Smart-Fly (Quest Engineering) Support Forum Support forum for all Smart-Fly products. Equalizers, Batshare, Ignition Cutoff, Regulators.
FailSafe for cutoff
Reply
Old 02-01-2013, 01:51 PM
tchanter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default FailSafe for cutoff
I'm using channel 7 (a toggle switch) AR8000 - Have set the ATV on that channel to +/-150% - Bound to transmitter with that channel off and throttle at idle - The ignition cuttoff works fine BUT when I turn off the transmitter the throttle returns to idle the ignition remains on. Shouldn't it turn off becase of the AR8000's failsafe?? The cutoff is part of an EQ6...
Regards
Trey
tchanter is offline
Old 02-01-2013, 02:05 PM
rrritchey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FailSafe for cutoff
Hi,
Some Spektrum receivers only failsafe the throttle channel. You need to check your receiver specifications. You can also check by plugging in a servo, turning your switch to the cutoff enable position and then turn off your transmitter to see if the servo does a full rotation indicating it went to the failsafe position.
ORIGINAL: tchanter
Regards
Trey
rrritchey is offline
Old 02-01-2013, 02:37 PM
tchanter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hmm... Will check tomorrow AM - thanks for the prompt reply!
tchanter is offline
Old 02-01-2013, 02:41 PM
rrritchey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If the Cutoff is following the toggle switch then if the receiver failsafes to the off position the Cutoff HAS to turn off.
ORIGINAL: tchanter
Old 02-01-2013, 03:40 PM
tchanter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Never mind... grabbed mannual "when signal is lost the throttle channel ONLY (my emphasis) is driven to it's preset failsafe position" - Apparently I'm too use to PCM stuff...
Regards,
Trey
tchanter is offline
Contact Us Archive Advertising Cookie Policy
