- Cleaning a crashed engine
- Which Radio?
- Wiring for Field Box
- low transmitter battery affect signal?
- 2 RX batteries
- Help with fuel
- Hobby-lobby YAK-55 3d profile???
- I figure I might as well
- Pulse XT 40
- Internet resources on flying. Any one know any?
- Slop in aileron!
- Hanger 9 P-51 PTS
- What kind of fuel is best for my engines?
- 1st Plane - Sig Kadet EP-42?
- wing stall?
- OS .46LA install
- Directions for Disassembling/Assembling of 2C or 4C engines for Newbies
- 2nd plane, first build pick question
- NexStar Windows
- solo material.
- Carbon Fiber to Wing
- alerons or rudder
- big stick 40 question
- fuel build up on the muffler?
- Flaperon mixing...
- What are these and how do they work.
- "50" size planes
- Alpha 40 or Arrow 40?
- Speed Controllers
- I hate when this happens!
- is this a tiger II in a new skin?
- engine not tuned
- LiPo ?s
- Where's Bev?
- Damn - Too many choices
- 2nd day out.
- Removing dry epoxy from monokote
- Does it count if
- Hinges
- is it good
- Covering gaps in control surfaces
- need battery size info.
- Need new 4 stroke for Big Stick 40
- Sealing a ARF tank
- Newby that want to know...
- Better Landings finally!
- What Plane?
- READY to start my RCing
- monokote on monokote question
- GRRR...ANOTHER QUESTION-RADIOS
- Big Brothers
- solo'd today
- Next after Electristar
- Prop coming loose
- DuBro Spinner - Add Washer?
- first fly
- Combat ???
- Glow vs. Gas
- Sailplanes in Louisiana
- First 4-stroke - odd noises?
- Hobby Zone Super Cub versus Hobbico Super Star EP
- Self taught
- New plane and motor question
- New to R/C
- Results of mixing own fuel
- Larger engine for a Extreme 540 by Goldberg
- OS.91 4-stroke shaker
- My first Glow engine
- Engine Cleaning
- SULLIVAN TAILWHEEL ASSEMBLY
- Under the hood
- 1st Tower Trainer .40
- 1ST TIMER - canopy staining
- 7CA 2.4ghz
- When is a Newbie Not a not a Newbie
- Flaperons?
- First Solo Flights
- Set up
- Nitro Parkflyers??
- 1ST TIMER with tube wing mount - gaps
- An all around good charger
- Avistar
- What kind of Crazy Weights have you used?
- Bolt terminology?
- Replacing glow plugs.
- Stunts
- Fuel starvation when flying inverted
- Engine Mount for YS 1.10
- Anyone familiar with Westerville,Ohio flight club
- leaning to fly
- Top Flight prop balancer
- Super Tiger G2300
- What makes a plane a "sport" plane?
- Epoxy ?
- Developing an appreciation for "the Classics"
- Modelers and cats
- w00t - Its airborn!
- Covering
- Flatouts?
- Inrunner selection
- Check valve = Too MUCH pressure?
- Stupid Battery question
- Antenna Placement - An Embarassing Story
- GP Sportster Deal?
- Aerobird Swift Giving me troubles
- Engine placement
- servo chatter/spastic
- Well newb here
- Slow stick build
- 1/16 off
- Solo flight mark II
- Hanger 9 Arrow ARF
- break in
- Futaba receiver
- Pledge to shine your plane?
- About a second plane.
- dazzler kit
- muffer exhaust angle
- yak maiden
- hobbyzone super cub
- Replacing fuel tank
- Control horn and adjusting elevator throw
- How much could I get for this radio?
- BRUSHLESS ESC/BRUSHED ESC
- Need to pick a model...
- Fuel Can Fitting Set
- 2 blade to 3blade prop
- Hinge Gap Question
- Park Flyers: Which is best for the beginner?
- Installing floats on trainer .40 ARF
- Good trainer plane???
- Whats the difference.
- im getting bored lol
- going for speed
- USING A SPECTRUM DX 7 WITH AN AR 6000
- Alpha 60 reciever
- Newbie Question
- I did it!! solo flight
- glow plug mistake?
- trainers: engine size, prop size, weight
- Battery Chargers
- wet plane
- How to make sure engine is put on straight?
- motor mixture wrong
- Servo Chatter on Field Test
- OS 46 "pumper" engine?
- Field Boxes out of Tool Boxes
- Magnum 61fs in SSE prop advice?????
- Prop size + engine..
- Vibration reduction mounts
- How do i setup a gas Tank on a 40cc gasser
- Tiger Moth .25-.32 balance point?
- Spinners
- tiger 60 balance point
- what is these?
- trainer set up
- Removing Covering
- Can lean low speed needle damage engine
- Homemade
- Nexstar on Floats???
- control throws
- Removing Glow Fuel Residue
- saito 100 setting
- Yet another question
- Elvolution 3 blad training prop on nexstar?
- aerobird 3 problem
- Getting the Reciever and Plane in tact.
- Glow engine tuning help.
- Tiger 2 ARF
- Which are long lasting engines ABC or Ringed???
- MONOKOTE
- fuel
- 1st plane build ever.. please help.
- 2nd plane
- How to construct new 2m wings! :)
- wing Loading????????
- Old plane conversion
- I have made my descision
- What would YOU do?
- Pinch test
- Noob needs help
- stuck in a sticky mess
- Is it good to run a 2Stroke Engine Rich or Lean?
- So ugly I have to fly it.
- Battery discharge rate ?
- bobby boykin 1st solo
- Trying to land in a small area..any help?
- servos for sig four star
- What would be the best WW1 kit to build?
- Smoke From Fuel Line When Filling
- Cg issues
- World Models t-34 Mentor Decal question
- Need fuel tank set up help
- Energizer Rechargeable NiMH
- Please help me identify this engine
- Good 2m .10 powered glider
- Plane Suggestion for Dad
- Creating stickers from DVD/CD label
- Stupid Rx question!
- Slow Poke?
- Radio and first plane
- High Wind RC Aircraft
- Muffler falling off.
- How to adjust cg
- covering Irons question
- Futaba 6EXAS Radio Question
- Indoor flight??
- First Solo Flight
- Thin CA, corosion in lid
- thinning expoy
- Futaba 6EXAS 6-Channel FM/4 S3004 Servos 54
- Tx setting spreadsheet - good stuff!
- Fuel dot and fuel T for cowling covered eng
- E-Flige Mini Edge 540 Questions
- Transmitter Case
- Landing...
- tail wheel.
- Re-attatching a Canopy?
- Help me identify please....
- Hobbistar 60 Landing Gear
- .10 Kit
- Battery sense and nonsenseability
- returning after 15 years & need your input
- How to re-attach trim on nexstar?
- Is it customary
- Throttle linkage Setup
- Antenna Shroud - Do You Need It?
- MOVED: For the New Guys!!!!!
- Broken Props
- Manual needed for the "CMP F4U Corsair50"
- First Plane! Which between the two
- Input on Alpha .60 Hanger 9 ARF plane possibility for Trainer
- Newbie Simulator Experiences
- Industry ethics?
- Is a sea plane hard to fly
- A radio to grow with
- Taxiing Question; Tail dragger
- Where is my CG now?
- NEED HELP!!!!!
- Sig Kadet Junior 25 or 46
- Fiberglass wing tape?
- What is the best motor for the F4U Corsair 50?
- My first CMP F4U Corsair 50
- Additional Servos on a Hobbistar 60
- need airframe ideas..
- Repositioning Hi-speed needle
- Mid-Star 40 3 view drawing?
- Monocoat Hindges Safe?
- CG edge 540 Questions
- Improper break-in
