Smart-Fly (Quest Engineering) Support Forum Support forum for all Smart-Fly products. Equalizers, Batshare, Ignition Cutoff, Regulators.
A123's and the Suer Reg
Reply
Old 04-15-2011, 08:20 AM
Bent Nail
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default A123's and the Suer Reg
Normal0falsefalsefalseoNotPromoteQF />EN-USX-NONEontGrowAutofit />ontVertAlignCellWithSp />ontBreakConstrainedForcedTables />ontVertAlignInTxbx />MicrosoftInternetExplorer4
Hi Robert, the receiver NICADs for my 1/3 L5 have finally given up after 5 years O well. I have decided to try A123’s. I have the Smart-Fly Power Expander Pro and Super Reg. Since I was using NICAD’s the Super Reg has been comfortably stored in its box (I had a bad experience with LiPoly). I was wondering about the effects of the 6.6 volts on my HiTech 645M (control surfaces) and smaller servos (for engine also rated 6.0 volts). I fully understand that you do not know the condition of my servos but I am asking the question in general. I can use the SuperReg to reduce the voltage but is it necesssary. I did read the information on the Power Expander and noted that A123’s can be plugged in directly. I also use the fail-safe switch.
Thanks John M.
Bent Nail is offline
Old 04-15-2011, 08:25 AM
rrritchey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: A123's and the Suer Reg
Hi John,
A123s work fine with the SuperReg as long as you do not set the SuperReg above 6.0V. You need about 0.5V difference between the input voltage and the set output voltage. If the input goes below that differential the output will drop.
rrritchey is offline
Old 04-15-2011, 09:38 AM
Bent Nail
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Robert for the quick reply. Iwill make a broad assumption that you do not think it is a good idea to 6.6 volts into the servos. Also, 'the output will drop' that does not meen the Servos will quit, they will just get less voltage.
John
Old 04-15-2011, 10:02 AM
rrritchey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
Actually, its hard to say about the servos. "Most" servos will take the 7.2V OK (full charge) and 6.6V is really fine, but you need to check you particular servo type. Sorry I cannot be more help. People generally run A123s so they do not have to run regulators, that is one of the "perceived" advantages.
Old 04-15-2011, 10:49 AM
Bent Nail
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Robert that helps make my decision more informative.
John
Contact Us Archive Advertising Cookie Policy
