Rudder-only acrobatics
- Newbie Question about battery care.
- flight box ideas (customized)
- Battery Chargers
- how do i apply monokote, prefered methods and techniques please
- Do exhaust tubes work??
- Servo Radio Gear
- Beginner general questions about plane selection
- Building 1st Kit, Have some questions.
- whats the best way to use aero gloss and tissue material to cover a wing?
- Building my first plane from scratch.....HELP!!!
- Landing at idle???
- need electric motor help please
- 1st kit??
- Help me
- accu cycler
- New flyer looking for some answers
- Basic Trainer Question
- WHAT ENGINE?
- Top Flite P-39 Airacobra
- Trainer keeps wanting to climb, how to trim a plane q's
- Carving the Spinner for Props???
- JR 421 flap set up
- Whats a good beginner plane
- Ready...Set... Radio?
- A Good Morning Flying
- Trainer Opinion
- Can I land in this driveway?
- High or low rates?
- not enough lift
- RX TX battery charging
- What You Should bring with you to the field!!
- first plane
- Fokker Eindecker 400
- WIGs
- Which 1 of these for first low wing plane?
- choosing the "right" prop
- dumb question, but gonna ask anyway
- UPDATE ON "DESERT MOUSE" from proud PAPA
- how is this kit for a second plane
- 3rd Plane
- Re-Big Trainers
- Newbie going to build
- cub j-3
- Can the wrong plane take your smile away.
- 2nd plane suggestion
- Flying GP P-51 40 ?
- How many crashes out of a trainer?
- Two rookies, two mistakes.
- Building first plane......have a question.
- Finding C of G
- 6 channel radio help???
- Solo flight!
- Covering techniques (Oracover Lite)?
- 40 mhz or 75 mhz? Which one?
- How do you all feel about 1/4 scale trainers?
- Crash and rebuild ... plus questions
- Trainer Package
- Trainer Package
- On-Board Glow Systems
- recharging the plane
- To leave or not to Leave the hobby
- learning without an instructor
- TT46 pro
- us40 controls
- Top Flite Contender as second airplane
- Hayes fuel tank
- Great Planes 60 Size Cub
- Show me your Stiks
- Co-pilot for begginers?
- Replacing LT-40 engine mount
- Great second plane
- Engine size
- Ace High MkII Kit
- aerial pencam picture thread
- glue
- Problems with servos
- Steering problems during take off.
- Engine size?
- Balance point for Cermark F-20 Tigershark
- I would build if I new how to Cover
- how do I use a 4 ch TX with 5 servos?
- Voltwatch accuracy
- cub
- new
- Where to fly.............................
- Which servos for Hangar 9 Ultra Stick 60?
- New Kid On The Block !!!!!!!!
- some help needed
- ONE MORE
- Field box fuel storage
- Fuel spill in fuselage
- Receiver on/off switch position
- Am I missing something?
- Burnning Hotter?
- Radio Programming???
- Pinch the Fuel Line
- megatech skyliner
- Crash!!!!
- slow biplanes
- Rx battery pack
- 60 trainer, does the sig senior kadet qualify
- Hitec, Futaba, JR, or Airtronics, Who makes the best computer radio?
- engine recommendation..?
- Second plane & windy weather plane??
- Servo
- after run oil
- How do I/Can I mix radio components?
- Difference between servos
- Big Trainers
- Goal: 1/4 Extra.....How?
- Eager Newbie
- great truck for sale for beginners
- taildragger take offs and landings
- rear end protection
- Going from GWS Beaver to Sig LT-40???
- Good luck
- Autopilot or gyro
- Props for 46
- i'm new, got some questions?
- Practiced on the ground but have a few questions
- Attention instructers?
- Giles 202
- I'm Building A Tiger 60!!!
- Need some help Guys
- What are all these screws on the engine for?
- Kit building
- A thank you to instructors
- Slow roll on LT-40
- Radio Range
- Congrats to AndyC
- Which Plane Should I Get???
- Anyone notice
- Taildragging A Big Stik 60
- An idea for an electric starter
- Run my engine for the first time
- Durable EP trainer with ailerons?
- Dual Conversion means what?
- Need help w/ radio purchase
- balancing
- Cheap LT40 arf
- RX Wire
- 2nd plane Giles 202
- distance from a field to turn on transmitter
- Whats a chicken stick?
- Learn How to land safely in 20 minutes :)
- Coming back to flying.
- Radio system
- Converting LT-40 to a taildragger
- Adding throttle control to T-hawk
- New to RC airplanes
- impressions of SPAD planes???
- More questions about building my ARF Trainer
- spin question
- Dual Aileron Servos?
- KADET LT-40 building plans
- don't click it
- covering plane with monokote ???
- Sig LT 40 Mods
- Vertical stabilizer to far back??
- Newbies favor left or Rt. turns?
- Landing
- Avistar Hints & Kinks
- GP Rv-4 40
- Learning to fly without an instructor.
- help?.. Putting together my first trainer plane
- noob planes.
- am transmitter and receiver
- Any movies/picture on aeromodelling
- Hitec Owners Please Help me Out
- Relative wind impact on scale models
- First Bi Plane?
- Aerobat Trainer Help
- Advice on 2nd plane - low wing
- Help big time Beginner
- Fuel Ratio
- Thanks! First Radio
- Rebuilding
- What is a good Beginner BI-Plane?
- GP PT40 problems?
- Rewing of LT-40
- APC props on FX46, bad???
- Flight Control Surfaces
- My Extra 300S....
- throttle channel keeps servo moving help ??? NEW RADIO
- Append: First Radio!
- new to this hobby HELP
- Removing LT-40 Dihedral
- Prop Damage
- Propeller question
- First Electric?
- Enya and Fox engines
- os engines
- LT 40 dihedral
- delete
- ink spot
- Flat bottom or Semi-Symmetrical
- whats a servo saver?
- 1st Radio !
- Where should I start and where do I go from there?
- How long before Kadet gets boring?
- Engine cutout
- affect of front wheel on flying and servo
- new to r/c planes, advice appreciated
- beginning beginner
- Gel Cell Batteries
- Nyrod question
- Is monokote water proof
- Why is the 8uaf so popular?
- 6 years old...
- Prop Question
- Advice from the pros...?
- Nose and tail wheel "throw"
- Pete n' Poke
- Flash 5 (Hitec)
- Ailerons & rudder
- rubber bands or bolt on wings????
- 2nd Plane
- Trying not to be cocky
- Shopping List
- 2 or 4 Stroke??
- Flat-bottom vs semi-symmetrical airfoil.
- titebond glue
- When to use servo saver ?
- Prop size and Pitch
- Fuel soaked fuse
- tuned pipes???
- New to R/C Planes & Joining AMA
- Flight trim article
- My 2 cents
- Four Star 60 covering job
- Hitec to Futaba compatibility
- Radio/Receiver Match
- newbie question
- What fuel level when balancing?
- GP PT-20 w/ o.s. 25la-enough power?
- Whats the most Important Item to have in a field Box.
- basic building/repair questions
- gws micro Rx, for example.....
- servo chatter
- my first solo flight
- Sig LT-40 Control Throws?
- landing
- kyosho spifire 2nd plane?
- is enya a goof engine?
- Color scheme
