Ignition cutoff location question
My Feedback: (32)
I am setting up a friends Extra with a DA50. Ignition is going to be used with a 7.4Li-ion with regulator. My question is where would I install the cutoff? Between the regulator and ignition box or would it go before the regulator? Or does it really matter?
My Feedback: (62)
NJ
RE: Ignition cutoff location question
I would think the regulator would go after the cutoff and before the ignition.
That's where mine goes to keep the input voltage to the ignition below 6 volts.
Hope that helps
Bob
Hope that helps
Bob
AZ
ORIGINAL: killerG
My Feedback: (32)
ok, i finally hooked it up, but I can't get the cutoff to work. I can't get power to to the ignition. I believe the module by the RX is bad. I have even used a couple of different optic cables and still, nothing. Then I took the module that mounts by the motor and installed it in another plane with a cutoff and I can get power to the ingition then. It must be the module buy the RX.
AZ
ORIGINAL: killerG
My Feedback: (32)
Yes, the green LED on the fiber optic transmitter is going on/off in conjunction with the toggle switch on my transmitter. So my programming in the radio is correct and setup correctly. And like I said the receiver module is good since I tested it on another plane. The transmitter unit must be bad unless I am missing something else. I have hooked these up before, so I am familiar with how they are setup/work. Anything other way to test it?
AZ
I have never seen a bad unit when the green LED is working. Are you sure you prepared BOTH ends of the fiber-optic cable by very carefully cutting then with a sharp razor or Xacto blade so the ends look like perfectly round shiny mirrors?
My Feedback: (32)
Well, I have tried cutting the cable ends again, even used a different cable, checked all the connections again, and it still doesn't work. I did what you aksed and hooked up a servo to the throttle cut channel, and the servo works with the opperation of the toggle switch. The transmitter module must be bad. There is no other option.
AZ
ORIGINAL: killerG
AZ
ORIGINAL: killerG
I got the new module today, everything works like a champ. I will put the bad one in the mail to you tomorrow.
this happen before.
