Smart Fly Regulator Question
My Feedback: (23)
I am considering a plane where I would like to run either a single Fromeco 2400 or 4800 pack. I want to put a deans connector on it so I'd probably be going with your HD Regulator. Then, what I would like to do, is have the Regulator with dual 22 gauge outputs. Do you have anything like the this?
My set up scheme is: battery->on/off switch->regulator->receiver.
From what you have on your website, I'd have to go: battery->regulator->on/off switch->receiver.
I'd just like to be able to check the battery voltage under a load without having to add an volt meter the plane.
