Smart-Fly (Quest Engineering) Support Forum Support forum for all Smart-Fly products. Equalizers, Batshare, Ignition Cutoff, Regulators.
Best way for 14 channels
Reply
Old 10-26-2010, 09:14 PM
Craig Wight
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Best way for 14 channels
Hi Robert
Would appreciate advice before I purchase. I have a scale float plane project requiring 14 channels. Using Futaba 12Z with 6014 receiver,giving 12 usable channels.
Plane has 2 servos each for Ailerons, Flaps and Elevator.
As far as I can see I could:
1. Use Power Expander EQ10 and using servo matching for above dual servos would give me 13 channels plus 1 direct into receiver. Would require Ignition cut off switch Total cost 309.90
2. Use Power Expander Competition 12 Plus and would require 2X Equalizer 11, with 2 channels direct into receiver. Ignition included. Total cost 274.90.
Other than cost would there be any other differences I need to consider, assuming above is correct and they will both achieve what I require.
I am leaning towards the EQ10 as would eliminate the extra clutter of Equalizer 11's
Craig Wight
Craig Wight is offline
Old 10-27-2010, 09:24 AM
rrritchey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Best way for 14 channels
Hi Craig,
You cannot run any servos directly off the receiver. There are ways to grab the signal from the receiver and power the servo from the system. I can help you with that. Other than that either system would work but the Eq10 is a bit cleaner.
rrritchey is offline
Contact Us Archive Advertising Cookie Policy
