View Full Version : Beginners
- Gas Engine
- oil removal
- Painting a foam EPO plane
- Charge lead question.
- charge lead wires
- Sullivan on board glow igniter
- Great Planes Avistar Elite
- Two Planes, Two Questions
- Building Board
- Some Questions for a newbe
- 1/4 scale cub skylight
- E flite apprentice problem
- Servo lead problem
- hello all
- Transmitter battery voltage
- Maiden flight with Apprentice STS question
- Engine for a Sig Kadet Mark II
- Newbie needs help with Arrows Bigfoot wiring
- Advice wanted
- Control throw issue
- Groove g480 questions
- advice on beginner plane
- The Multiplex Easystar
- Maiden flight of the Super Frontier Senior
- Buddy Box Question
- Float Flying with the Mentor
- Spektrum Radio Locked Up
- Seagull Boomerang Trainer
- Another Servo/Radio Question
- ESC programming
- Mode1 Vs Mode2
- Antenna Placement
- Kit recommendations
- Prop Will not stay Tght
- looking to make a preferably sub-250g long range motorglider type plane
- digital cockpit telemetry displays
- Servo Question
- can i extend transmitter antenna using wire?
- Seized Engine
- Where do you get your wood?
- Engine Modification 30 Vigilant RC
- Getting back to flying
- First build help suggestions...
- Remote ID Questions
- Controlling multiple motors
- Custom Landing Gears
- new member
- Vintage Servo Question
- Dual control surface servos
- Retracts Question
- Returning to hobby questions……
- Need help identifying an airplane engine that has dual glow plugs.
- Searching for a specific setup
- flight controllers
- Sig Kadet Mark II Kits
- Trying to get back in the saddle
- SoCal flying clubs ?
- Where to buy Nitro Miami area
- Setting control surface throw.
- Futaba 16IZ question
- Hello, new here! Digital servo question
- Art Tech Cessna RTF
- First balsa kit recommendations
- Newbie question about basic parts
- Looking for new plane…
- New to the hobby
- First plane
- parachute does not open
- New Pilot!
- Did I get a good deal?
- How much land ?
- beginner rockets
- Receiver Linking trouble
- Question about motor specs
- Vintage Tower Trainer 46 on snow skis from the WAY BACK MACHINE!
- Can I be fined for losing my plane?
- Rear plate gasket for OS46FX
- Where to get the model body / cowl?
- Aeroscout s2 will barely roll left
- Parkinson's Foundation RC flight instruction
- Suggestions For Next Airplane
- Looking for trainer model advice please
- Receiver and servo compatibility
- Can anyone help?
- Esc rebooting
- NexStar Info needed
- Battery amperage needed for my plane
- Looking for pro tips for DX radios
- May get back into RC after long absence and have questions, reposting from Radios...
- EVA Foam Core??
- DX6I battery door
- Hinge repair - foamy
- Can wings actually rip off in flight ?
- Tuning a 2-stroke .46 size nitro engine
- Glow Plug Issues
- Herr Mini Sport Fin
- Question about damaged motor
- Durafly Prime Tundra 1200mm STOL Trainer
- How have you been treated in your club
- Remove window from foam plane
- Best Scratch build to start
- Best plane for a Rimfire 400 motor
- Control throws
- Should I buy this plane ???
- RADIOMASTER TX16S - re-activating a HK Corsair modelxx.bin + deleted model
- My Best Beginner RC Plane Advice
- scratch build deltawing CG
- Rc plane help needed
- Glow engine won't run
- which radio?
- WTH? Long time coming back.. so confused
- Good material for RC construction?
- FMS Ranger 850mm RTF GPS RC Trainer Plane
- Blow Up my Esc :3
- EDF speed and throttle issue
- Balancing plane
- Hobbico Nexstar Parts
- Z Benders
- New to Electric need help
- oil problem
- Help
- what to buy
- Plane
- Nitro fuel tank question
- Help with getting older models running again
- nx6
- B737 max
- HELP! Flight Mode and SAFe on new PC-21
- Beginner's kit
- Skyhunter micro too much elevator rolls it left
- Engine mount on firewall
- So new I squeek. A bit over overwhelming
- Power and Power loading Unit
- Edgley Opitica
- Fuse length
- HS-422 or HS-425BB
- SIG Field Box - NO Power Panel
- Arrows RC Pioneer 620mm RTF Trainer Plane
- oil problem
- Wall Powered AC Motor
- AT10 11 compatability
- Newbie looking for parts
- Motor trouble
- First Warbird?
- mounting a propellor?
- Propeller spin direction on a multirotor airplane.
- Can somebody recommend good quality motor with thrust 8-10kg for fixed wing plane?
- balsa wood component thickness
- Smart battery install
- cross sectional sizing on wing spar
- Programming the Spektrum AR636A / AS3X
- What components to use for a heavy-lift long-range fixed wing plane?
- Horizon Sport Cub S-2 Question for anyone
- Pay-Pal Credit.....BEWARE !!!!!!
- Needs plans for my plane
- Thunder Tiger Sky Lark 40T
- Making my RC Seaplane, where to place the motors
- Multi purpose charger
- tamiya hornet wheels
- WWI scale kit or plans
- New from Wisconsin
- need instrucions, cox spitfire mk xiv
- instruction manual
- shipping tube fuselage
- Is Value Hobby really a value?
- What Do I Have Here?
- How to choose servos, hinges, hardware?
- Its been 30 years
- Dual Rate Question
- What servos do I need for a spad debonair
- Getting back into the hobby need advice
- Receiver 6.0V 2000mAh NiMH
- Receiver Mounting
- Return after 24 years
- ALZRC X360 set up questions
- Big flying wing build
- Motor asp 0.61 4 tiempos, que tal este motor ?
- Plano avion Lucky star 40 sport trainer, chino. SE busca
- Redcon cm703 satellite rx wiring
- Beginner questions
- Battery power supply to servo, stand alone, help.
- Reciever/Servos Battery
- Noob questions
- Attaching wing to fuselage
- Propeller for an Old Cub
- Which electronics should I choose?
- I need help to rebuild RC helicopter
- Running Omega in an OS 46 FX
- Brownouts ? I think
- Where to buy a drone – reliable & a good price
- Is GPS really necessary for a beginner & your suggestions
- Buzzing Servo
- Enya 09-IV engine bring back to life! Need some advice
- Sig Hummer Conversion
- Beginner question
- Hello everybody getting back into it
- What gas engine for an Easysport
- Your first plane?
- What servos should I use
- New guy in Fort Worth
- Beginner hello
- Water jet thruster motor size?
- Best airfoils fo long flights
- Cleaning up an old glow engine
- 3200 mah and 5000mah in eflite apprentice
- Need advice- new to planes
- Will this combo work?
- ESC calibration problem
- Apprentice STTS or Mini Apprenntice
- Carbon-z Cub with DX8 2nd Gen transmitter
- designing rc plane
- More than one way to skin a cat...
- Brushless Motor not Reaching Max RPM
- Tower Hobbies TS-51 servos
- YS muffler problem
- YS RC Airplane Muffler problem
- What happened to all the glow powered trainers?
- Throttle stick question for ZLRC (The Beast)
- Proposed Fiberglass RC Airplane with a 1.5hp diesel engine.
- EFlite Safe Mode - Adjusting Gain
- Beginner progressing nicely
- airhogs rc plane mid 2000's
- OS 46 IsoSmooth mount rubber crumbled
- Modeltech Magic Electric
- Cross like symbol on a Lucky Stick
- Super Cub kits?
- Building board for kit?
- New to RC aircraft and just bought a kit
- Long range / flight time with parallel batteries & other questions
- Apprentice S 15e Starting problem
- kill switch
- Axle Screw???
- Horizon Hobby Flight School
- AR620 Receiver compatibility
- Airtronics New Era 40 instructions Needed
- New To Hobby
- New to the group.
- I need a muffler
- Getting back into RC planes
- Just for a second or two
- Have equip, need plane recommendation
- Another Old Plane Being Brought Back To Life
- High Power to Weight Motor
- Books, Reports... please.
- .40 Engine in Phoenix Sonic?
- Pole count
- questions about pusher props.
- build
- New to rc HELP
- Load of noooob Q's
