View Full Version : Beginners
- what a great day to fly!I
- Workshop
- Electric
- Futaba 7C 7-Channel 2.4GHz Air
- Tapes??
- the crash!
- new evo .46 engine won't hold high rpms.
- Nicad receiver battery
- New Alabama Flyer, hangar 9 tango fuel tank issue,
- quick LiPo question
- New here
- Avistar Flight time
- Refueling Supersportster
- ahhhhhhhh fults
- Does the servo need to be centered for aileron torque rods?
- OS Max engine designations
- Ambiguously specified part in GP Extra kit
- Just a question????
- Balance problem
- Power and weight : How to tell if a plane will fly
- Damn, I'm good...
- Why Do My Servos "Chatter"?
- Help
- Changing tune
- Hobbico J-3 Piper Cub
- Discharging SubC NiCads
- Second Plane Tail Dragger recomendations
- Muffler Positioning...How critical?
- Want to buy OS 4-stroke tools please help
- Saito 180 starter?
- Control Horns throws?
- Warped Fuselage
- buying a wife an airplane
- AMA Membership
- Difference between CA Hinge to Pinned Hinge?
- New question on glues
- Trouble today on my 4*60 build
- Anyone outhere from Valley Forge Signal Seekers
- LT 40 to tail drager
- Pattern flying?
- newbie friendly tail dragger RTF
- Need help putting engine in P51
- Saito 82 vent line
- Nexstar v/s Alpha 60 for newbie
- From Trainer to Stik
- what to do?
- I hate my evolution .61
- YAK 54 Crash during maiden flight
- Air bubbles between the carb and needle valve, Is it serious?
- Saito rebuild question
- reassembling engine ???
- threading pushrod
- A
- SPADs
- Newbie building questions
- Vent Open Bay Areas in Wing?
- Well whatdaya know ..
- First photos of my 4*60 build
- Wheelchair guy wants to get into RC Flying
- rolling left
- General field etiquette/rules questions
- Hand Tools Help
- which servo/receiver?
- Dang Wind !!!!
- Showtime maiden in the drink
- Tiger 2 and Eagle 2 ARFs to be discontinued?
- 4 Stroke Engine Fuel?
- jr xp6102 default settings??
- Fiberglass Cowl cutting and fitting.
- R/C Electric 2-Channel Fan-Tail Flyer
- Engine mount suggestions needed for OS 90 4-stroke
- Where to buy? RV4-40 kit parts?
- What's it all mean?
- how do I prevent from my engine run too lean?
- Does anyone use Great Planes Nylon hinges?
- On board glow V. ignition on glow
- Fuel Injected model engine
- My big baby is almost ready for paint!
- What is the correct way to bevel the ailerons?
- How do you cut slots for hinges
- mustang and yak 54
- In-Line Fuel Filter Install Help
- Anudder newb question: plane storage?
- voltmeter
- What to buy
- "Marie" P-51D
- 4*60 Build starting Is there a site with help?
- Instructing Hearing challenged student
- Centerline on firewall
- New charger called Hyperion ???
- Ultracote Backing Material?
- lowest safe voltage to fly a ar7000 reciever
- RX/Crystal ?
- First plane: Alpha 40 or Alpha 60?
- Plane Recommendation
- I just bought a new hitec eclipse 7
- Ultracote lite
- Alpha 40 problem
- ST G20/23 PROBLEM?! NO PROBLEM!
- Nexstar & Saito 72
- Transporting Planes
- Re-drilling hinge slots
- I need a link on this site for used glow engines for sale please
- What does
- saito fs fuel?
- Ultrakote
- Women fliers
- Missing Person
- Engine Out Help
- What HOW TO book to buy for building?
- skybolt engine
- 4 stroke fuel line set up
- Thinking about buying a plane
- Engine test stand designs to build or buy...
- Slow Poke 40
- COLOR FOR VISABILITY
- landing gear wire ...
- Help a newbie choose first plane
- Where can I find instruction on how to fly?
- Lost plane device
- fuel tank for gas engines
- kyosho calmato 40 trainer
- will it fog
- E-Flite ultra stick 25e
- Tail heavy Slow Stick
- what is this blue thing??
- How do you get the quotes at the bottom of the page
- NHS Fuel Line
- High low band receiver
- OS 90 four stroke engine manual needed
- Fuel Tank Issue
- Blowing in the wind
- carbon props
- Word of advise!
- How do I remove hardened epoxy safely?
- Propellers?????
- I’m looking for a switch like a servo
- another 2.4 question.
- Stupid question about fuel tanks!
- Lipos for reciever?
- OS 90 four cycle engine new in box
- how do i connect a srvo to my engine
- help for my sister
- Thinking of starting this hobby, in Sweden
- hobbico hobbistar 60 mk III help!!!!!
- Engine for club pylon race
- lipo field charger?
- Off topic ?
- fuel inside fuselage
- Is this a bad idea?
- cisaster and a bad plane
- Extra Tail Weight - where & how?
- need tips
- dx7 binding
- os 46ax
- Need Charger
- Identify two planes
- Why is the goldberg cub not a good trainer
- high voltage power lines
- spectrum battery and charger
- Pull-pull crimp?
- whats the difference
- Need comments on the Neptune ARF
- Scratched my Tru-Turn Spinner - How to remove?
- .30 size nitro in E flite mini planes ?
- Overcharging Tx,Rx batteries
- Show how you Set up your Trailer
- Single or Double Converstion???
- Tower .75 Muffler
- E-Flite J-3 Cub (25 size motor)
- correction regarding specification need help to build a plane from scratch
- Noobs Want To Know How Your Engine Works?
- Ball link on Throttle arm?
- Old JR Century VII
- BIG PROBLEM!!!
- cessna 182
- Parkzone Typhoon
- battery storage
- dang spinner
- Extra Weight added to Easysport 40
- How do I mount a brushless motor, easily
- 9 CAP VS 9 CAS????
- Change K+B 3.5 from marine to prop
- What Fuel Do I Need?
- Scratch build (small)
- O.S. .40 LA engine
- Super skybolt arf help
- Finally - But Ouch!
- motor run fast, then slow, then fast
- question about the phantom
- first solo then a disaster
- Any disabled pilots out there?
- Is a 75 too big for a Dazzler?
- Cleaning and overhall of engines
- After Run oil question again.....
- CG location question
- This is a joke
- Help! - Exponential Controls
- battery test
- Will this engine set-up cause problems?
- NAME THAT PLANE!!
- Lipo Batteries and balance charger
- Drilling straight cntrl horns
- +6v rx battery
- nexstar diving problems
- Better Propeller?
- Storing your Planes @ Home
- what happened
- I'm new
- Snap??????
- Which is the most durable 4 channel plane?
- Ouch! That hurt!
- which 2nd plane?
- Motor w/pinion
- Stall strip
- Tiger 60 changes
- JR XP7202 w/ JR s400 buddy box
- .25 trainer arf
- Need help with JR 7202 radio
- What is a blog exactly ?
- Setting throws
- had a good find today!
- Problems with ailerons
- fill valve question
- Why does it screech like that?
- Senior Telemaster ARF or not to ARF
- ahh please help - NEXSTAR
- RX battery question
- Monokote
- tail trouble
- 3 1/4 TRU Spinner
- multiplex easystar help
- Nexstar Prop
- SDM Piper Cub
- Parkzones WWII Fighters?
- Covering question and sealing it to
- Can anyone tell me truthfully if it is difficult to fly a rc plane?
- Hanger 9 Arrow semi sym. trainer wing flutter..?
- Has anyone converted a Sig Rascal 40 -Glow to Electric?
- Hitec RCD Supreme Receiver - Anyone know anything about these?
- Well I did it today.
- Rx Upside-down - bad idea? Mounting small servos?
- low vs mid wing?
- Prop for Saito 91?
- J-3 Cub 25 ARF
- First low wing / Tail dragger, which do I buy?
- Flying with skis - trike or taildragger?
- Plane for 4-year-old?
- Have to plug a catalog
- slow throttle response?
