View Full Version : Beginners
- RCU administrator
- Newbs first flight.
- Prop Difference
- New and hoping for guidance
- Old timers
- New Instructor with First Student
- fuel cans
- .25 engine needing a plane
- After two years away......
- Solo'd
- prop reccomendations for minnow OS91
- What do you prefer and why, 2 vs. 4 stroke?
- Saito Twin / Propeller Question?
- Nathanspam post
- Hanging Glow Planes vertically BAD!?
- The great airframe apocalypse
- REPOST: Two firsts last sunday
- Epoxy Rudder/Elavator Hinges
- Please help with battery selection.
- Clean out those garages!
- 8103/dual aileron servos/flap question?
- "World Models"
- Servos / flight pack for Sig 4* 60
- Plane Seems Unstable On The Ground
- Bragging about the .55 AX
- du_Bro kwik fuel valve system
- Servos
- Maiden Flight
- Plane Tail Hold-Down
- Tower 40 antenna installation
- Engine Bad Luck
- OK newbs, Learn a quick stupid bit of advice from me.
- help with quick charger???
- How should servos be installed?
- Question for RCKen
- In need of some repair advice.
- OS 46 Excessive Vibration?
- ironing wrinkles on stabs
- Fiberglass with Polyurethane
- the Magister is fixed!!!
- A big thanks to all you Tiger 60 owners
- Plane cut throttle 3 times in flight, every flight... :(
- 4-channel trainer
- plane for a "renewed pilot"
- Servos Question (Is it worth it)
- Info On Charger That Comes With Tower Trainer (Tower Hobbies 4-TH)
- Question about using a "Y"
- Balance Charger Recommendations Please
- low wing planes
- servos and channels
- What's your favorite size plane?
- PT-60 needs more control
- Well, I bought a 2nd Plane, but it's not a Kaos . . .
- Pushrods....
- Fuel tubing issues
- engine trouble
- It's done. First day at the club field, and I Solo'd
- Best Standard Servo for the Money
- PZ J-3 Cub gearbox problem
- Epoxy on ultracote
- low wing trainer help...
- Horizon Hobby, Need reciept??
- Noob question
- OK for second plane?
- more battery questions....
- amp gauge?
- Confused about Ball Links for push rods
- Any Hobbystores in Charlotte NC?
- MIT OPEN COURSE- Aircraft Systems Engineering
- DX6i, 7 servos and I want flaps please!!!
- Strengthening Lower Fuselage
- First KIT
- Climate Changes affect storing planes?
- F-22 Raptor Hangar 9 - Installing Flaps
- HiTec Servo Cheap!!
- 4-channel trainer?
- I did it!
- First Post - Seeking Trainier Advice
- Inverted Engines
- SC eng adjustment
- Finished my Avistar, Few questions and abnormalities...perhaps normal?
- guys
- Avistar AV-46 carb problems
- Fun new electro toy
- LOOK what my Dad's freind gave me!!
- Engine mounting problem.
- 3 blades - easier?
- CA hinges VS pinned hinges
- Gorilla wood glue
- A Huge THANK YOU to RCU and Mods
- How Do I Become an RCU Reviewer
- Muffler gasket
- I'm Back
- What is Glow Glide?
- Radio Noise
- engine causing grief!!
- Vinyl stickers for planes. Who?
- Randy Randolph Easy
- Need help with Hobbico CA hinges
- 4CH VS 6CH?
- Icanfly by Dynam? Dymond Gone?
- What to do with your trainer?
- Sonic , Uproar or Kaos?
- CG and Lateral Balancing
- Noob Radio Questions
- Adjusting CG
- oops, I suffered from over confidence.
- Motor question
- midwest aerostar
- Video from the beginnings
- About the LT-40 crash
- Battery Questions
- This deserves its own thread, ( in regards to son's crashed LT-40)
- Adding Castor to fuel
- Any other teen flyers?
- cycling nicd batteries
- Anyone with a Tower .46 ! Where's the low speed needle Located?
- Can't Tighten Prop Nut
- NEW RADIO OR SERVOS????????
- HEY Missleman!
- Quick .46 Question
- CURIOUS TO KNOW: How is the plane from RCKen's build hanging in?
- Well, it happened.
- Ok, almost done. Does this look right?
- Solo'd!
- Concerns about Spectrum radios
- futaba horns
- different PTS
- Tank Installation Help....
- I went to the Toledo Show
- Dihedral
- What kind of starter do I need
- Can I use a 4S1P in my NexStar EP?
- Some brushed to brushless conversion questions
- first time starting
- Please help me tune my OS 46 AX
- 2 PC sims and a USB controller for under $60
- Adjusting control throws
- Nitro, gas and glow?
- VIDEO- Model Airplanes from the 1930s-1960s
- Dual rates and expo
- Hitec 645 HB help
- Weather stripping the wing saddle
- How do you judge your fuel consumption
- I hope this will fly
- Adding weight to Nose Heavy Tower
- First glow flight since last November!
- f4u corsair in the making...
- Fuel Tank Mounting?
- Spektrum lawsuit???
- covering on my tiger 2
- Monday morning Big Stick 60
- Rules and regs for RC systems
- Reciever for my HiTech Flash 4
- Sullivan onboard glow hookup??
- Easystar vs. T-Hawk vs. Firebird etc.
- Kit Building for Beginners
- What is the composition of nitro Exhaust ?
- Voltwatch question
- Can we talk about servos a bit?
- Flaps,Spoilers,Crows, & tight Loops....
- Tower Trainer 40 - Engine Moved Fwd.
- rx battery source
- Fiberglass?
- PIPER CUB SAITO .72 or .82
- 2.4 which six channel radio?
- Movies
- Beaver question
- Spektrum DX6i, the best $200 dollar radio?
- Plane For Making Movie
- Hitec receiver with Futaba Tx
- model classifications
- Covering Over Cap Strips
- engines in storage?
- advice on 3rd plane
- Flying Girlfriend... suggestion
- RC Ken and MinnFlyer have joined forces
- More about covering...
- Spoilerons or Flaperons?
- Best prop for Kadet LT-40 w/ .46 Evolution?
- Alpha 40 dsm radio
- LiPo battery size => flight duration?
- Buddy box question
- Any new flights this weekend ??
- Simulator
- OS91 4 cycle valve adjust?
- Tower Trainer Requires Trimming every flight! Why?
- blind nut issues/wing saddle help
- pulse xt 40 second plane
- pulse xt 40
- Last roll call before placing order. Please Chime in, much appreciated
- DIHEDRAL TOO HIGH
- Airlerons vs Rudder?????????
- EAA Young Eagles
- Radio help
- 2 suggestions needed ( little new to R/C)
- covering question
- Thunder Tiger PRO .40 break in.
- Fuel Filter
- Nexstar is my blood
- First Plane
- Planes available for the Aero Fly flight sim??
- Help Starting Older Tower .46
- Flight Simulators
- Elevator/stabilizer play
- nbew wing
- Nexstar ARF - Nitro or Electric
- What servo would be like the HiTec 645
- Looking for something I can get aerobatic with.
- Can u paint a foam parkzone?
- I have wind.........
- Installing control horns
- How do you land?
- muffler leaking on a OS 46Fx
- New Here, few questions
- Airplane "size"
- futaba servos in jr receiver
- When will you change your plug?
- hmm.. What esc + battery should i pair up with my 50mm diameter 300kv rating motor?
- Which is better bang for your buck?
- lube question?
- Super Cub vs. Parkzone J-3 BL
- technique to mix your fuel....
- Sig Four Star VS Pacific Knockabout
- prop fitting
- Construction question
- Brake Systems?
- Will OS 70 Surpass fly the Funtana X 50?
- This hobby would be much more popular..........
- Firebird Freedom Mods
- Using the same TX on differnt planes
- Nexstar Engine Mount
- Tractor Vs. Pusher
- engine
- Newbie with Servo and Radio questions
- problems
- New to rc. Need help starting.
- High Speed Electric and the Pipe Dream
- 2 questions:
- What ya think?
- Four Star 40 about to be conceived.
- prop size for 180 4s.
- thread lock on servo screws?
- Discoveries in Friend's Basement!
- Super Tigre G.51 runs backwards
- What fuel for Saito .72
- Wing Dragon plane
- Beginner needs advice
- Four stroke Saito dying in air. Tweaks?
- Does the Funtana X 50 ARF come with a spinner?
