- Selling 4 planes on ebay! Where to post on rcuniverse
- Inverted engines?
- WHY DO YOU LIKE TO FLY???
- NexSTAR taildragger?
- Ultrastick 40 balancing ?
- RCU bias against ARF's
- Planes made from a H9 Alpha RTF Trainer
- Single or dual conversion - help
- stripped muffler screw
- Going to take the plung next week need some help
- Hinges
- car/plane
- First Solo
- Changing Fusilage on J3-Cub (Park Zone)
- rudder, elevator help
- .15 in a plane?
- Beginers/Newbies Read this on how NOT to assemble an ARF
- Took the first step to complete my dream...
- Alpha 60 and beginner pilot success story!
- Relearn to fly.
- Prop hole diameter question. Help
- Happy Valentines Day!
- My First Trainee!
- Saito .56
- Help with identification
- black widow trouble
- I ordered my first plane.
- Whats a good .25 sized airplane?
- Grape flavored fuel?
- OS .46 FX Exhaust/Residue Color
- Mixing your own fuel?
- nexstar fuel leak help!
- Just finished my field gear.
- Can I use any 12v wall wart to charge 12v batt?
- Learning on the frog
- Are Airplanes Reliable, Becauses My Cars Aint
- Basic question about banana clips
- just wondering
- 12 V Seriously Newb ?
- Everything was going fine.....and then #%$^
- questions
- SuperTigre 45 having some issues at idle
- SIG Pushrods.
- Tx, Rx, ESC, and Servos questions
- Engine Recommendation for LT-40
- GWS Zero Fighter
- I'm a total newbie
- crystal question
- LT-40 Tail Wheel
- Stripped Wheel Collar removal?
- DISASTER!!!!
- Hobbico NexSTAR Simulator
- gws me 109 for slope
- insurance FYI
- OMG I did it!!!!!!!
- Thanks!
- Ourstanding resource for new pilots
- Radio Question Heli or Air?
- Question about throws...
- I really need help.......
- Life for my OS 46 LA after my trainer...
- Spent fuel color myth?
- Plane/Engine combo...
- Looking to upgrade ! NexSTAR is old and boring now
- Fingers on the sticks????
- WM T-34 Mentor Or Other War Planes (Second)
- It Does work!!!!!!!!!!!!!!
- Simulator or not....
- All Newbie and Wannabe RC Pilots..listen up
- new plane and first flight
- Firebird II
- Mac smoke system?
- First flight, First crash! 1 and only plane!
- Fuel line Prob?
- Exhaust Question
- Any views on the Magnum XLS-52 BB/ABC/FSR ?
- smoke for a trainer
- What to do...crash story!
- Introducing myself.....
- MOVED: Hobbico Sukhoi SU-31 ARF
- How do I know?
- spiraling two servo - good or bad practice?
- Where to Fly.....Lakeland, Florida
- Just did my solo!!!
- OS .46AX Quits nose down
- Another new guy!
- cub
- A second Plane - Low wing trainer
- Alpha trainer 60 by Hanger 9 VS NexSTAR's 46FXi engine
- futaba t6xa good radio???
- Fuel Tank Question
- Chase City , Va
- $$$$$$$$ Payback
- PCM or PPM Radio?
- One Week to Solo video
- tt pro 46 vs. os 46 ax
- Getting started is so dang hard
- Avistar Maiden Flight
- OS FS-70 Surpass II for CG Chipmunk?
- Free Shipping @ Tower Hobbies
- HELP!!! Maiden flight right off
- Stripped threads in plywood
- .25 LA vs .25FX
- role call!!!!!! Lt-40 pilots.
- First Flight of The SuperStar
- Prop draws blood
- Who knows...
- Any differences between Goldberg Falcon 56 Mark2 (1980's kit) and the current Falcon 56 Mark3 kit???
- flight sim for mac computers
- my first solo
- Nexstar Success guarentee?
- OS FS .91 same as OS FS .91 Surpass II?
- Taildragger
- Learning to fly with a mid-wing tail dragger????
- Draining fuel tank
- Will this work
- Airplane Fuel
- Shelf life question
- old battery.
- Evo 61 NT what Prop?
- Muffler fell off
- Have I tought myself a bad habbit
- CG test
- EPA
- thinning epoxy
- 2nd choice
- Smaller plane
- Field box and accessories
- IMAA ?
- I got a lt-40!!
- Simulators
- 6EXA Radio question
- Taildragger question....
- thunder tiger 46 for kaos 40
- Switch posistion
- Seagull Decathlon
- Painting Advice Required
- ROD HELP
- PA flying fields
- learning to build
- Alpha 60
- Fueling and De-Fueling
- applying covering
- Saito FA 56 problem.
- Engine Mount Question
- 2 Rx's why??
- Prop popping off
- It Flies!!
- Dual Feed Engines
- nexstar wing tip extensions
- Razor Slice Under Wing
- **Update w/ Pics** First Plane First Build !! I'm still around!
- Running In
- Servo extension
- Engine for Trainer - LA or AX?
- Was it just me
- Bubbles in Monokote What went wrong?
- The anti-ARF sentiment is not healthy
- Y Harness
- After run oil or not?
- question of collor...
- Used to much after run oil
- Protech Skydancer
- Alpha trainer .40 by Hanger 9
- battery charging question
- 2nd plane the tower kaos or the voyager
- mounting engine
- dark oil problem
- Spoilers/Spoilerons
- How do you "uncover" Monokote?
- mounting engine
- Has your wife or g/f gotten mad about r/c?
- Motor spewing fuel
- The most popular question of all...
- Sig Four-Star 60 & Sig Four-Star 40
- please help identify plane.
- Question about "T" fuel dots
- Eek broken throttle on Aerobird Challenger
- question about futaba 6exa
- Does FuntanaS 90 aileron hinges could be ??
- Dual Aileron Servos on Avistar
- expo?
- Help choosing an engine
- Replacement parts
- GLOW FUEL STORAGE ?
- Sig LT-40 ARF Right Wing
- Trainer Battle Royal - Sig Kadet LT-40 vs. Hobby Lobby Telemaster
- Airtronics RD6000 Newbie Question
- Epoxy Wing
- Basic question about batteries
- MOVED: Do they sell Ducted Fan kits separately?
- Avistar ARF Build
- Hey Guys New To The Forum With Some ?'s
- Anyone heard of this or flown one "SD J3 Grasshopper "
- Dual Rates
- Got my stuff in too!
- Exponential
- Bigger fuel tank on nexSTAR ?
- Who flies off the ice?
- Wood VS prastic prop ? I did a search
- reciever question
- MOVED: plane identification
- Crooked engine on NexStar?!
- Almost there!
- CA GLUE & EPOXY
- Missing instructions
- My Addiction - (long post but a short story) by Cazarak
- Kadet Seniors
- Suggestions for third plane
- as wJust Got My Stuff
- question on landings
- I want to hear you say.....
- newbie: gas tank position relative to engine
- rotating case motors
- Avistar or Superstar?
- Fuel out of Muffler
- Perry Carbs
- Ready to choose my first plane!
- Spinner size
- Trainer Suggestions Needed
- glow carb- tank relationship
- Altitude is your friend, Speed is your enemy
- North Jersey Area
- Graupner J-3 piper cub??
- Engine Question
- Side mounting engine
- Goldberg Tiger 60 pilots!!!
- Purchase new .40-.46 plane..
- Thunder Tiger Lazy Tiger P-51 PROP question
- Should I fly it??? extra 300s
- what have I done
- Aero Bird Nose Dive????????
- What clear coat will work?
- While I'm Waiting
- Smoke on Saito 91
- nexstar landing gear?
- U-Can-Do Cowl?
- Nitro aftershave?
- glue question
- Our new "Precedent Hi Boy 2"
- Not Sure
- Exhaust tubing
- Wooden Prop Comparison
- still waiting.
- gas tank and fuel line set up
- anhedral in Ultra stick 40
- Instuctor in Houston?
- Quick engine comparison.
- fuel line touching engine?
