Smart-Fly (Quest Engineering) Support Forum Support forum for all Smart-Fly products. Equalizers, Batshare, Ignition Cutoff, Regulators.
Comp Arf Pitts setup
Reply
Old 09-20-2011, 04:06 PM
FormerCA.
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Comp Arf Pitts setup
Robert
could you give me your suggestion on which power expander to use on my new Pitts.
Ron
FormerCA. is offline
Old 09-21-2011, 06:03 AM
rrritchey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Comp Arf Pitts setup
Hi Ron,
I need a lot more information. I am not familiar with all the planes so I don't know how big this is. I don't know what kind of batteries you want to run and if you want the servos regulated or unregulated. I also don't know the radio you are using, my suggestion might be different for a 12-channel radio than a radio with less channels. I also don't know if you are looking for servo matching in the unit or will do that some other way. If you can provide me more information I can narrow down your choices.
rrritchey is offline
Old 09-21-2011, 08:52 AM
FormerCA.
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sure
CompArf Pitts biplane-2 servos in each wing panel for a total of eight digital servos. Moki 250 radial engine, 2 digital servos for the elevator and 2 digitals for the rudder. I use Fromeco relions almost exclusively in all my big planes. Plane will all-up at around 44 lbs. All radio equipment is Futaba. 10 channel 2.4. prob need to regulate the servos at 6v. Want to use Futaba 9156 servos throughout. Also like to use gas engine kill switch.
Ron
Old 09-21-2011, 09:50 AM
rrritchey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Ron,
In this size plane with the equipment you have and the setup you want I think you will have to pair a PowerExpander Eq10 with a TurboReg. The Eq10 is the only unit that can support 8 aileron servos. You would then have to add the single receiver Ignition Cutoff to this. Let me know if you have more questions.
Contact Us Archive Advertising Cookie Policy
