Ignition cut off
KS
Hello. I purchased a Smartfly Opto ignition cut off last November. I installed it in my Staggerwing Beech. Every thing works fine except for one thing. The ignition doesn't cut off when the tx signal is lost. Hope you can help me on this.
KCKRCER
KCKRCER
AZ
Hi,
You have to set the failsafe on your transmitter channel to turn off the Cutoff when you
turn off your radio. The Cutoff has no way of knowing if your transmitter is on or off
if you do not set your failsafe correctly.
ORIGINAL: kckrcer
KCKRCER
KCKRCER
KS
Ah there's the rub. I forgot to put in the other part of my situation. I am flying with a Fut. 9-C Super with a add on 2.4 module. In order for 2.4 to work you have to use PPM mode. To have fail safe you must be in PCM mode. So it would appear I can't have ignition cut off at loss of signal with this rig. Do the new radios now have failsafe on 2.4?
Thanks for replying.
KCKRCER
KCKRCER
AZ
Hi,
The new 2.4 Futaba radios set failsafe just like the PCM radios in the transmitter except for
some of the low channel receivers which only failsafe the throttle but they are typically
park flyer type receivers.
ORIGINAL: kckrcer
KCKRCER
KCKRCER
Previous Thread
Next Thread
