Smart-Fly (Quest Engineering) Support Forum Support forum for all Smart-Fly products. Equalizers, Batshare, Ignition Cutoff, Regulators.
Mounting Smart-Fly units
Reply
Old 03-25-2013, 09:19 AM
sparkx38
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Mounting Smart-Fly units
I've seen where alot guys are putting wodden rails down to mount thier boards to because the white plastic piece on the bottom holds it off of the wood. Is this done on purpose to reduce vibration or some other reason?
sparkx38 is offline
Old 03-25-2013, 09:23 AM
rrritchey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Mounting Smart-Fly units
Hi,
You want the unit mounted so the grommets do what they are suppose to do. This means the only point of contact on
the units should be the 4 grommets. The eyelets must be installed correctly, from the bottom, and servo screws (that
have a built-in washer) or regulator screws with a washer must be used so the eyelet/washer forms a "U" so that
the grommet is not crushed.
ORIGINAL: sparkx38
rrritchey is offline
Contact Us Archive Advertising Cookie Policy
