Smart-Fly (Quest Engineering) Support Forum Support forum for all Smart-Fly products. Equalizers, Batshare, Ignition Cutoff, Regulators.
Ignition Cutoff
Reply
Old 05-30-2013, 05:40 PM
Rogler.2008
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Ignition Cutoff
I have the EQ6 and Futaba R617FS receiver. I'm setting up a 35% extra 300. Presently all the receiver channels are being used, for the extra aileron and dual batteries. Channel 7/bat not being used. Can I use empty spot for the ignition cutoff. If not how would you setup the receiver to use the ignition cut off.
Tony
Rogler.2008 is offline
Old 05-31-2013, 06:09 AM
rrritchey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Ignition Cutoff
Hi,
You should have Ch 1 or 8 (depending on if your receiver numbers go left to right or right to left) plugged into your Throttle. Five of the single wire channels should be plugged in to the receiver
and the other 3-wire channel should plug into your channel 7. Typically channel 5 is used for Cutoff since its already on a switch for gear. The Cutoff must be assigned on one of the programmable
(2-7) channels. If you need me to walk you through this then I suggest you call.
ORIGINAL: Rogler.2008
Tony
rrritchey is offline
Contact Us Archive Advertising Cookie Policy
