PDA
View Full Version : Composites Fabrication And Repair
Pages : 1 2 [3] 4 5 6 7 8 9 10 11
  1. How many coats of gel cote
  2. applying gel cote to mold
  3. making formers
  4. foaming agent
  5. starmax gear mount needs reinforcement
  6. Reinforcing a Starmax F5e wing
  7. delta wing
  8. Can anyone help with this??
  9. Fiberglass Cloth Weight .. ??
  10. FREAKIN' MAYDAY....
  11. Vertical stab, how do I attach to composite fuselage? HELP!
  12. fibreglass cloth supplier
  13. Thixotropic epoxy
  14. Epoxy resin brands
  15. Peel Ply
  16. Peel Ply
  17. Paint primer in FG molding?
  18. glassing ABS
  19. Thread patterns
  20. Epoxy Resin Viscocity
  21. ballons vs chopped vs milled
  22. fiberglasswarehouse
  23. trimming the cowl
  24. DIY cowel - one off
  25. Building a fuse
  26. Fiberglass Thermal Glider
  27. WHAAAA! tore up my fiberglass fuse. HELP!
  28. Carbon fiber tailboom layup question.
  29. HELP! Composite fuselage, how do I attach vert and horiz stabs?
  30. Mold release problems.....
  31. PATRIOT PATTERN PLANE / NEED FIBERGLASS REPAIR HELP
  32. PVA question
  33. Help Repair a 3m Comp-Arf
  34. Epoxy type ?
  35. Wax type?
  36. Anyone used carbon fiber rod instead of music wire with Robostruts?
  37. Bowed aileron
  38. Identify the mfg of this plane?
  39. carbon Fiber
  40. How to cut out ailerons with CF laminate embedded?
  41. buying .020 lexan.....
  42. First fiberglass project, need some advise on sanding
  43. forming lexan
  44. Carbon Fiber Parts
  45. covering the......
  46. Fibreglass Finishing - advice needed PLEASE!
  47. How and which Mold release agent
  48. Carbon Help
  49. Mixing larger amounts of resin
  50. Why did this happen???
  51. to build another one of these G.P. T-Craft cowl & landing gear
  52. All Aluminum with Pics
  53. Materials..... 1/16 lite ply v.s. 1/8 balsa
  54. Priming & Painting Epoxy/Poly Kit
  55. COWL( just added pics)
  56. Building foam core wings
  57. Epoxy tooling coats
  58. Texalium supplier
  59. Need harder setting epoxy than wests 105
  60. Painting Composite plane
  61. Carbon Spinner
  62. how to ? fiberglass funjet
  63. Vacuum pump
  64. Someone help me fix a fibreglass fuselage
  65. KMP Cessna 337 Skymaster repair parts
  66. Fiberglassed ugly stick
  67. Advice on making glass canopy frame.
  68. How do I fix this?
  69. How do I fix this?
  70. Need opinions on material for flying wing
  71. Fiberglass or Carbon Fiber cloth
  72. Panel lines in cowl
  73. Fiberglassing Pink/Blue Foam
  74. PLASTER OF PARIS MOLD PROBLEM
  75. How to repair lexan?
  76. Epoxy Advice Needed
  77. how to remove wax
  78. ABS SURFACE PREPERATION
  79. Comp-ARF touch-up paint
  80. Fibreglass Mold/Plug Part Thickness
  81. Automotive filler and glazing putty
  82. How long will a plane last?
  83. Carbon Fiber Renforcement?
  84. Carbon Fiber Question??
  85. dent removal or fill?
  86. Help with design - plane unstable
  87. help glassing 1/3 scale floats
  88. Covering Foam wings with Fliteskin
  89. Gorilla glue lay up
  90. landing gear
  91. epoxy
  92. Yiiikes....Blistering!!!
  93. How do you create panel lines and rivet / screws for a mold ??
  94. Carbon Fiber Sheet Help
  95. coating a p 52 .20 with glass
  96. Compostie construction reading material
  97. Cardboard Plane
  98. Glass/adhesive compatability
  99. tooling resin use
  100. Value of Vacuum Bagging
  101. fuelproofing a foamie?
  102. Fuel Resistance & Compatability of P.U.V.
  103. Arrgh! fuselage has a seam
  104. Canopy mold help
  105. A Beginner's Guide to Cutting and Bagging Foam Wings
  106. Hard clear coating needed!
  107. Any one know of a Diamond DA-20, DA-40, DA-42 kit or arf?
  108. Carbon veil with nitrate dope ?
  109. Frekote FRP-NC a no release
  110. Gas Proof Help
  111. Dolphin wax
  112. carbon rod airfoil shape
  113. Resin vs. Poyurathane for glassing a model?
  114. Repairing a nick in a CF prop
  115. Composite fuse A-level project
  116. Radial Engine mold
  117. Sanded through fibreglass wing
  118. FIBERGLASSING A GIANT SCALE PLANE
  119. Covering whole wing with 2oz cloth
  120. Voids in the seam of a fiberglass fuse..
  121. Forming Canopy & cocpit
  122. Who made a 100" Superchipmonk ARF or kit?
  123. Look what I found...
  124. Mold Release
  125. Silicone/Mother (Shell) mold..anyone tried it?
  126. Carbon tubes/rods for landing gear
  127. In need of technical information.
  128. Fiberglass issue
  129. Painting Fiberglass
  130. GLARE like skin for RC model.
  131. surface quality of moulded parts
  132. Newbie needs some advice on Avistar wing.
  133. Remove wax from plastic part??
  134. Fiberglassing wing halves
  135. Twisted control surfaces?
  136. League 330 composite repair
  137. Airbag material
  138. How to color Epoxy
  139. SBD 4 Dauntless
  140. How can I repair this??
  141. Mold questions
  142. Invisible stiffeners.
  143. 3 mm carbon fiber rods or tubes?
  144. I NEED HELP WITH COVERING A PLANE WITH FIBERGLASS
  145. Questions regarding scale fuselage molding
  146. Fiberclassic skin delamination
  147. Vmax Q500 Hollow Composite Wing Repair?
  148. thickness of fiberglass
  149. P-47 Fuse Mold
  150. Bolt insert for composite gear
  151. Best CA Glue?
  152. TAIL/ELEVATOR REMOVAL
  153. 'N' Struts
  154. 3d cnc probe
  155. Restore Deformed Polyester Fuse?
  156. Carbon powder or Aluminium powder for epoxy surface coat on a mold?
  157. corematt or paper towel??
  158. Fiberglass cloth to CF cloth comparison for sailplane wing
  159. How to fuse two halfs together
  160. Wanted Excellent Painter
  161. best epoxy for layup?
  162. How many layers of glass do I need?
  163. Epoxy VS, Polyester, this will leave a mark.
  164. How and where to mark parting line on plug
  165. scratch Builders
  166. carbon fiber pushrods
  167. Need someone who can do 3d CAD foam cutting for plugs
  168. where can I find a cowl
  169. Foam Repair and Glues....
  170. Expert sl800 servo parts?
  171. making f/g cowls / spinners
  172. Hawker Tempest Project!
  173. Hawker Tempest Project!
  174. Covering Balsa with Carbon Veil
  175. Prather Micro Balloons
  176. Avro Arrow's Restoration started!
  177. Is 40" too small for a fiberglass fuse?
  178. Home Depot epoxy for fiberglass cowl?
  179. Plug/Parting board
  180. Hanger9/Carden yak Fix?
  181. Surface sheeting for Wing Plugs to make Molds
  182. What happened here - Delamination
  183. Hysol 9462 or 3M DP100/110?
  184. Repair to my Composite ARF EXTRA
  185. Restoring distorted f/g cowl?
  186. This the plugs for my new Q/500
  187. Looking for a computer controlled hotwire machine and router cutter
  188. Fuselage without Formers/Bulkheads
  189. How can i fix and reinforce aircraft redome.
  190. CARF
  191. Funtana rebuild
  192. Tooling Dough??
  193. 2-phase structural epoxy question
  194. vacuum pump from Harbor Freight
  195. Building with Foam and Covering it
  196. Rookie needs Help/Advise on fiberglassing a Balsa/Ply Hydroplane
  197. Getting scale details into fiberglass parts (lost foam method)
  198. Vacuum pump drenched in oil
  199. other than gelcoat?
  200. Lightweight Finishes over Balsa
  201. Simple Plug-What to use as a release Agent
  202. Fuel proofing: Thinning Epoxy or Lacquer?
  203. building a better cowl?
  204. Are autoclaves and vacuum bags necessary?
  205. Carbon fiber over fiberglass wing tube?
  206. How does carbon fiber veil and dope add strength to balsa?
  207. What would you do with crack?
  208. Which material for glass fuse reinforcing?
  209. Joe Nall
  210. removing paint from fiberglass fuse
  211. composite wet layup with micro ballon mixed Epoxy
  212. fiberglass and Gorilla glue????
  213. fiberglass spring
  214. Polyeter Epoxy Compatability
  215. Beginner to fabricating stuff...
  216. 32 inch pitts question
  217. How do you use/apply C/F?
  218. HELP: Problems with West Systems 209 Hardener
  219. Dave Patrick Ultimate
  220. Composite Muffler/Header?
  221. Cut Fiberglass Cowl?
  222. RC Plane Composite Molding Video (Thorough Like "Vacuum Bagging Made Easy")
  223. polyester gelcoat / epoxy layup?
  224. polyester mold epoxy parts
  225. thinning z-poxy
  226. 4 meter glider wings. How much structure?
  227. C/F repair of a composite arf
  228. Using CF/FG in repairs?
  229. metric wing tube?
  230. Composite Sandwich Firewall
  231. Peeling Skin
  232. Q 500 Pylon racer V-tail lay-up
  233. high temp epoxy
  234. Hotliner wing bolt area repair
  235. Source for EPP?
  236. Release agents- What's the differance?
  237. Quickee 500 V tail lay-up schedule?
  238. Tooling gell need??
  239. Carbon Fiber wing tubes.
  240. Quickie 500 Fuselage layup and mold building pics
  241. Looking for a dealer who sells all materials needed
  242. carbon fiber question...
  243. First attempt at making fiberglass cowl need advice
  244. F35 drawings
  245. Orthopaedic Casting Tape
  246. Vacuum infusion or bagging?
  247. Fiberglassing wing panels together
  248. Need Help identifying and glueing plastics
  249. Custom DLG
  250. Oil Poly. vs Water Poly. vs Finishing Resin
