Super Reg Question
Super Reg Question
Im using A Super Reg with two 2 cell 1600 mah lipos. The question is if one of those lipos is a 45c discharge rate and the other is a 25c discharge rate is that going to matter? And if so how? My way of looking at it is you have two gas tanks of the smae size but a larger fuel line going out of one than the other ...... correct me if im wrong..
Thanks Matt
Thanks Matt
AZ
RE: Super Reg Question
Hi Matt,
The SuperReg will keep the battery's voltage equal so basically the only thing that matters is the mAH rating. You may get a tiny bit more difference in voltage between the two packs but not much (a few tenths).
